Home » Modeling » EMF » [TENEO] Save Double list with NaN and Infinity
[TENEO] Save Double list with NaN and Infinity [message #1763407] Mon, 15 May 2017 12:52
Patric Bayer is currently offline Patric BayerFriend
I'm quite new in using Teneo, but I'm very happy to have found something to persist my EMF model in a relational database instead of using the XML format. My problem is, that one of my data containers stores (a list of) Double values which can be also NaN, Infinity or NULL. I tried to overcome this by using @PrePersist respectively @PreUpdate annotation, but sadly that does not work (the method to replace above mentioned values by double placesholders aren't called, so the annotation does not seem to work).
Any idea how to solve this problem respectively get the annotions solution run?
Thanks in advance
Patric
Previous Topic:difference between dynamique instance and XMfile
Next Topic:[CDO] Create ecore model with CDOBlob attribute
Current Time: Sat Feb 22 13:34:46 GMT 2020
Powered by FUDForum. Page generated in 0.07261 seconds
