Home » Newcomers » Newcomers » 'Updating Software' has encountered a problem.(Just tried to do an update and got a bunch of errors.)
'Updating Software' has encountered a problem. [message #1760076] Fri, 21 April 2017 20:46 Go to next message
Chuck Pergiel is currently offline Chuck PergielFriend
This is what the update box showed.
An error occurred while collecting iterms to be installed
When I asked for details it gave me a list of a zillion lines like this:
An error occurred while collecting items to be installed
session context was:(profile=_home_c_eclipse_cpp-neon_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.cdt,9.2.1.201704050430
No repository found containing: osgi.bundle,org.eclipse.cdt.autotools.core,2.0.0.201704050430
No repository found containing: osgi.bundle,org.eclipse.cdt.autotools.docs,2.0.2.201704050430
Sent from my Commodore-64 via a US Robotics 300 Baud Modem
Re: 'Updating Software' has encountered a problem. [message #1760086 is a reply to message #1760076] Sat, 22 April 2017 06:39 Go to previous messageGo to next message
There could have been a network failure.
Re: 'Updating Software' has encountered a problem. [message #1760097 is a reply to message #1760086] Sat, 22 April 2017 13:37 Go to previous messageGo to next message
If there was a network failure, it's not on my end. I just ran an update on Linux and it worked fine. Then I tried to update Eclipse again and I got the same error as before.
Re: 'Updating Software' has encountered a problem. [message #1760133 is a reply to message #1760097] Sun, 23 April 2017 15:41 Go to previous messageGo to next message
Maybe there are more clues in the Error Log?
Re: 'Updating Software' has encountered a problem. [message #1760135 is a reply to message #1760133] Sun, 23 April 2017 16:05 Go to previous messageGo to next message
Error Log? Where is the Error Log?
Re: 'Updating Software' has encountered a problem. [message #1760137 is a reply to message #1760135] Sun, 23 April 2017 16:09 Go to previous messageGo to next message
Type Error Log in the Quick Access to open the Error Log view.
Re: 'Updating Software' has encountered a problem. [message #1760138 is a reply to message #1760137] Sun, 23 April 2017 16:29 Go to previous messageGo to next message
Most of today's entries in the Error Log are the same as above. I did find these four items from Friday at 2:30PM, which was like 9 hours before I tried to do the update.
Unknown Host: http://download.eclipse.org/oomph/updates/milestone/latest/compositeContent.xml
Unknown Host: http://download.eclipse.org/tools/cdt/releases/9.2/compositeContent.xml
Unknown Host: http://download.eclipse.org/eclipse/updates/4.6/compositeContent.xml
Unknown Host: http://download.eclipse.org/releases/neon/compositeContent.xml
The event details for all four of these are identical, except for the URL.
eclipse.buildId=4.6.3.M20170301-0400
java.version=1.8.0_121
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.epp.package.cpp.product
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.cpp.product
org.eclipse.equinox.p2.transport.ecf
Error
Fri Apr 21 14:29:07 PDT 2017
java.net.UnknownHostException: download.eclipse.org
at java.net.InetAddress.getAllByName0(InetAddress.java:1280)
at java.net.InetAddress.getAllByName(InetAddress.java:1192)
at java.net.InetAddress.getAllByName(InetAddress.java:1126)
at org.apache.http.impl.conn.SystemDefaultDnsResolver.resolve(SystemDefaultDnsResolver.java:44)
at org.apache.http.impl.conn.DefaultClientConnectionOperator.resolveHostname(DefaultClientConnectionOperator.java:259)
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:159)
at org.apache.http.impl.conn.ManagedClientConnectionImpl.open(ManagedClientConnectionImpl.java:304)
at org.apache.http.impl.client.DefaultRequestDirector.tryConnect(DefaultRequestDirector.java:611)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:446)
at org.apache.http.impl.client.AbstractHttpClient.doExecute(AbstractHttpClient.java:863)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82)
at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:263)
at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69)
Re: 'Updating Software' has encountered a problem. [message #1760157 is a reply to message #1760138] Mon, 24 April 2017 06:11 Go to previous messageGo to next message
These logs entries suggest network problems, at least at that point in time. You could clear the log, try again, and see what's all in the log. I'm not sure what else to suggest. Perhaps there is some inconsistency in CDT's update sites. You might try using Windows -> Preferences -> Install/Update -> Available Software Sites and disabling the CDT one; CDT should be in the Neon repository anyway.
Re: 'Updating Software' has encountered a problem. [message #1760182 is a reply to message #1760157] Mon, 24 April 2017 11:37 Go to previous messageGo to next message
Tauno Voipio is currently offline Tauno VoipioFriend
There might be something fishy in the links or Eclipse repository.
When used as browser URL's, only the CDT link got a XML page, the other three gave the Eclipse project 'Not found' page.
Tauno Voipio
Re: 'Updating Software' has encountered a problem. [message #1806532 is a reply to message #1760182] Fri, 10 May 2019 08:48 Go to previous messageGo to next message
Wojciech Lisik is currently offline Wojciech LisikFriend
I strongly suggest closing down Eclipse as this bug (its a BUG) is still relevant 2 years on.....
It clearly shows that developers give a middle finger to it. Either because they don't have a clue what's going on, or they don't care....
Re: 'Updating Software' has encountered a problem. [message #1806570 is a reply to message #1806532] Fri, 10 May 2019 13:36 Go to previous message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Is it? You've reopened a two year old thread about an outdated release without adding any other information.
Nitin Dahyabhai
Eclipse Web Tools Platform
Previous Topic:Java Exit Code - 1
Next Topic:Where is the correct place to add a trusted certificate on Linux?
Current Time: Sun Aug 25 07:41:19 GMT 2019
Powered by FUDForum. Page generated in 0.03675 seconds
