Home » Eclipse Projects » Jubula » Close tab by jubula(Close tab by jubula)
Close tab by jubula [message #1761427] Thu, 11 May 2017 03:55 Go to next message
trung nguyen is currently offline trung nguyenFriend
I have a problem when closing tab in AUT application. Normally, I use key "Alt + -" to open a table and press "C" to close. But Jubula does not support key "Alt + -", and I can't use object mapping to click to sign "X" to close as well (object mapping just map whole tab, not map sign "X").
Let me know what way to resolve the situation?
Trung.
Re: Close tab by jubula [message #1761457 is a reply to message #1761427] Thu, 11 May 2017 09:48 Go to previous message
Marvin Mueller is currently offline Marvin MuellerFriend
there is the unbound module called "ub_app_externalPressAnyKey". This action is taking a modifier key (in your case "alt") and a base key(in your case "MINUS" without the ") . This action will then do your key combination.
kind regards
Marvin Mueller
Previous Topic:Problem installing Jubula database drivers from bredex
Next Topic:Jubula extension component !
Current Time: Sat Dec 07 19:40:58 GMT 2019
Powered by FUDForum. Page generated in 0.01976 seconds
