Home » Eclipse Projects » EGit / JGit » egit Broken after upgrade(Upgrade from Neon.2 to Neon.3 broke egit UI)
egit Broken after upgrade [message #1758193] Fri, 24 March 2017 14:37 Go to next message
Alan Warner is currently offline Alan WarnerFriend
I upgraded my Neon.2 to Neon.3 and found that egit failed to upgrade. When I select GIT view I get an error in the GIT Repositories explorer:
Plug-in org.eclipse.egit.ui was unable to load class org.eclipse.egit.ui.internal.repository.RepositoriesView.
The error details are:
org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.egit.ui was unable to load class org.eclipse.egit.ui.internal.repository.RepositoriesView.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.registry.ViewDescriptor.createView(ViewDescriptor.java:58)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:101)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:278)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:316)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:536)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:520)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:70)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1317)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:103)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:669)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:70)
at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:142)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:665)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:82)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:72)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4814)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:135)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
at org.eclipse.e4.ui.workbench.addons.perspectiveswitcher.PerspectiveSwitcher$12.widgetSelected(PerspectiveSwitcher.java:593)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4256)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1501)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1524)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1509)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1313)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3706)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.egit.ui (2339).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:116)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:325)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:345)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:423)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:564)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getSourceProviders(WorkbenchServiceRegistry.java:177)
at org.eclipse.ui.internal.services.SourceProviderService.readRegistry(SourceProviderService.java:108)
at org.eclipse.ui.internal.Workbench$47.runWithException(Workbench.java:2447)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:32)
at org.eclipse.ui.internal.StartupThreading.runWithoutExceptions(StartupThreading.java:95)
at org.eclipse.ui.internal.Workbench.initializeDefaultServices(Workbench.java:2442)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1678)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2944)
at org.eclipse.ui.internal.Workbench.access$9(Workbench.java:2875)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:684)
... 16 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.egit.ui.Activator.start() of bundle org.eclipse.egit.ui.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:795)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:724)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:932)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:470)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
... 42 more
Caused by: java.lang.LinkageError: loader constraint violation: when resolving method "org.slf4j.impl.StaticLoggerBinder.getLoggerFactory()Lorg/slf4j/ILoggerFactory;" the class loader (instance of org/eclipse/osgi/internal/loader/EquinoxClassLoader) of the current class, org/slf4j/LoggerFactory, and the class loader (instance of org/eclipse/osgi/internal/loader/EquinoxClassLoader) for the method's defining class, org/slf4j/impl/StaticLoggerBinder, have different Class objects for the type org/slf4j/ILoggerFactory used in the signature
at org.slf4j.LoggerFactory.getILoggerFactory(LoggerFactory.java:336)
at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:284)
at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:305)
at org.eclipse.jgit.lib.Repository.<clinit>(Repository.java:109)
at org.eclipse.egit.ui.Activator.setupRepoIndexRefresh(Activator.java:423)
at org.eclipse.egit.ui.Activator.start(Activator.java:307)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:774)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:767)
... 49 more
I tried to revert to the previous install but still get the errors. Has anyone seen this and is there a workaround?
Re: egit Broken after upgrade [message #1758221 is a reply to message #1758193] Fri, 24 March 2017 18:53 Go to previous messageGo to next message
Joseph Benken is currently offline Joseph BenkenFriend
I had the exact same error today after updating from neon.2 to neon.3. I had two different org.slf4j.api bundles in my plugins directory, 1.7.2 and 1.7.10. I manually deleted the older one and the problem went away.
Re: egit Broken after upgrade [message #1758243 is a reply to message #1758193] Sat, 25 March 2017 18:08 Go to previous messageGo to next message
Dieter Scholz is currently offline Dieter ScholzFriend
I have exactly the same problem. The upgrade to Neon.3 also breaks the m2e and the buildship plugins.
If it makes difference - I'm using an oomph profile for my setup.
Dieter
Re: egit Broken after upgrade [message #1758267 is a reply to message #1758193] Sun, 26 March 2017 11:11 Go to previous messageGo to next message
Nicola Musatti is currently offline Nicola MusattiFriend
I have exactly the same problem, on both a CentOS 7.3 and a Windows 7 installation. Git is completely unusable.
Re: egit Broken after upgrade [message #1758302 is a reply to message #1758193] Mon, 27 March 2017 12:07 Go to previous messageGo to next message
Jens Reimann is currently offline Jens ReimannFriend
I just ran into the same issue. Is there any fix or workaround for this.
Was an upgrade from Neon.2 to Neon.3, based on Oomph
Re: egit Broken after upgrade [message #1758303 is a reply to message #1758193] Mon, 27 March 2017 12:21 Go to previous messageGo to next message
Ok, I was able to fix this issue. The root cause was that two versions of "org.slf4j.api" where installed.
