Home » Eclipse Projects » Virgo » Configuring security context for "/admin"(Is is possible to override the default security without changing the jar?)
icon5.gif  Configuring security context for "/admin" [message #1760981] Thu, 04 May 2017 20:36 Go to next message
Bill Mair is currently offline Bill MairFriend
Member
I would like to change the security configurations of WABs to use SPNEGO and LDAP roles without having to modify their contents.
I'm using "Virgo Server for Apache Tomcat" and I have tried all sorts of files like:
$KERNEL_HOME/configuration/web.xml
$KERNEL_HOME/configuration/context.xml.default
$KERNEL_HOME/configuration/Catalina/localhost/admin.xml
To be honest, I'm not even sure if I even created the files with the right content and the documentation and just about all the examples I could find were about editing the contents of the web.xml in the application being deployed. So after an afternoon of getting nowhere, I thought I'd ask the experts.
How can I set up the security as I need it through configuration and not modification?
P.S. Everything works if I modify the contents of the management console jar (WEB-INF/web.xml) as follows:
Original:
  <security-constraint>
    <web-resource-collection>
      <web-resource-name>Virgo Server Admin Console</web-resource-name>
      <url-pattern>/resources/*</url-pattern>
      <url-pattern>/content/*</url-pattern>
      <url-pattern>/jolokia/*</url-pattern>
      <url-pattern>/upload/*</url-pattern>
    </web-resource-collection>
    <auth-constraint>
      <role-name>admin</role-name>
    </auth-constraint>
  </security-constraint>
  <login-config>
    <auth-method>BASIC</auth-method>
    <realm-name>Virgo Admin Console</realm-name>
  </login-config>
  <security-role>
  </security-role>
Modified:
    <auth-constraint>
      <role-name>Virgo-Administrator</role-name>
      <role-name>Virgo-Operator</role-name>
    </auth-constraint>
  <login-config>
    <auth-method>SPNEGO</auth-method>
  </login-config>
  <security-role>
  </security-role>
  <security-role>
  </security-role>
Re: Configuring security context for "/admin" [message #1761205 is a reply to message #1760981] Mon, 08 May 2017 21:32 Go to previous messageGo to next message
Violeta Georgieva is currently offline Violeta GeorgievaFriend
You should be able to provide your own global web.xml.
I tested this
and it is working.
Did you try to put the configuration above (the one that you changed in WEB-INF/web.xml for management console jar) in the $KERNEL_HOME/configuration/web.xml
What's happening?
Violeta
Re: Configuring security context for "/admin" [message #1761208 is a reply to message #1761205] Mon, 08 May 2017 22:48 Go to previous messageGo to next message
Member
Hi Violeta,
I tried copying the modified web.xml to that location and it didn't work, I still got a BASIC authentication window popping up and some weirdness with JNDIRealm and windows AD.
When I did that it also broke just about all the other WABs that are installed (these are developed in house and they have their own roles and paths).
As I said, I probably got the contents completely wrong, could you please supply the file that you used to test it?
I want to be able to change it on a "per application" basis, so that individual applications can define their own roles and I can override them if they don't fit.
Re: Configuring security context for "/admin" [message #1761213 is a reply to message #1761208] Tue, 09 May 2017 05:40 Go to previous messageGo to next message
Bill Mair wrote on Mon, 08 May 2017 22:48
Then you have to change it as you did for the management console because the global web.xml will be applied to all web bundles.
Violeta
Re: Configuring security context for "/admin" [message #1761229 is a reply to message #1761213] Tue, 09 May 2017 09:03 Go to previous message
Member
I was hoping for something similar to the context configuration but I can live with manually changing the security on the few external jars that are in use.
Thanks for the clarification Violeta.
Previous Topic:Disable recursive jar manifest 'Class-Path' verification
Next Topic:Minor change requested for dmk.sh
Current Time: Tue Mar 31 12:22:55 GMT 2020
Powered by FUDForum. Page generated in 0.02301 seconds
