Home » Eclipse Projects » Remote Application Platform (RAP) » How to terminate the UI thread(As we all know, in RAP application, the UI thread will be created after user login successfully, when refresh the browser, a new UI thread will be created, this will cause DOS due to high usage of CPU)
How to terminate the UI thread [message #1760631] Sat, 29 April 2017 04:00 Go to next message
Hi all,
As we all know, in RAP application, the UI Thread will be created after user login successfully, this is Daemon Thread.
But a new UI Thread will be created when user refresh the browser.
If the hacker send many time requests, it will create many UI Threads and will cause DOS due to high usage of CPU and memory.
Re: How to terminate the UI thread [message #1760652 is a reply to message #1760631] Sun, 30 April 2017 05:58 Go to previous messageGo to next message
There are many ways to terminate the UIThread:
Expire the HTTP session.
Remove the UISession from the HTTP session.
Let the EntryPoint#createUI method finish
Throw a ThreadDeath exception in the UIThread
I'm sure there's more but that's just off the top of my head
Re: How to terminate the UI thread [message #1760695 is a reply to message #1760652] Tue, 02 May 2017 02:30 Go to previous message
Thanks for your reply.
I have found the reason, when refresh the browser, cid which UI session depends on will change, and cid generate from _generateConnectionId function of client.js. I think I can control the cid on server side to make sure unique value per session.
My Rap version is 2.2.0.
Thanks again.
Previous Topic:Browser.setUrl() creates duplicate requests
Next Topic:Where to post demo code?
Current Time: Sat Nov 08 13:22:04 EST 2025
Powered by FUDForum. Page generated in 0.03907 seconds
