Home » Eclipse Projects » Jubula » Jubula extension component !(JUBULA Does Not Recognize component in TABPane ( such As Chart , Botton .....))
Jubula extension component ! [message #1761156] Mon, 08 May 2017 10:40 Go to next message
Khemiri Mahran is currently offline Khemiri MahranFriend
Hello ,
I'm Working With Eclipse Testing Neon and I'm New To, I'm Testing A JavaFX Application , When I've Tried To Map Some Componemt Inside A Tabpane , Jubula Doesn't Recognize Them .
I've Read About Extension But It Seems That I Do Not Get Quite Well The Steps.
Can Anyone Help Me With A Demonstration.
Re: Jubula extension component ! [message #1761460 is a reply to message #1761156] Thu, 11 May 2017 10:04 Go to previous message
Marvin Mueller is currently offline Marvin MuellerFriend
Hello Mahran,
There might be different things going on. Either there is a really not supported component, or the container(the tabPane) is not supported as a Container. If you would have used the Jubula Standalone there would also be the possibility that you could try to support the component via SimpleExtension. For more information regarding the complex extension writing see [1]
kind regards
Marvin Mueller
[1] http://help.eclipse.org/neon/index.jsp?topic=%2Forg.eclipse.jubula.client.ua.help%2Fcontent%2Fhtml%2FdeveloperManual%2FtoolkitExtension%2FtoolkitExtension.html&cp=49_2
Previous Topic:Close tab by jubula
Next Topic:Unable to map objects
Current Time: Tue Aug 04 08:56:47 GMT 2020
Powered by FUDForum. Page generated in 0.01476 seconds
