Home » Modeling » OCL » Programmatical creation(Building OCL constraints from Java)
Programmatical creation [message #1759430] Tue, 11 April 2017 16:16 Go to next message
Edoaurd Batot is currently offline Edoaurd BatotFriend
Member
In order to modify OCL ASTs I would like to create an OperationCallExp to replace one I don't like (with(in) reason). I want to instantiate an "oclIsTypeOF" operation.
Creating the OperationCallExp object is made easy thanks the EcoreFactory, and modifying its fields is straight forward using Ecore eSetters. Plugin a source, changing operation code is ok.
Troubles to perform the creation happen when I try to instantiate an EOperation to fill the referredOperation field. I've tried many ways, investigated in the Ecore code and documentation, but I can't make it.
Do you have any hint where to look for in the documentation and/or code and/or test code to instantiate such EOperation from scratch (I mean, no parsing) ?
Thank you,
Edouard
[Updated on: Tue, 11 April 2017 16:19]
Report message to a moderator
Re: Programmatical creation [message #1759436 is a reply to message #1759430] Tue, 11 April 2017 16:39 Go to previous messageGo to next message
H
See your reply on the start/end thread.
Programmatically, IIRC there is an additionalOperations capability to register alien operations. Search the JUnit tests for an example. I never understood them, but did realize that they could not be serialized to XMI. Hence the Pivot OCL uses true models that can have true XMI references.
Ed Willink
Re: Programmatical creation [message #1759440 is a reply to message #1759436] Tue, 11 April 2017 17:35 Go to previous message
Member
Alien ?
I'm modifying OCL within its own boundaries. Operations I want to (re)create are OCL operations : "oclIsTypeOf", "=", "<>", etc.
Previous Topic:How to derive a collection of objects
Next Topic:Start/End position
Current Time: Wed Jan 20 13:46:57 GMT 2021
Powered by FUDForum. Page generated in 0.01542 seconds
