Home » Eclipse Projects » OM2M » waspmote on xbee
icon5.gif  waspmote on xbee [message #1759266] Sun, 09 April 2017 06:49 Go to next message
valentina vv95 is currently offline valentina vv95Friend
Hy,
How can I connect my temperature sensor on Waspmote with oM2M platform? I get the data through xbee devices on my computer.
Thank you,
Valentina
Re: waspmote on xbee [message #1759306 is a reply to message #1759266] Mon, 10 April 2017 12:37 Go to previous messageGo to next message
Mahdi Ben Alaya is currently offline Mahdi Ben AlayaFriend
You can simply send the data from your computer to a oneM2M node using HTTP, CoAP or MQTT APIs.
Mahdi
Re: waspmote on xbee [message #1760132 is a reply to message #1759306] Sun, 23 April 2017 15:38 Go to previous message
Hi Mahdi,
thank you for answer.
I have still one question, if I wanted to send data from gateway on OM2M server how you recomend to create HTTP or COAP client on gateway?
Can I also use OM2M platform for this, or just create a simple client application or use postman? I'm confused how to connect my gateway with server.
If I'm using postman is it necessary to change configuration?
Thank you,
Valentina
Previous Topic:OM2M :Method Not Allowed Update on ContentInstance is not Allowed
Next Topic:CoAP tutorial
Current Time: Mon Jan 20 13:08:59 GMT 2020
Powered by FUDForum. Page generated in 0.02082 seconds
