Re: egit Broken after upgrade [message #1758303 is a reply to message #1758193] |
Mon, 27 March 2017 12:21   |
Jens Reimann Messages: 3 Registered: March 2017 |
Ok, I was able to fix this issue. The root cause was that two versions of "org.slf4j.api" where installed.
You can check this in the file ${eclipse.root}/configuration/configuration/org.eclipse.equinox.simpleconfigurator/bundles.info:
org.slf4j.api,1.7.10.v20160921-1923,file:/home/jreimann/.p2/pool/plugins/org.slf4j.api_1.7.10.v20160921-1923.jar,4,false
org.slf4j.api,1.7.2.v20121108-1250,file:/home/jreimann/.p2/pool/plugins/org.slf4j.api_1.7.2.v20121108-1250.jar,4,false
Deleting the 1.7.2 entry did solve the issue for me.
Re: egit Broken after upgrade [message #1758348 is a reply to message #1758193] |
Mon, 27 March 2017 22:58   |
David Frantz Messages: 6 Registered: March 2017 |
I'm also suffering from the same problem.
When trying to go to Team>GIT>Configuration I get this:
Unable to create the selected preference page.
An error occurred while automatically activating bundle org.eclipse.egit.ui (1702).
Note this is upon successive attempts. Really have no idea what is going on. The platform is a Mac with the latest OS and latest Java. The only possible bit of strangeness here is that my previous eclipse sat in ~/usr/bin not in the /Applications directory.
A paste of part (the actual file is huge) of my log file:
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2017-03-27 18:16:34.975
!MESSAGE Plug-in org.eclipse.scout.sdk.s2e.ui was unable to load class org.eclipse.scout.sdk.s2e.ui.internal.util.ScoutSdkStartupExtension.
!STACK 0
java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.scout.sdk.s2e.ui (2089).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:116)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:325)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:345)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:423)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:564)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:291)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:52)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:286)
at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:53)
at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2835)
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.scout.sdk.s2e.ui.internal.S2ESdkUiActivator.start() of bundle org.eclipse.scout.sdk.s2e.ui.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:795)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:724)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:932)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:470)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
... 20 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/m2e/core/ui/internal/M2EUIPluginActivator
at org.eclipse.scout.sdk.s2e.ui.internal.S2ESdkUiActivator.setDefaultMavenSettings(S2ESdkUiActivator.java:125)
at org.eclipse.scout.sdk.s2e.ui.internal.S2ESdkUiActivator.start(S2ESdkUiActivator.java:86)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:774)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:767)
... 27 more
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.m2e.core.ui (820).
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:419)
... 33 more
Caused by: org.osgi.framework.BundleException: Error starting module.
at org.eclipse.osgi.container.Module.doStart(Module.java:590)
... 42 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/m2e/core/internal/index/IIndex
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2671)
at java.lang.Class.getConstructor0(Class.java:3075)
at java.lang.Class.newInstance(Class.java:412)
at org.eclipse.osgi.internal.framework.BundleContextImpl.loadBundleActivator(BundleContextImpl.java:758)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:711)
... 45 more
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.m2e.core (819).
... 54 more
... 63 more
Caused by: java.lang.LinkageError: loader constraint violation: when resolving method "org.slf4j.impl.StaticLoggerBinder.getLoggerFactory()Lorg/slf4j/ILoggerFactory;" the class loader (instance of org/eclipse/osgi/internal/loader/EquinoxClassLoader) of the current class, org/slf4j/LoggerFactory, and the class loader (instance of org/eclipse/osgi/internal/loader/EquinoxClassLoader) for the method's defining class, org/slf4j/impl/StaticLoggerBinder, have different Class objects for the type org/slf4j/ILoggerFactory used in the signature
at org.slf4j.LoggerFactory.getILoggerFactory(LoggerFactory.java:336)
at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:284)
at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:305)
at org.eclipse.m2e.core.internal.MavenPluginActivator.<init>(MavenPluginActivator.java:87)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
at java.lang.Class.newInstance(Class.java:442)
... 66 more
!STACK 0
... 20 more
... 27 more
... 33 more
... 42 more
... 45 more
... 54 more
... 63 more
... 66 more
!ENTRY org.eclipse.ui 4 0 2017-03-27 18:16:34.981
!MESSAGE Unable to execute early startup code for the org.eclipse.ui.IStartup extension contributed by the 'org.eclipse.scout.sdk.s2e.ui' plug-in.
