Home » Eclipse Projects » OM2M » raspberry as gateway
raspberry as gateway [message #1759690] Sat, 15 April 2017 20:11 Go to next message
valentina vv95 is currently offline valentina vv95Friend
i want to use Raspberry pi with sensor as gateway. I want to send the data from sensor on server. Should I create om2m application or new plugin?
And do I create application on gateway or server?
I could't find tutorial for this, so if you have it please send me.
Thank you
Re: raspberry as gateway [message #1760236 is a reply to message #1759690] Tue, 25 April 2017 02:08 Go to previous messageGo to next message
Fariz Alemuda is currently offline Fariz AlemudaFriend
Hi Valentina,
You better create an application.
Thank you.
Re: raspberry as gateway [message #1760408 is a reply to message #1760236] Wed, 26 April 2017 18:07 Go to previous messageGo to next message
Thank you!
Can you also please explain me how to make connection between gateway and server. I would like to use COAP, but I'm confused what should I do on gateway and what on server.
Thank you.
Valentina
Re: raspberry as gateway [message #1775247 is a reply to message #1760408] Thu, 26 October 2017 17:45 Go to previous message
Umar Farooq is currently offline Umar FarooqFriend
Hi Valentina,
were you able to figure how to communicate between the raspberry pi and server? Can you tell me which language did you end up using?
Umar
Previous Topic:om2m and Iot
Next Topic:MQTT Server Authorization (request/response topic)
Current Time: Wed Aug 17 16:40:18 GMT 2022
Powered by FUDForum. Page generated in 0.02103 seconds
