Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » convert ecore to xmi
convert ecore to xmi [message #1761059] Fri, 05 May 2017 19:17 Go to next message
Banafsheh Azizi is currently offline Banafsheh AziziFriend
How can I convert ecore to xmi?
I can rename it with .xmi and open it. but it doesn't really convert to xmi.
Member of MDSE Research Group
http://mdse.ui.ac.ir
Re: convert ecore to xmi [message #1761073 is a reply to message #1761059] Sat, 06 May 2017 05:15 Go to previous messageGo to next message
HI
Do nothing. It is already XMI.
Ed Willink
Re: convert ecore to xmi [message #1761119 is a reply to message #1761073] Sun, 07 May 2017 11:21 Go to previous messageGo to next message
thanks for your reply.
To clarify, I want to have a metamodel as a model. in other words, I want to have a model that is same as its metamodel (with all references,..) and I want to add only values to its class attributes.
Is there any way to help me in this regard?
[Updated on: Sun, 07 May 2017 11:23]
Report message to a moderator
Re: convert ecore to xmi [message #1761120 is a reply to message #1761119] Sun, 07 May 2017 11:47 Go to previous messageGo to next message
Sorry, what you ask makes no sense, Ecore is its own metamodel, but adding only values to class attributes. Beats me.
The general level of your questions suggests that you don't really understand what you are trying to do. I suggest you use Ecore and related tools in conventional ways before attempting what appear to be really odd things. I suspect that you will discover that what you thought you were trying to do is not what you really need to do.
Ed Willink
Re: convert ecore to xmi [message #1763723 is a reply to message #1761120] Fri, 19 May 2017 05:53 Go to previous message
saravanakumar Mohanasundaram is currently offline saravanakumar MohanasundaramFriend
I am not actually understand your case. This may help you.
You can create a xmi for your model itself. Select the root node in your model.
Right click--> create dynamic instance then you will get xmi for your model.
saravanakumar
[Updated on: Fri, 19 May 2017 05:55]
Previous Topic:Cannot create genmodel from valid schema.
Next Topic:Create diagram view of model
Current Time: Thu Feb 25 19:24:00 GMT 2021
Powered by FUDForum. Page generated in 0.02295 seconds