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.scout.sdk.s2e.ui was unable to load class org.eclipse.scout.sdk.s2e.ui.internal.util.ScoutSdkStartupExtension.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.scout.sdk.s2e.ui (2089).
... 10 more
... 20 more
... 27 more
... 33 more
... 42 more
... 45 more
... 54 more
... 63 more
... 66 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2017-03-27 18:16:34.981
!STACK 0
... 20 more
... 27 more
... 33 more
... 42 more
... 45 more
... 54 more
... 63 more
... 66 more
!ENTRY org.eclipse.ui.workbench 4 2 2017-03-27 18:16:35.038
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 1
org.eclipse.core.runtime.CoreException: Executable extension definition for "class" not found.
at org.eclipse.core.internal.registry.ConfigurationElement.throwException(ConfigurationElement.java:62)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:222)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:282)
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2017-03-27 18:16:35.038
!MESSAGE Executable extension definition for "class" not found.
!ENTRY org.eclipse.ui 4 0 2017-03-27 18:16:35.039
!MESSAGE Unable to execute early startup code for the org.eclipse.ui.IStartup extension contributed by the 'org.eclipse.ui.tests' plug-in.
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2017-03-27 18:16:35.039
!ENTRY org.eclipse.equinox.ds 1 0 2017-03-27 18:51:48.591
!MESSAGE Could not bind a reference of component org.eclipse.fx.core.internal.JUtilLoggerFactory. The reference is: Reference[name = registerHandler, interface = java.util.logging.Handler, policy = dynamic, policy-option = greedy, cardinality = 0..n, target = null, bind = registerHandler, unbind = unregisterHandler, updated = null]
!ENTRY org.eclipse.equinox.registry 4 1 2017-03-27 18:52:11.368
!MESSAGE Unable to create the selected preference page.
!STACK 0
java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.egit.ui (1702).
at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getSourceProviders(WorkbenchServiceRegistry.java:177)
at org.eclipse.ui.internal.services.SourceProviderService.readRegistry(SourceProviderService.java:108)
at org.eclipse.ui.internal.Workbench$47.runWithException(Workbench.java:2447)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:32)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4814)
at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:95)
at org.eclipse.ui.internal.Workbench.initializeDefaultServices(Workbench.java:2442)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1678)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2944)
at org.eclipse.ui.internal.Workbench.access$9(Workbench.java:2875)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:684)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.egit.ui.Activator.start() of bundle org.eclipse.egit.ui.
... 42 more
at org.eclipse.jgit.lib.Repository.<clinit>(Repository.java:112)
at org.eclipse.egit.ui.Activator.setupRepoIndexRefresh(Activator.java:423)
at org.eclipse.egit.ui.Activator.start(Activator.java:307)
... 49 more
!ENTRY org.eclipse.ui 4 0 2017-03-27 18:52:21.777
!MESSAGE Class load Failure: 'org.eclipse.egit.ui.internal.actions.PushMenu'
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.egit.ui was unable to load class org.eclipse.egit.ui.internal.actions.PushMenu.
at org.eclipse.ui.internal.util.Util.safeLoadExecutableExtension(Util.java:812)
at org.eclipse.ui.internal.menus.DynamicMenuContributionItem.createContributionItem(DynamicMenuContributionItem.java:166)
at org.eclipse.ui.internal.menus.DynamicMenuContributionItem.getContributionItem(DynamicMenuContributionItem.java:159)
at org.eclipse.ui.internal.menus.DynamicMenuContributionItem.fill(DynamicMenuContributionItem.java:145)
at org.eclipse.jface.action.MenuManager.doItemFill(MenuManager.java:728)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java:810)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java:669)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.scheduleManagerUpdate(MenuManagerRenderer.java:1185)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.access$3(MenuManagerRenderer.java:1180)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer$3.handleEvent(MenuManagerRenderer.java:247)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setVisible(UIElementImpl.java:345)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributionRecord.updateVisibility(ContributionRecord.java:102)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRendererFilter.updateElementVisibility(MenuManagerRendererFilter.java:189)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRendererFilter.updateElementVisibility(MenuManagerRendererFilter.java:200)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerShowProcessor.showMenu(MenuManagerShowProcessor.java:232)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerShowProcessor.menuAboutToHide(MenuManagerShowProcessor.java:114)
at org.eclipse.jface.internal.MenuManagerEventHelper.showEventPostHelper(MenuManagerEventHelper.java:92)
at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java:471)
at org.eclipse.jface.action.MenuManager.access$1(MenuManager.java:465)
at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager.java:497)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:256)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4256)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1501)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1524)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1505)
at org.eclipse.swt.widgets.Menu.menuWillOpen(Menu.java:805)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5787)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
at org.eclipse.swt.internal.cocoa.NSMenu.popUpContextMenu(NSMenu.java:77)
at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:267)
at org.eclipse.swt.widgets.Display.runPopups(Display.java:4157)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3699)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.egit.ui (1702).
