Home » Modeling » TMF (Xtext) » Reduce available JvmTypes
Reduce available JvmTypes [message #1759730] Mon, 17 April 2017 18:54 Go to next message
Marco Ullrich is currently offline Marco UllrichFriend
Hello everyone,
i am currently writing a beginner friendly OO-Language based on Xbase.
I decided to use Xbase for this purpose, hence most of my DSL concepts can easily be mapped to Java and it ships with a lot of nice features (like debugging).
My problem is, that Xbase provides too many types (e.g. StringBuilder etc...), which can be quiet overwhelming for beginners.
I only want to provide some primitive types (like int, String, boolean and double) and some datastructures like arrays and lists (and user-defined classes of course).
I tried to override the different Xbase grammarrules to achieve this, e.g:
JvmParameterizedTypeReference:
type=[JvmPrimitiveType] ;
But with no luck. : /
So my question is: How can i reduce the amount of available JvmTypes?
Where should i start / what is the best approach for that?
Thanks in advance and kind regards,
Marco
Re: Reduce available JvmTypes [message #1759790 is a reply to message #1759730] Tue, 18 April 2017 06:22 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
I think you should make use of some filtering of the proposals e.g. as in https://kthoms.wordpress.com/2012/03/14/how-to-limit-proposed-java-types-to-implementors-of-an-interface/
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Reduce available JvmTypes [message #1759819 is a reply to message #1759730] Tue, 18 April 2017 08:47 Go to previous messageGo to next message
Karsten Thoms is currently offline Karsten ThomsFriend
You can also restrict the types with JDT Type Filters preference setting. That does not require any customization, just preference configuration.
Re: Reduce available JvmTypes [message #1759829 is a reply to message #1759819] Tue, 18 April 2017 17:31 Go to previous messageGo to next message
Hello Christian and Karsten,
thank you for your fast reply!
I tried your approaches and they work well for the proposed types, but it wont prevent a user from using/writing types like StringBuilder in a program.
Is there a way to only allow the mentioned primitive types and collections on a grammar level?
Kind regards,
Marco
Re: Reduce available JvmTypes [message #1759830 is a reply to message #1759829] Tue, 18 April 2017 17:39 Go to previous messageGo to next message
That would be scoping not grammar
(See XbaseBatchScopeProvider for entry point
And
IJvmTypeProvider)
Re: Reduce available JvmTypes [message #1759897 is a reply to message #1759829] Wed, 19 April 2017 08:10 Go to previous messageGo to next message
Right. I would wrap the scope with a FilteringScope and only accept allowed types.
Re: Reduce available JvmTypes [message #1759911 is a reply to message #1759730] Wed, 19 April 2017 20:12 Go to previous messageGo to next message
Thank you both for your support, now I am back on track. Smile
I decided to extend and customize the JdtTypeProvider, hence it should only provide some types.
Now I have one question left:
The scope provider now uses my implementation of the type provider but all types are still proposed.
I thought the proposals were build depending on the content of of the scope, aren't they?
As a workaround, i could customize the proposals as mentioned in Karstens blog, but I wonder why it still proposes all types....
Here my solution so far ,just in case someone else has the same problem / requirement:
In the UI-Plugin add a factory...
@Singleton
class MyFilteredJdtTypeProviderFactory extends JdtTypeProviderFactory {
	@Inject
	IWorkingCopyOwnerProvider copyOwnerProvider;
	@Inject
	TypeResourceServices typeResourceServices;
	override protected IJdtTypeProvider createJdtTypeProvider(IJavaProject javaProject, ResourceSet resourceSet) {
		if (javaProject == null){
			return new NullJdtTypeProvider(resourceSet)
		var WorkingCopyOwner wco= null
		if(copyOwnerProvider==null)
			wco = DefaultWorkingCopyOwner.PRIMARY
		else
			wco = copyOwnerProvider.getWorkingCopyOwner(javaProject, resourceSet)
		return new MyFilteredJdtTypeProvider(javaProject, resourceSet, getIndexedJvmTypeAccess(), wco, typeResourceServices);
...and the provider...
class MyFilteredJdtTypeProvider extends JdtTypeProvider {
	public new(IJavaProject javaProject, ResourceSet resourceSet, IndexedJvmTypeAccess indexedJvmTypeAccess, WorkingCopyOwner workingCopyOwner, TypeResourceServices services) {
		super(javaProject, resourceSet, indexedJvmTypeAccess, workingCopyOwner, services)
	private val HashSet<String> supportedJdtTypes ={
		val hs = new HashSet()
		hs.add("int")
		hs.add("double")
		hs.add("boolean")
		hs.add("java.lang.String")
               // Required by the compiler to process method bodys right
                hs.add("void")
		// Required, otherwise operators do not work
		hs.add("org.eclipse.xtext.xbase.lib.StringExtensions")
		hs.add("org.eclipse.xtext.xbase.lib.IntegerExtensions")
		hs.add("org.eclipse.xtext.xbase.lib.DoubleExtensions")
		hs.add("org.eclipse.xtext.xbase.lib.BooleanExtensions")
		return hs
	public override JvmType findTypeByName(String name) {
		if(name.isTypeSupported){
			return doFindTypeByName(name, false)
		}else{
			return null
	public override JvmType findTypeByName(String name, boolean binaryNestedTypeDelimiter) {
			return super.findTypeByName(name,binaryNestedTypeDelimiter)
		}else{
			return null
	def isTypeSupported(String name){
		supportedJdtTypes.contains(name)
... and tell the framework (in UiModule.xtend) to use our factory instead of its default impl:
	override Class<? extends IJvmTypeProvider.Factory> bindIJvmTypeProvider$Factory() {
		return MyFilteredJdtTypeProviderFactory;
[Updated on: Thu, 20 April 2017 18:38]
Report message to a moderator
Re: Reduce available JvmTypes [message #1759914 is a reply to message #1759911] Wed, 19 April 2017 20:51 Go to previous messageGo to next message
No they are not. There is an exception for jvm types regard scope = content assist thus my first hint on ca filtering
Re: Reduce available JvmTypes [message #1759948 is a reply to message #1759730] Thu, 20 April 2017 10:01 Go to previous message
Okay, I See, thanks again. Smile
In case someone should be interested, this is my approach (iam filtering the types of the ITypesProposalProvider / JdtTypesProposalProvider):
class MyDslProposalProvider extends AbstractExpressionsProposalProvider {
    override protected completeJavaTypes(ContentAssistContext context, EReference reference, boolean forced,IValueConverter<String> valueConverter, ITypesProposalProvider.Filter filter,ICompletionProposalAcceptor acceptor) {
		val extendedFilter = TypeMatchFilters.and(filter,new SupportedTypesFilter())
		super.completeJavaTypes(context, reference, forced, valueConverter, extendedFilter, acceptor)
	private static class SupportedTypesFilter extends AbstractFilter {
		override boolean accept(int modifiers, char[] packageName, char[] simpleTypeName,char[][] enclosingTypeNames, String path) {
			// Add further predicates to filter for java types here
			packageName.join.equals("java.lang")&& simpleTypeName.join.equals("String")
Previous Topic:Is it possible to call @Check method only once in validation
Next Topic:Active Annotation Concept in a XBase and JvmModel based DSL
Current Time: Sun Oct 24 20:03:15 GMT 2021
Powered by FUDForum. Page generated in 0.02451 seconds
