Re: How about Charts? [message #1760829 is a reply to message #1760804] |
Wed, 03 May 2017 12:37 |
R. van Twisk Messages: 12 Registered: April 2017 |
Hey Mattias,
I am trying to follow that code, but I might be missing a piece of magic:
I created : src/main/js/chart-module.js
(function(scout, $, undefined) {
__include("chart/Chart.bundle.min.js");
__include("chart/ChartField.js");
__include("chart/ChartAdapter.js");
__include("chart/ChartFieldLayout.js");
}(scout, jQuery));
But I am getting : [nio-8080-exec-5] o.e.s.r.u.html.script.ScriptFileLocator : locate /res/chart-module.js: does not exist (no library, macro or source module)
And I am seeing in application-all.js
// --- /res/chart-module.js ---
// !!! NOT PROCESSED
This makes sense, because by default src/main/js isn't getting bundled (as far as I know).
So I moved it to src/main/resources/WebContent/res
and I see in application-all.js that the file is included, but then I get a javascript error :
// --- LIBRARY /res/chart-module.js ---
__include("chart/Chart.bundle.min.js"); // <== ReferenceError: Can't find variable: __include
}(scout, jQuery));
I also did a fresh clone from : https://github.com/BSI-Business-Systems-Integration-AG/SpringBoot-and-EclipseScout/tree/6.1.x/org.eclipse.scout.springboot
Ran the application and I also get in the log:
2017-05-03 14:35:05.487 WARN 71454 --- [nio-8080-exec-4] o.e.s.r.u.html.script.ScriptFileLocator : locate /res/spring-security-module.less: does not exist (no library, macro or source module)
2017-05-03 14:35:05.528 WARN 71454 --- [nio-8080-exec-6] o.e.s.r.u.html.script.ScriptFileLocator : locate /res/spring-security-module.js: does not exist (no library, macro or source module)
Any help would be greatly appreciated.
Ries
Re: How about Charts? [message #1760885 is a reply to message #1760881] |
Thu, 04 May 2017 06:37 |
> Does scout handle exact widget calculations and positioning or is this CSS based?
It's a bit of both. Most of the widgets in Scout's Html UI are laid out by JavaScript. The layouting concept is similar to Java Swing. Each "scout.Widget" has a root DOM element (the $container) which is attached to an instance of "scout.HtmlComponent" which has an instance of "scout.AbstractLayout". This class is responsible for calculating and returning the preferred size of the widget and to layout the widget when the size of its parent is set. Once the correct size is set on the root element of a Scout widget, the widget can layout its content with CSS positioning or with absolute positioning done by JavaScript code in the layout method.
To calculate the "preferred size" of a widget we rely (most of the time) on what the browser renders including CSS styles. A very simple layout is the "scout.SingleLayout" class. It is used in places where a DOM element has only one child element and the size of that child element should be equals to the parent size.
However: when you're working with Scout Forms, you usually work with GroupBoxes and FormFields. Thus your custom widget should probably be a sub class of scout.FormField which has a FormFieldLayout. Each form field has a label, a mandatory indicator, a status and the field itself (which in your case, would be the Chart).
Depending on how your Chart library works (maybe you have to call a library specific function whenever the size of the parent of the Chart changes), you should create a ChartFormFieldLayout.js, which deals with the specific layout requirements of the Chart.
I guess the HeatmapFieldLayout.js is a good example for that. As you see in that class the Heatmap library requires we call an 'invalidateSize' function whenever the size of the parent changes. If we didn't call that function we'd probably see similar issues as you currently have with your Chart in 1EBA8CD4.png.
Eclipse Scout Homepage | Documentation | GitHub
Re: How about Charts? [message #1760932 is a reply to message #1760885] |
Thu, 04 May 2017 12:25 |
Andre,
thank's for thanks extensive and quick answer. I indeed use the heatmap as my base, and started to modify it for my learning experience.
Instead of the Hello World, I used the Scout + Spring Boot tool, here is my repository I am fooling around with : https://github.com/rvt/SpringBoot-and-EclipseScout
Today I am going to play with it some more and see how it goes.
Ries
Update: It works! I had to set getConfiguredGridH and returned 6 for both of the form fields (table and Chart). I am not sure if this is considered a hack or not....
[Updated on: Thu, 04 May 2017 13:27] Report message to a moderator
Re: How about Charts? [message #1793806 is a reply to message #1793775] |
Thu, 16 August 2018 07:07 |
Oueslati Anis wrote on Wed, 15 August 2018 10:09Hello
I created my project and followed the sample you made and I am facing an issue with size of the chart that I do not know how to solve it, please take a look on this
how to fix this ?
Looks like a layouting issue. Please check the following things:
1. Is your form field configured correctly, i.e. does it have a "getConfiguredGridH" value greater than 1? Otherwise the layouter will not stretch the field to fill the entire form.
2. Does your JS widget set a "layout" and is this layout implemented correctly? In the _render() method of your field, somewhere there should be a line similar to this:
... htmlComp.setLayout(new myproject.MyFieldLayout(this));...
In the corresponding "MyFieldLayout.js" there should be a _layout() method. This method is called whenever the size of the parent element is known and the inner element can now be layouted.
Have a look at the example HeatMapFieldLayout.js. In the _layout() method, this.field.heatmap.invalidateSize() is called. This causes the leaflet library to correctly use the available space. Your chart library probably has a similar method.
Beat
FUDForum. Page generated in 0.04473 seconds