... 16 more
... 42 more
... 49 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2017-03-27 18:52:21.778
!MESSAGE Plug-in org.eclipse.egit.ui was unable to load class org.eclipse.egit.ui.internal.actions.PushMenu.
!STACK 0
at or
Re: egit Broken after upgrade [message #1758409 is a reply to message #1758243] |
Tue, 28 March 2017 13:21   |
SLF4j is a logging facade[/em] where it presents an API with several possible backend implementations. The key is that there should only be a single implementation. Your stack trace indicates that there are two backends available:
at org.eclipse.jgit.lib.Repository.<clinit>(Repository.java:109)
To work around this, you need to uninstall one of these logging backends. The 'easiest' way I can think of is:
- Open the Console view. From the Open Console[/em] drop down in the view toolbar, select Host OSGi Console[/em].
- Run ss slf4j[/em] to see the different bundles and fragments containing slf4j[/em]. Note the bundle numbers on the left-hand side.
- Figure out which bundle is the miscreant (see below), and then use uninstall BUNDLE#[/em].
- Run ss org.eclipse.egit.ui[/em], note its bundle #, and then issue refresh BUNDLE#[/em]. I think that should be enough to restart the bundle.
Here's what I did in my system. There are two backends available: Logback (ch.qos.logback.slf4j) and Log4j (org.slf4j.impl.log4j12). I uninstalled the Log4j backend.
osgi> ss slf4j
"Framework is launched."
id State Bundle
18 ACTIVE ch.qos.logback.slf4j_1.0.7.v201505121915
Master=650
368 RESOLVED org.eclipse.m2e.maven.runtime.slf4j.simple_1.8.0.20160921-2001
650 RESOLVED org.slf4j.api_1.7.2.v20121108-1250
Fragments=18, 1111
939 RESOLVED org.slf4j.api_1.7.10.v20160921-1923
1111 RESOLVED org.slf4j.impl.log4j12_1.7.2.v20131105-2200
Master=650
osgi> uninstall 1111
It looks like EGit brings in the Log4j backend, and m2eclipse brings in the Logback backend?
Hope that helps, and YMMV etc.
Brian.
Re: egit Broken after upgrade [message #1758468 is a reply to message #1758303] |
Wed, 29 March 2017 02:12   |
Thanks Jens!!
This appears to have corrected the problem for me. I just initially checked the repair and so far it looks good.
I'm rather new to the internals of Eclipse so frankly didn't even have a clue as to where to look to even try to debug the problem. Or to put it another way I'm more of. user than a developer or Eclipse hacker.
Again thanks.
Jens Reimann wrote on Mon, 27 March 2017 12:21Ok, I was able to fix this issue. The root cause was that two versions of "org.slf4j.api" where installed.
Re: egit Broken after upgrade [message #1758635 is a reply to message #1758533] |
Thu, 30 March 2017 21:11   |
Michael Rosenhahn Messages: 3 Registered: March 2017 |
I have the same issue, after updating to Neon.3 egit is now unusable. The suggested above fixes do not work for me.
