Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMFStore]: What do I to invoke LADPUserVerifier Class(How do I define es.properties file to invoke LADPUserVerifier Class)
[EMFStore]: What do I to invoke LADPUserVerifier Class [message #1761218] Tue, 09 May 2017 07:12 Go to next message
Garcia de Mirasierra Perez is currently offline Garcia de Mirasierra PerezFriend
Hello Maximilan and Edgar,
I want to use LADP. In es.propeties file I put:
emfstore.accesscontrol.authentication.policy=ldap
emfstore.accesscontrol.authentication.ldap.1.url=LDAP://ldap.forumsys.com:389/
emfstore.accesscontrol.authentication.ldap.1.base=ou=mathematicians,dc=example,dc=com
When I do debug. I see that invoke to UserVerifierChain.
My question is: What do I do to use LDAPUserVerifier Class.
Many thanks advanced.
Amalia
Re: [EMFStore]: What do I to invoke LADPUserVerifier Class [message #1761367 is a reply to message #1761218] Wed, 10 May 2017 09:06 Go to previous messageGo to next message
Edgar Mueller is currently offline Edgar MuellerFriend
Hi Amalia,
we're looking into this and set-up a test case, we'll keep you posted.
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Edgar Mueller
Re: [EMFStore]: What do I to invoke LADPUserVerifier Class [message #1761369 is a reply to message #1761367] Wed, 10 May 2017 09:20 Go to previous messageGo to next message
Ok, here's the promised test case. In order to access the LDAP server you have to set additional properties in your es.properties file.
The test case tells you which properties you have to set, e.g. 'emfstore.accesscontrol.authentication.ldap.1.authuser' has to be set to 'cn=read-only-admin,dc=example,dc=com', 'emfstore.accesscontrol.authentication.ldap.1.authuser' to 'password' and so on, see the commented parameters in the LDAPUserVerifier constructor.
Hope this helps!
public class LDAPUserVerifierTest extends ESTestWithMockServer {
	@BeforeClass
	public static void beforeClass() {
		startEMFStore();
	@AfterClass
	public static void afterClass() {
		stopEMFStore();
	@Test
	public void ldapVerifyUser() throws AccessControlException {
		final ESOrgUnitRepositoryImpl repository = new ESOrgUnitRepositoryImpl(getServerMock().getServerSpace());
		final ESOrgUnitProvider orgUnitProvider = new ESOrgUnitProviderImpl(repository);
		final LDAPUserVerifier ldapVerifier = new LDAPUserVerifier(
			orgUnitProvider,
			"ldap://ldap.forumsys.com", // url
			"dc=example,dc=com", // base
			"uid", // searchdn
			"cn=read-only-admin,dc=example,dc=com", // authuser
			"password");  // authpass
		assertTrue(ldapVerifier.verifyPassword("gauss", "password"));
Edgar Mueller
Re: [EMFStore]: What do I to invoke LADPUserVerifier Class [message #1761912 is a reply to message #1761369] Thu, 11 May 2017 16:46 Go to previous message
Thank you very much Edgar!!
Previous Topic:[EMFStore]: How do you extend loginService
Next Topic:Cannot create genmodel from valid schema.
Current Time: Sat Jun 06 02:35:05 GMT 2020
Powered by FUDForum. Page generated in 0.01616 seconds
