Datetime mapping on SQLite data source [message #1758579] |
Thu, 30 March 2017 09:27 |
Roberto Palermo Messages: 9 Registered: March 2017 |
Dear all,
I'm trying to use Eclipse Link in order to read a provided (the schema is not editable by me) SQLite data source, but I'm in trouble with date management.
In particular I have a field with "datetime" format, I tried to map in on Java entity with the type Date:
@Temporal(TemporalType.TIMESTAMP)
@Column(name="record_datetime", nullable=false)
protected Date record_datetime;
but in this way the date is not parsed correctly, for example if in the DB the value is
"2017-03-13 11:21:16.606005"
I receive instead the value:
"Mon Mar 13 11:31:22 CET 2017"
In addition, when I try to create a TypedQuery based on this field, for example:
DateFormat df = new SimpleDateFormat("yyyy-MM-dd hh:mm:ss.SSS");
Date dateFrom = df.parse("2017-03-13 11:21:16.847");
List< TableRecord > values = new ArrayList< TableRecord >();
TypedQuery<JPATableEntity> typedQuery = entityManager.createQuery("SELECT t FROM table t WHERE t.record_datetime >= :tsFrom", JPATableEntity.class);
typedQuery.setParameter("tsFrom", dateFrom);
for (TableRecord t : typedQuery.getResultList())
values.add(t);
it returns all records of table without filtering.
I think that the problem may be related to the fact that the "datetime" in the table is in the format "yyyy-MM-dd hh:mm:ss.SSSSSS" and it is wrongly parsed as "yyyy-MM-dd hh:mm:ss.SSS", could it be?
In any case what is the correct way to map the SQLite type "datetime" in Java using EclipseLink?
Many thanks in advance for your help.
FUDForum. Page generated in 0.01970 seconds
