Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMFStore on Tomcat: How to set it up using MongoDB?
EMFStore on Tomcat: How to set it up using MongoDB? [message #1764105] Wed, 24 May 2017 21:03 Go to next message
Yuri Sokolovski is currently offline Yuri SokolovskiFriend
Hi, I followed the instructions http://eclipsesource.com/blogs/2016/11/15/running-emf-client-platform-emfstore-as-rap-application-on-tomcat/ to start EMFStore in Tomcat environment. But I couldn't figure out how to make it use MongoDB as a back-end as opposed to the filesystem.
Is there any documentation on how to configure it for Tomcat installation? Appreciate any pointers!
Thank you!
Re: EMFStore on Tomcat: How to set it up using MongoDB? [message #1764522 is a reply to message #1764105] Tue, 30 May 2017 20:10 Go to previous messageGo to next message
Edgar Mueller is currently offline Edgar MuellerFriend
Hi Yuri,
sorry for the delay. No, unfortunately there's no such guide. I'll need to look through the guide myself, but I'll keep you posted once I know more.
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Edgar Mueller
Re: EMFStore on Tomcat: How to set it up using MongoDB? [message #1764604 is a reply to message #1764522] Wed, 31 May 2017 16:24 Go to previous messageGo to next message
I had a look at the article and I think you need to pay attention to the following aspects:
- When setting the target, make sure the necessary mongo bundles are available (see ecpmongo.target in the EMFStore repo)
- When creating the warproduct based on the launch config, the launch config should contain the relevant mongo bundles. There's a launch config you can use for comparison in the mongodb.client bundle
- Check for any missing plugin dependencies during war export
- After exporting and starting/stopping the server, update the mongodb.properties file under $TOMCATDIR/.emfstore/server/profiles/default/conf to adjust any mongo db specific properties
Let me know if this is of any help.
Edgar
Edgar Mueller
Re: EMFStore on Tomcat: How to set it up using MongoDB? [message #1764838 is a reply to message #1764604] Fri, 02 June 2017 14:26 Go to previous message
Thank you very much, Edgar!
I'll give it a try.
-Yuri
Previous Topic:How to add a map with generics?
Next Topic:can-not open xmI files
Current Time: Fri Oct 30 15:40:37 GMT 2020
Powered by FUDForum. Page generated in 0.02452 seconds
