Import Ecore packages into EVL [message #1759555] |
Thu, 13 April 2017 00:47 |
Sara Rosa Messages: 24 Registered: March 2017 |
Hi all,
I'm adding extra metamodel validation with EVL, however, I'm trying to reach an EPackage that is inside the main EPackage Ecore but nothing seems to work.
How can I reach the ContextModeling EPackage (for example)? Should I import that EPackage into the EVL file? If yes, how can I do that?
Thank you for your help,
Sara
Attachment: EVLCM.png
(Size: 18.23KB, Downloaded 185 times)
[Updated on: Thu, 13 April 2017 00:49] Report message to a moderator
Re: Import Ecore packages into EVL [message #1759598 is a reply to message #1759583] |
Thu, 13 April 2017 16:21 |
Hi Sara,
This appears to be a bug in the EVL-EMF integration, which assumes that all elements in a model are instances of EClasses that belong to the same EPackage. We'll try to fix this [1] but, as mentioned in a previous message, you're likely to find out that there are other cases where EMF-based tools don't play well with sub-packages so my recommendation would be to consider flattening your metamodel.
Dimitris
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=515262
Re: Import Ecore packages into EVL [message #1759638 is a reply to message #1759606] |
Fri, 14 April 2017 10:34 |
Hi Sara,
Sure - feel free to add yourself to the CC list of the bug to receive updates. If this is a blocker for your work, I would recommend considering the proposed workaround as it's unlikely that we'll be able to look at this within the next few weeks, due to other commitments.
Dimitris
FUDForum. Page generated in 0.04609 seconds
