Home » Modeling » TMF (Xtext) » Strange conflict on xtext grammar
icon9.gif  Strange conflict on xtext grammar [message #1760839] Wed, 03 May 2017 10:20 Go to next message
Hi everyone,
I'm on project that uses xtext grammar to produce a script langage.
I have problem with rules tha should not do conflict, but they do.
Here is a part of my grammar:
Variable:
	name='valeur' |
	(producer=STR '.') ( parameter=STR '.') attribut = VariableAttribut
VariableAttribut:
	name='unité' |
	name='valeur'
GetBit:
	variable=Variable '.getBit' '(' index=INT ')'
TurnBitOn:
	variable=Variable '.allumerBit' '(' index=INT ')'
TurnBitOff:
	variable=Variable '.eteindreBit' '(' index=INT ')'
terminal STR : ('a'..'z'|'A'..'Z'|'_') ('a'..'z'|'A'..'Z'|'0'..'9'|'_'|'\\')*;
Well, the problem is when I type something like this (I expect this to enter "Variable" rule):
valeur=PRODUCTEUR.ENTIER2.valeur;
I get errors:
- no viable alternative at input 'TIER2'
- mismatched character 'N' expecting set null
And I checked it, this is because of "TurnBitOff". i have the same error with parameters starting with "g" and "a".
Do you know why this problem happens ?
Thanks for your answers
Re: Strange conflict on xtext grammar [message #1760840 is a reply to message #1760839] Wed, 03 May 2017 10:30 Go to previous messageGo to next message
can you please share a minimal but complete grammar and unit test?
Re: Strange conflict on xtext grammar [message #1760841 is a reply to message #1760840] Wed, 03 May 2017 10:33 Go to previous messageGo to next message
p.s.
and try to use this pattern:
variable=Variable '.''getBit' '(' index=INT ')'
Re: Strange conflict on xtext grammar [message #1760844 is a reply to message #1760841] Wed, 03 May 2017 10:58 Go to previous messageGo to next message
Thank you very much Christian, it works perfectly !
Is it an xText issue or is there any reason to split the ".getBit" ?
Re: Strange conflict on xtext grammar [message #1760846 is a reply to message #1760844] Wed, 03 May 2017 11:01 Go to previous messageGo to next message
its a problem with how antlr lexers work
Re: Strange conflict on xtext grammar [message #1760847 is a reply to message #1760846] Wed, 03 May 2017 11:06 Go to previous message
Ok.
Thank you again !
Previous Topic:Parsing Problem: Colon and negative number
Next Topic:Exception when accessing xtext index
Current Time: Sat Nov 08 01:05:57 EST 2025
Powered by FUDForum. Page generated in 0.04525 seconds
