Home » Modeling » TMF (Xtext) » XText category not available on update site(Installation trouble)
icon11.gif  XText category not available on update site [message #1760035] Fri, 21 April 2017 12:04 Go to next message
Arend Rensink is currently offline Arend RensinkFriend
I neext XText 2.7.3 as a prerequisite for another plugin. When I add the update site suggested on https://eclipse.org/Xtext/download.html into the "Install New Software" dialog, XText is not among the selectable categories, in contrast to what is stated in the Installation Instructions. I'd very much appreciate a hint on how I can get XText 2.7.3 installed.
Just in case it matters: I'm using Neon 3.
--Arend
Re: XText category not available on update site [message #1760038 is a reply to message #1760035] Fri, 21 April 2017 12:10 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
i cant follow you on this this. (sure you delected show latest version only?) ntl xtext 2.7.3 is here http://download.eclipse.org/modeling/tmf/xtext/updates/releases/maintenance/R201411190455/
Twitter : @chrdietrich
Re: XText category not available on update site [message #1760039 is a reply to message #1760035] Fri, 21 April 2017 12:10 Go to previous messageGo to next message
At a second attempt (after closing and restarting Eclipse) I got a different result that does include XText, including the required version. Problem solved already!
Re: XText category not available on update site [message #1760175 is a reply to message #1760038] Mon, 24 April 2017 09:41 Go to previous message
Thanks a lot for your reply. I probably got a timeout first time around, because the XText category didn't appear at all. Topic closed, AFAIAC.
Previous Topic:Launch Runtime Eclipse run configuration unreliable?
Next Topic:EObject 'nature' of domain classes no longer available?
Current Time: Tue Apr 16 16:07:03 GMT 2024
Powered by FUDForum. Page generated in 0.16758 seconds