I get the following error when I attempt to import an existing git repository
!ENTRY org.eclipse.ui 4 0 2017-03-30 13:58:17.763
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.nio.file.InvalidPathException: Illegal char <"> at index 0: "C:\Users\mrosenha"\.gitconfig
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:65)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:282)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:264)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:494)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:488)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:353)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:340)
at org.eclipse.egit.ui.UIUtils.executeCommand(UIUtils.java:717)
at org.eclipse.egit.ui.UIUtils.executeCommand(UIUtils.java:704)
at org.eclipse.egit.ui.internal.repository.RepositoriesView$8.linkActivated(RepositoriesView.java:320)
at org.eclipse.ui.forms.widgets.AbstractHyperlink.handleActivate(AbstractHyperlink.java:228)
at org.eclipse.ui.forms.widgets.AbstractHyperlink.handleMouseUp(AbstractHyperlink.java:322)
at org.eclipse.ui.forms.widgets.AbstractHyperlink.access$2(AbstractHyperlink.java:306)
at org.eclipse.ui.forms.widgets.AbstractHyperlink$4.handleEvent(AbstractHyperlink.java:129)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4418)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4236)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3824)
Caused by: java.nio.file.InvalidPathException: Illegal char <"> at index 0: "C:\Users\mrosenha"\.gitconfig
at sun.nio.fs.WindowsPathParser.normalize(Unknown Source)
at sun.nio.fs.WindowsPathParser.parse(Unknown Source)
at sun.nio.fs.WindowsPath.parse(Unknown Source)
at sun.nio.fs.WindowsFileSystem.getPath(Unknown Source)
at java.io.File.toPath(Unknown Source)
at org.eclipse.jgit.util.FileUtils.lastModified(FileUtils.java:563)
at org.eclipse.jgit.util.FS.lastModified(FS.java:299)
at org.eclipse.jgit.internal.storage.file.FileSnapshot.save(FileSnapshot.java:109)
at org.eclipse.jgit.storage.file.FileBasedConfig.load(FileBasedConfig.java:139)
at org.eclipse.jgit.internal.storage.file.FileRepository.loadUserConfig(FileRepository.java:260)
at org.eclipse.jgit.internal.storage.file.FileRepository.<init>(FileRepository.java:203)
at org.eclipse.jgit.storage.file.FileRepositoryBuilder.build(FileRepositoryBuilder.java:92)
at org.eclipse.jgit.storage.file.FileRepositoryBuilder.create(FileRepositoryBuilder.java:111)
at org.eclipse.egit.core.RepositoryCache.lookupRepository(RepositoryCache.java:57)
at org.eclipse.egit.core.internal.gerrit.GerritUtil.tryToAutoConfigureForGerrit(GerritUtil.java:263)
at org.eclipse.egit.ui.internal.repository.tree.command.AddCommand.addRepository(AddCommand.java:66)
at org.eclipse.egit.ui.internal.repository.tree.command.AddCommand.execute(AddCommand.java:59)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:295)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
... 42 more
The entries in my \eclipse\configuration\org.eclipse.equinox.simpleconfigurator\bundles.info for the slf4j are:
org.slf4j.api,1.7.2.v20121108-1250,file:/C:/Users/mrosenha/.p2/pool/plugins/org.slf4j.api_1.7.2.v20121108-1250.jar,4,false
org.slf4j.impl.log4j12,1.7.2.v20131105-2200,file:/C:/Users/mrosenha/.p2/pool/plugins/org.slf4j.impl.log4j12_1.7.2.v20131105-2200.jar,4,false
OS: Win10
Re: egit Broken after upgrade [message #1758704 is a reply to message #1758303] |
Fri, 31 March 2017 18:56   |
Spencer Williams Messages: 5 Registered: November 2014 |
Yes!!! This helped me as well.
Jens Reimann wrote on Mon, 27 March 2017 06:21Ok, I was able to fix this issue. The root cause was that two versions of "org.slf4j.api" where installed.
Re: egit Broken after upgrade [message #1764866 is a reply to message #1758193] |
Fri, 02 June 2017 17:02   |
David Saunders Messages: 5 Registered: June 2017 |
Linux Fedora25
Eclipse Neon 4.6.3
gcc 7.1.0
clang 5.0 (upstream)
I have only been using Eclipse for the past 2 days, so there is a tremendous amount that I do not know .......
I too have the same problem. I removed the org.slf4j.api,1.7.2 lines as per earlier suggestions, and this enabled all the Git options in Preferences, but nothing shows up in Project>Team except Apply Patch, which does nothing. However I did manage to create a bare Repository via File>New.
Edit: Specifically I am unable to add a project to the repository.
Just wondering if there has been any progress on this?
Thanks in advance for any replies :+)
[Updated on: Fri, 02 June 2017 17:19] Report message to a moderator
FUDForum. Page generated in 0.02858 seconds
