Home » Eclipse Projects » e(fx)clipse » Wrong bundle loaded after update on macosx
Wrong bundle loaded after update on macosx [message #1761260] |
Tue, 09 May 2017 12:14 |
Guillaume Papon Messages: 13 Registered: August 2016 |
This issue follows one we previously had about macosx bundling.
We were unable to create a .pkg installer using Tycho so we fInally, we gave up and ended doing the packaging "by hand".
So we have a exec-maven-project running a script like this :
#!/bin/sh
file_path=$( cd "$(dirname "${BASH_SOURCE[0]}")" ; pwd -P )
if [ ! -d "$HOME/CNOP/FAST" ]; then
mkdir -p $HOME/CNOP/FAST
fi
cd "$HOME/CNOP/FAST"
export applicationXMI='dp.fast.core.workbench/Application.e4xmi'
$file_path/../jre/bin/java -Dorg.osgi.framework.bundle.parent=ext -Dfile.encoding=UTF-8 -classpath $file_path/../Eclipse/plugins/org.eclipse.equinox.launcher_1.3.100.v20150511-1540.jar org.eclipse.equinox.launcher.Main -product dp.fast.core.workbench.product -configuration file:$file_path/../Eclipse/configuration/ -os macosx -arch x86_64 -nl fr_FR -noSplash -clearPersistedState
# -DforceDebug=true -Dmode=dev -debug -consoleLog
Which is packaged using native pkgbuild to produce a working installer:
pkgbuild --identifier dp.fast.app --root ../target/dp.fast.product-mac/dp.fast.product/ --install-location /Applications ../../dp.fast/deploy/Fast.pkg
But problem comes later.
We use the standard UpdateService which is working correctly. The app loads new stuff from repository and put it in app/plugins directory, so we end up having in this directory both versions of each of our plugins (say versions 1 and 2).
On windows, when the app starts, it picks up the correct version of the plugins (version 2), but on mac, it keeps loading the wrong one (version 1). If i delete all v1 jars, it picks up the correct ones (v2 obviously) but if i then undelete them (so we now have back v1 and V2), it keeps taking v2.
Is it a known issue? How does equinox choose which jar to load when there are several availables?
Maybe we miss a parameter from our custon packager command line?
Thanks for help.
Re: Wrong bundle loaded after update on macosx [message #1763447 is a reply to message #1763421] |
Tue, 16 May 2017 09:41 |
I am not sure i can create a minimal working example, it would be too complex, but maybe i will try later if i have time. And i dont really understand what your second sentence means.
But i noticed a difference between windows and mac in the file configuration\org.eclipse.equinox.simpleconfigurator\bundles.info (which, correct me if i am wrong, seems to describe the jars to load)
On windows, when i do the update, this file contains only the new version of the jars, ex:
dp.fast.app,2.0.1,plugins/dp.fast.app_2.0.1.jar,4,false
dp.fast.app.update,2.0.1,plugins/dp.fast.app.update_2.0.1.jar,4,false
dp.fast.app.workbench,2.0.1,plugins/dp.fast.app.workbench_2.0.1.jar,4,false
dp.fast.connector,2.0.1,plugins/dp.fast.connector_2.0.1.jar,4,false
dp.fast.core,2.0.1,plugins/dp.fast.core_2.0.1.jar,4,false
dp.fast.core.fx,2.0.1,plugins/dp.fast.core.fx_2.0.1.jar,4,false
But on mac, it contains both the old and the new version:
dp.fast.app,2.0.0,plugins/dp.fast.app_2.0.0.jar,4,false
dp.fast.app.update,2.0.0,plugins/dp.fast.app.update_2.0.0.jar,4,false
dp.fast.app.workbench,2.0.0,plugins/dp.fast.app.workbench_2.0.0.jar,4,false
dp.fast.connector,2.0.0,plugins/dp.fast.connector_2.0.0.jar,4,false
dp.fast.core,2.0.0,plugins/dp.fast.core_2.0.0.jar,4,false
dp.fast.core.fx,2.0.0,plugins/dp.fast.core.fx_2.0.0.jar,4,false
I guess the problem lays here. If i remove the lines containing the old version, the app correctly loads the new bundle (obvioulsy).
So what can create these double lines ?
Current Time: Sat Apr 20 01:36:08 GMT 2024
Powered by FUDForum. Page generated in 0.03904 seconds
