Home » Newcomers » Newcomers » Eclipse Neon (Windows 7/10)(Package Tree / Font Size)
Eclipse Neon (Windows 7/10) [message #1760786] Tue, 02 May 2017 18:47
I see this enough, that I thought it prudent to post my findings and maybe save someone else the grief in the future.
If you wish to change the font and size of the Package Explorer in Windows7/10, while using Eclipse Neon, the location of the format CSS sheet isn't where one might expect to find it (I seem to recall it was in .eclipse before?).
It's located in: \Users\<USERNAME>\.p2\pool\plugins\org.eclipse.ui.themes_<VERSION>\css
In here, you will find the, what I believe might be the cached version of the style sheets that Eclipse uses. (It appears it expands them from packaged jars at first run, so if they're missing, run eclipse first)
You can check which theme you are using by looking in Window -> Preferences -> General -> Appearance within Eclipse Neon
You can either edit your particular theme file you have selected, which by default on Windows7/10 should be: e4_default_win7.css
Or you can edit the base file which all the e4 themes will inherit, named: e4_basestyle.css
At the end of either of these files, simply add the lines:
#org-eclipse-jdt-ui-PackageExplorer Tree,
#org-eclipse-ui-navigator-ProjectExplorer Tree {
    font-size: 10px; /* <-- Desired font size */
    font: Consolas;  /* <-- Font you want to have */
You can independently write these css classes out to your liking, or leave them grouped as is. Both the parameters font-size and font, are of course optional.
[Updated on: Thu, 04 May 2017 04:08] by Moderator
Previous Topic:Java Eclipse Apps use Lucida Grande instead of SF (only my Mac)
Next Topic:Papyrus and neon.3
Current Time: Sun Apr 20 03:49:45 EDT 2025
Powered by FUDForum. Page generated in 0.07429 seconds
