Re: No Tracing Events in Forte Console [message #1763902 is a reply to message #1763827] |
Mon, 22 May 2017 17:58 |
In FORTE 1.8.x we deactivated per default all output as the output can have quite some performance implications. Therefore not seeing anything is perfectly fine. The best way to test if your FORTE is working is to download a small sample program and monitor the values and events of the application. The advantage of this approach is that this is working for all FORTE supported devices even for those which have no display.
If you want to see the tracing and debug output you need to set the variable CMAKE_BUILDTYPE to Debug and then you can set the tracing and logging options in the cmake options.
I hope this helps.
Alois
Re: No Tracing Events in Forte Console [message #1764107 is a reply to message #1763960] |
Wed, 24 May 2017 22:17 |
I see two issues in your screenshot. The first is that in this version there seems to be an issue with FORTE's cmake configuration files. AFAIK this is fixed in the latest version in our git repository. Therefore I would kindly ask you to clone our git repo and checkout the 1.8.x branch.
The second point is that you haven't set the FORTE_ARCHITECTURE to the value for your platform.
I hope this helps,
Alois
FUDForum. Page generated in 0.02962 seconds
