Home » Eclipse Projects » Plugin Development Environment (PDE) » Eclipse editor is not becomes dirty when I change the text(Eclipse plug-in, TextEditor)
Eclipse editor is not becomes dirty when I change the text [message #1758620] Thu, 30 March 2017 15:41 Go to next message
kozhaev Vladimir is currently offline kozhaev VladimirFriend
Hi All, now I'm working on the eclipse plug-in. Now I working of the editor extended from org.eclipse.ui.editors.text.TextEditor
And there is following code of marking the editor of dirty when something is changed
public class MyEditor extends TextEditor {
	public boolean isDirty() {
		return mIsDirty;
        @Override public void createPartControl(Composite pParent) {
        mDocumentUndoManager = DocumentUndoManagerRegistry.getDocumentUndoManager(getSourceViewer().getDocument());
		OperationHistoryFactory.getOperationHistory().addOperationHistoryListener(e -> {
			if (e.getOperation().hasContext(mDocumentUndoManager.getUndoContext())) {
				// if there is no more operation to undo
				if (!OperationHistoryFactory.getOperationHistory().canUndo(mDocumentUndoManager.getUndoContext())) {
					mIsDirty = false;
				} else {
					mIsDirty = true;
				firePropertyChange(IEditorPart.PROP_DIRTY);
Listener and isDirty method are called when I make the changes of text in the editor, but my Editor not marked as dirty, also I can't undo the changes.
May I ask to give me some ideas, where can be problem?
Vladimir
Re: Eclipse editor is not becomes dirty when I change the text [message #1763621 is a reply to message #1758620] Thu, 18 May 2017 05:37 Go to previous message
saravanakumar Mohanasundaram is currently offline saravanakumar MohanasundaramFriend
Hi Vladimir,
I think this will help you : https://www.eclipse.org/forums/index.php/t/101048/
Check this : http://www.wideskills.com/eclipse-plugin-tutorial/eclipse-plugin-editors-tutorial
[Updated on: Thu, 18 May 2017 05:49]
Report message to a moderator
Previous Topic:how to add user login function into eclipse by plug-in development
Next Topic:Textmarker overwrites style information in the Editor
Current Time: Sun Jan 24 14:06:15 GMT 2021
Powered by FUDForum. Page generated in 0.02362 seconds
