Home » Modeling » TMF (Xtext) » Building for Eclipse and LSP
Building for Eclipse and LSP [message #1761441] Thu, 11 May 2017 08:55 Go to next message
Vlad Dumitrescu is currently offline Vlad DumitrescuFriend
Hi!
I upgraded to Xtext 2.11 and need to build both an Eclipse plugin and a vscode extension. The problem is that plugins can only be built with Maven, and the LSP server is much easier to build with Gradle.
I am trying to combine those, but without luck yet. Should it work, or am I trying in vain?
I tried to find a Maven plugin that would bundle the LSP server with all deps in a fat jar, but could not make that work either.
What would be the best way to provide both artifacts?
best regards,
Vlad
Re: Building for Eclipse and LSP [message #1761443 is a reply to message #1761441] Thu, 11 May 2017 09:00 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
hi,
what was your exact problem with that.
what about having a maven AND a gradle build?
if you select eclipse + gradle in the wizard it should offer you to do that?
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Building for Eclipse and LSP [message #1761445 is a reply to message #1761443] Thu, 11 May 2017 09:06 Go to previous messageGo to next message
Oh, I didn't read the second sentence when choosing Gradle, about creating a Tycho build too.
It's a bit of work to recreate the projects with the wizard for an existing code base, but it sure is easier than trying to do it by hand! I had probably missed some settings.
Thanks Christian!
Re: Building for Eclipse and LSP [message #1761446 is a reply to message #1761443] Thu, 11 May 2017 09:06 Go to previous messageGo to next message
anf for pure maven you should have a look at
- copy dependencies from https://maven.apache.org/plugins/maven-dependency-plugin/copy-dependencies-mojo.html
- https://maven.apache.org/plugins/maven-shade-plugin/
Re: Building for Eclipse and LSP [message #1761448 is a reply to message #1761446] Thu, 11 May 2017 09:08 Go to previous messageGo to next message
I tried those plugins, but again, something is probably missing because I got an incomplete result. I hope to get Gradle working, though.
Re: Building for Eclipse and LSP [message #1761451 is a reply to message #1761448] Thu, 11 May 2017 09:16 Go to previous messageGo to next message
=> use the wizard. that should work out of the box
Re: Building for Eclipse and LSP [message #1763263 is a reply to message #1761451] Fri, 12 May 2017 09:17 Go to previous messageGo to next message
Thanks, it looks like it is working, but when trying out the mydsl example, I get an error; any ideas what I can do to fix it?
[Error - 11:14:53 AM] Server initialization failed.
Message: java.lang.reflect.InvocationTargetException
Code: -32603
Re: Building for Eclipse and LSP [message #1763272 is a reply to message #1763263] Fri, 12 May 2017 10:14 Go to previous messageGo to next message
did you start the java -jar manualy to get a complete stacktrace
Re: Building for Eclipse and LSP [message #1763274 is a reply to message #1763272] Fri, 12 May 2017 10:30 Go to previous messageGo to next message
I used the embedded variant. Will try the standalone, but so far I can't get it to connect (to be specified that I don't have a pure mydsl demo, but implemented it similarly on my code base)
Re: Building for Eclipse and LSP [message #1763275 is a reply to message #1763274] Fri, 12 May 2017 10:36 Go to previous messageGo to next message
no i mean:
in the embedded variant you have a shell script or something
simply call that manually from cmd line
Re: Building for Eclipse and LSP [message #1763277 is a reply to message #1763275] Fri, 12 May 2017 10:37 Go to previous messageGo to next message
The error is thrown when receiving the first message. Just starting from CLI works fine, the server sits and waits for a connection.
Re: Building for Eclipse and LSP [message #1763280 is a reply to message #1763277] Fri, 12 May 2017 10:50 Go to previous messageGo to next message
that looks strange. so the error happens on connect. maybe you can start the server with remote debugging so you can inspect
Re: Building for Eclipse and LSP [message #1763284 is a reply to message #1763280] Fri, 12 May 2017 11:05 Go to previous messageGo to next message
I will try that, it's been a while since doing that.
My guess is that the problem occurs when the jsonrpc dispatcher calls the initialize method - that would be consistent with the InvocationTargetException that is reflection-related.
Re: Building for Eclipse and LSP [message #1763550 is a reply to message #1763284] Wed, 17 May 2017 10:24 Go to previous messageGo to next message
anil chalil is currently offline anil chalilFriend
Member
I encoutered with same error as well. Then i moven my dsl files to a new directory and from vscode i opened directory. Exception has gone. But i dont know what fixed it i mean opening the directory or a fresh directory without other files.
Re: Building for Eclipse and LSP [message #1763625 is a reply to message #1763550] Thu, 18 May 2017 07:15 Go to previous messageGo to next message
You are right, thanks!
So the problem happens when opening files without a current open folder... Looking at the code, it should be handled with a proper error message, but maybe something goes wrong before getting there, while doing the dependency injection magic.
Re: Building for Eclipse and LSP [message #1763627 is a reply to message #1763625] Thu, 18 May 2017 07:21 Go to previous message
well this is: https://github.com/eclipse/xtext-core/issues/57
Previous Topic:Cannot be resolved
Next Topic:default value for Boolean attribute and serialization
Current Time: Fri Oct 22 11:01:36 GMT 2021
Powered by FUDForum. Page generated in 0.02630 seconds
