Home » Eclipse Projects » Gendoc » element first occurence page number
element first occurence page number [message #1758509] Wed, 29 March 2017 09:11 Go to next message
Hi experts !
I need to refer in my generated document the page number of some elements where they appear for the first time (they can appear multiple times in the document)
For example, en element 'X' appears the first time on the second page of the generated document. I want to display this page number everytime this element 'X' reappear elsewhere in the document
Is it possible to do this ? Or is it possible to store the page number of the first occurence of each element somewhere and use it during the generation to create the link?
Re: element first occurence page number [message #1758583 is a reply to message #1758509] Thu, 30 March 2017 05:52 Go to previous messageGo to next message
Hi!
What you can do,it is setup a bookmark when the element appears the first time, named with the id of the element. You can see how the gendoc handle the bookmarks, and then create a cross reference, Reference Type: Bookmark; Reference To: page number and choose the bookmark you have created.
Then you display the field codes (Toggle Field codes) and change the bookmark to the acceleo query where you get the id of the element.
I think that will do the trick,
Antonio
Re: element first occurence page number [message #1759380 is a reply to message #1758583] Mon, 10 April 2017 19:01 Go to previous messageGo to next message
Sorry for the delay, i was on vacation.
Thanks a lot for your reply, i'm going to try your solution.
I'll let you know if it works.
[Updated on: Mon, 10 April 2017 19:02] by Moderator
Re: element first occurence page number [message #1759633 is a reply to message #1759380] Fri, 14 April 2017 04:31 Go to previous messageGo to next message
hi,
i have a problem. I know what to do but i don't know how and not sure if it's even possible to do.
In order to create a bookmark only once (the first time the element appears), i need to set a variable ( for instance from '0' to '1'). In fact, i call a fragment in which i display my element, and this fragment is called many times in my document; i tried to use [let] expression with a counter variable but every time the fragment is called, the counter variable is set back to '0'. So, the bookmark is created more that once.
Is there a way to define a variable outside so that it wouldn't be overwrite with 0 each time ?
An other thing i would like to know: Is there possible in gendoc to call an external service (a java method i.e) ?
ps: Sorry for my bad english
Geoffrey
Re: element first occurence page number [message #1759646 is a reply to message #1759633] Fri, 14 April 2017 08:38 Go to previous messageGo to next message
Hello
indeed fragments is not used for queries
It would be nice to use gGet and gPut but Acceleo caches the result of the queries and it would not allow you to get incremented values
maybe indeed you can use a java service to get the value, explanation to create a java service
you can check for existing code to see how it works http://git.eclipse.org/c/gendoc/org.eclipse.gendoc.git/tree/plugins/org.eclipse.gendoc.bundle.acceleo.papyrus
feel free to ask questions if you are new to eclipse plugin development
To share value across several execution you can use a static field but it is not safe or you can get an instance of IRegistryService : http://git.eclipse.org/c/gendoc/org.eclipse.gendoc.git/tree/plugins/org.eclipse.gendoc.services/src/org/eclipse/gendoc/services/IRegistryService.java
through GendocServices.getDefault.get(IRegistryService.class)
Re: element first occurence page number [message #1760345 is a reply to message #1759646] Wed, 26 April 2017 03:58 Go to previous messageGo to next message
Thanks for your reply
I checked the existing code on http://git.eclipse.org/c/gendoc/org.eclipse.gendoc.git/tree/plugins/org.eclipse.gendoc.bundle.acceleo.papyrus
In my Template document, i set the expression:
[query public div(r1 : Real, r2 : Real) : Real = invoke('[package]','div(java.lang.Double, java.lang.Double)', Sequence{r1, r2}) /]
[div(2.1,1.7)/]
The [package] is the package of my Class of course.
I created the div method in my class:
public Double div(Double r1, Double r2){
	return r1/r2;
(The Class is an existing Class containing some others méthods which are not used by Javaservice)
When i generate the document with Gendoc, nothing is returned. Is there an Eclipse plugin to install in order to use Javaservice, or do i forget something important in my code ?
Re: element first occurence page number [message #1760698 is a reply to message #1760345] Tue, 02 May 2017 03:49 Go to previous messageGo to next message
Hello
did you modify plugin.xml file to declare extension ? an example : http://git.eclipse.org/c/gendoc/org.eclipse.gendoc.git/tree/plugins/org.eclipse.gendoc.bundle.acceleo.papyrus/plugin.xml
Re: element first occurence page number [message #1760739 is a reply to message #1760698] Tue, 02 May 2017 09:44 Go to previous messageGo to next message
No, i didn't.
I'm a little confused with the example. What exactly do i need to configure in my project ? Do i need just the plugin.xml file for declaring the extension or is there something else?
Re: element first occurence page number [message #1760806 is a reply to message #1760739] Wed, 03 May 2017 03:59 Go to previous messageGo to next message
Yeah I'm sorry if you are not used to eclipse development application.
So to be sure :
you have an eclipse with a workspace containing your sources : we will name it EclipseDev
In EclipseDev you have defined your acceleo code inside an eclipse plugin. In this plugin you should have a plugin.xml file if it is not the case open the manifest.mf file and go to extensions tab and add something random just to force the plugin.xml file creation. After that you can remove the created extension.
In this plugin.xml file you have to insert :
<extension
         point="org.eclipse.gendoc.script.acceleo.services">
      <service
            emtl="bin/org/eclipse/gendoc/bundle/acceleo/papyrus/mtl/youremtlfile_take_care_it_is_hidden_by_default_in_eclipse.emtl"
            importedByDefault="false"
            name="theNameToInsertInImportedBundles">
      </service>
   </extension>
Take care to have in your meta-inf/manifest.mf file a dependency to : org.eclipse.gendoc.script.acceleo
after all of that.
You have to run a new instance of eclipse named EclipseRuntime from EclipseDev.
Does it seem ok for you ?
Re: element first occurence page number [message #1761027 is a reply to message #1760806] Fri, 05 May 2017 07:50 Go to previous message
Hi.
Thanks for your reply.
Unfortunately,i'm an intern and today is my last day.
I will transfer all documentations i found about Javaservice, in particular this topic, for the next experts who will work on in the company.
Thanks a lot for your help. I wil mention this forum (the community) for the appreciations in my report.
Geoffrey
[Updated on: Fri, 05 May 2017 07:52] by Moderator
Previous Topic:looking for sample code...
Next Topic:GenDoc on Eclipse Neon.3
Current Time: Tue Jul 08 18:08:30 EDT 2025
Powered by FUDForum. Page generated in 0.28005 seconds
