| Apply DateColumnFilter [message #1763157] |
Fri, 12 May 2017 04:25  |
I got a problem with the ColumnUserFilterState, that seems to not work with Dates.
I have a Column "SollAnColumn" with Dates in it and on this column I want to set a filter whitch excludes all rows of the Table with their Date outside of the given Range (Date fromDate, date toDate).
I would be very grateful for your help.
Here is a Snippet of the Column, where I want to apply a filter:
@Order(30.0)
public class SollAnColumn extends AbstractCockpitCisDateTimeColumn {
public int compareTableRows(ITableRow r1, ITableRow r2) {
return compareRowZeitBySort(r1, r2, SortMode.SOLL);
protected void execDecorateCell(Cell cell, ITableRow row) throws ProcessingException {
super.execDecorateCell(cell, row);
ZugfahrtAmBetriebspunktDTO model = (ZugfahrtAmBetriebspunktDTO) row.getCellValue(getZugfahrtAmBetriebspunktModelColumn().getColumnIndex());
if (!Objects.equals(model.getZugfahrtPunkt().getAnZeit().getSoll(), cell.getValue())) {
cell.setFont(ITALIC_FONT);
} else {
cell.setFont(NORMAL_FONT);
The Abstract Column with the correct Date Format:
public class AbstractCockpitCisDateTimeColumn extends AbstractDateColumn {
private static final String DATE_TIME_FORMAT = "HH:mm dd.MM.yyyy";
private static final String TIME_FORMAT = "HH:mm";
protected Date execParseValue(ITableRow row, Object rawValue) {
CisDateTime timeValue;
if (rawValue instanceof CisDateTime) {
timeValue = (CisDateTime) rawValue;
} else {
timeValue = CisDateTime.createCisDateTime((Date) rawValue);
return super.execParseValue(row, timeValue.getDate());
CisDateTime value = CisDateTime.createCisDateTime(getValue(row));
cell.setText(formatCisDateTime(value));
private String formatCisDateTime(CisDateTime value) {
if (value == null) {
return null;
int today = new DateTime().getDayOfYear();
if (value.getDateTime().getDayOfYear() != today) {
return value.toString(DATE_TIME_FORMAT);
return value.toString(TIME_FORMAT);
The Filtermananger applys when RadioButtonValue has changed:
@Order(10.0)
public class ZeitraumStundenGroup extends AbstractZugfahrtPunktZeitraumGroup {
protected boolean getConfiguredEnabled() {
return true;
protected void execChangedValue() {
Zeitraum zeitraum = getValue();
ZugfahrtPunktTableColumnFilterManager filterManager = getFilterManager();
if (filterManager != null) {
filterManager.applyCisDateComparableFilter(getTable().getSollAnColumn(), zeitraum);
The TableFilterManager how should apply the Filter to the Table, but doesnt seem to work:
public class ZugfahrtPunktTableColumnFilterManager extends TableUserFilterManager {
private AbstractTable table;
public ZugfahrtPunktTableColumnFilterManager(AbstractTable table) {
super(table);
this.table = table;
public void applyCisDateComparableFilter(IColumn filterCol, Zeitraum zeitraum) {
TableUserFilterManager filterManager = table.getUserFilterManager();
DateTimeColumnUserFilterState comparableFilter = (DateTimeColumnUserFilterState) getFilter(filterCol);
if (comparableFilter == null) {
comparableFilter = new DateTimeColumnUserFilterState(filterCol);
comparableFilter.setDateFrom(zeitraum.getZeitVon().getDate());
comparableFilter.setDateTo(zeitraum.getZeitBis().getDate());
if (filterManager.getFilter(filterCol.getColumnId()) != null) {
filterManager.removeFilterByKey(filterCol.getColumnId());
filterManager.addFilter(comparableFilter);
If you need more information just ask.
best regards,
Joshi
| Re: Apply DateColumnFilter [message #1763981 is a reply to message #1763693] |
Tue, 23 May 2017 11:19  |
Hei Claudio
Alriight, i thought this is how you should define a filter in Java scout specific.
But you were right, there is no need for those TableUserFilterManager in this case.
Thank you for your help.
Joshi
FUDForum. Page generated in 0.05773 seconds
