Home » Eclipse Projects » Eclipse 4 » MPart close by tab gotcha(application model still contains MPart)
MPart close by tab gotcha [message #1758901] Tue, 04 April 2017 11:44 Go to next message
Jay Norwood is currently offline Jay NorwoodFriend
I found if you close an MPart using the x in its partstack tab, that the MPart still exists in the application model.
My solution was to add a parService.hidePart in the closed class. Perhaps there is another solution?
@Inject
MPart myPart;
@Inject
EPartService partService;
@PreDestroy
public void dispose() {
partService.hidePart(myPart, true);
Re: MPart close by tab gotcha [message #1758903 is a reply to message #1758901] Tue, 04 April 2017 11:58 Go to previous messageGo to next message
Christoph Keimel is currently offline Christoph KeimelFriend
AFAIK you can add the Tag "removeOnHide" to the part so that it will be removed from the application model when closed.
Re: MPart close by tab gotcha [message #1759075 is a reply to message #1758903] Wed, 05 April 2017 22:12 Go to previous message
ok, thanks, I'll give that a try.
Previous Topic:EventBus cannot be resolved to a type
Next Topic:Install New Software
Current Time: Mon Oct 19 22:16:23 GMT 2020
Powered by FUDForum. Page generated in 0.02077 seconds
