Custom Control in menu item [message #1764133] |
Thu, 25 May 2017 15:33 |
I would like to generate a menu item as a custom control (a checkbox-button with text in my case).
I implemented a org.eclipse.jface.action.ControlContribution then added to my MenuManger, but this way I am breaking an internal JFace assertion:
org.eclipse.core.runtime.AssertionFailedException: assertion failed: Can't add a control to a menu
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:110)
at org.eclipse.jface.action.ControlContribution.fill(ControlContribution.java:88)
at org.eclipse.jface.action.MenuManager.doItemFill(MenuManager.java:728)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java:810)
at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java:472)
at org.eclipse.jface.action.MenuManager.access$1(MenuManager.java:465)
at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager.java:497)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:256)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:5227)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1340)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1366)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1345)
at org.eclipse.swt.widgets.Menu.gtk_show(Menu.java:711)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1949)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5492)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2495)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4149)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:161)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Any comment?
thanks!
-Piero
Re: Custom Control in menu item [message #1764204 is a reply to message #1764186] |
Fri, 26 May 2017 15:49 |
Thank yoy Brian.
Having a checkbox item is enough here.
I blindly did not notice the IAction.AS_CHECK_BOX style bit for actions, which worked for me.
However, I would like the menu to stay open when clicking on this checkbox-ed item, to be able to toggle without having to re-open the menu each time.
How could I control that?
thanks,
-Piero
Re: Custom Control in menu item [message #1764356 is a reply to message #1764186] |
Mon, 29 May 2017 07:03 |
Thank yoy Brian.
thanks,
-Piero
FUDForum. Page generated in 0.03850 seconds