You can check this in the file ${eclipse.root}/configuration/configuration/org.eclipse.equinox.simpleconfigurator/bundles.info:
org.slf4j.api,1.7.10.v20160921-1923,file:/home/jreimann/.p2/pool/plugins/org.slf4j.api_1.7.10.v20160921-1923.jar,4,false
org.slf4j.api,1.7.2.v20121108-1250,file:/home/jreimann/.p2/pool/plugins/org.slf4j.api_1.7.2.v20121108-1250.jar,4,false
Deleting the 1.7.2 entry did solve the issue for me.
Re: egit Broken after upgrade [message #1758348 is a reply to message #1758193] Mon, 27 March 2017 22:58 Go to previous messageGo to next message
David Frantz is currently offline David FrantzFriend
I'm also suffering from the same problem.
When trying to go to Team>GIT>Configuration I get this:
Unable to create the selected preference page.
An error occurred while automatically activating bundle org.eclipse.egit.ui (1702).
Note this is upon successive attempts. Really have no idea what is going on. The platform is a Mac with the latest OS and latest Java. The only possible bit of strangeness here is that my previous eclipse sat in ~/usr/bin not in the /Applications directory.
A paste of part (the actual file is huge) of my log file:
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2017-03-27 18:16:34.975
!MESSAGE Plug-in org.eclipse.scout.sdk.s2e.ui was unable to load class org.eclipse.scout.sdk.s2e.ui.internal.util.ScoutSdkStartupExtension.
!STACK 0
java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.scout.sdk.s2e.ui (2089).
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:291)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:52)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:286)
at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:53)
at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2835)
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.scout.sdk.s2e.ui.internal.S2ESdkUiActivator.start() of bundle org.eclipse.scout.sdk.s2e.ui.
... 20 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/m2e/core/ui/internal/M2EUIPluginActivator
at org.eclipse.scout.sdk.s2e.ui.internal.S2ESdkUiActivator.setDefaultMavenSettings(S2ESdkUiActivator.java:125)
at org.eclipse.scout.sdk.s2e.ui.internal.S2ESdkUiActivator.start(S2ESdkUiActivator.java:86)
... 27 more
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.m2e.core.ui (820).
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:419)
... 33 more
Caused by: org.osgi.framework.BundleException: Error starting module.
at org.eclipse.osgi.container.Module.doStart(Module.java:590)
... 42 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/m2e/core/internal/index/IIndex
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2671)
at java.lang.Class.getConstructor0(Class.java:3075)
at java.lang.Class.newInstance(Class.java:412)
at org.eclipse.osgi.internal.framework.BundleContextImpl.loadBundleActivator(BundleContextImpl.java:758)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:711)
... 45 more
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.m2e.core (819).
... 54 more
... 63 more
at org.eclipse.m2e.core.internal.MavenPluginActivator.<init>(MavenPluginActivator.java:87)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
at java.lang.Class.newInstance(Class.java:442)
... 66 more
!STACK 0
... 20 more
... 27 more
... 33 more
... 42 more
... 45 more
... 54 more
... 63 more
... 66 more
!ENTRY org.eclipse.ui 4 0 2017-03-27 18:16:34.981
!MESSAGE Unable to execute early startup code for the org.eclipse.ui.IStartup extension contributed by the 'org.eclipse.scout.sdk.s2e.ui' plug-in.
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.scout.sdk.s2e.ui was unable to load class org.eclipse.scout.sdk.s2e.ui.internal.util.ScoutSdkStartupExtension.
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.scout.sdk.s2e.ui (2089).
... 10 more
... 20 more
... 27 more
... 33 more
... 42 more
... 45 more
... 54 more
... 63 more
... 66 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2017-03-27 18:16:34.981
!STACK 0
... 20 more
... 27 more
... 33 more
... 42 more
... 45 more
... 54 more
... 63 more
... 66 more
!ENTRY org.eclipse.ui.workbench 4 2 2017-03-27 18:16:35.038
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 1
org.eclipse.core.runtime.CoreException: Executable extension definition for "class" not found.
at org.eclipse.core.internal.registry.ConfigurationElement.throwException(ConfigurationElement.java:62)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:222)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:282)
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2017-03-27 18:16:35.038
!MESSAGE Executable extension definition for "class" not found.
!ENTRY org.eclipse.ui 4 0 2017-03-27 18:16:35.039
!MESSAGE Unable to execute early startup code for the org.eclipse.ui.IStartup extension contributed by the 'org.eclipse.ui.tests' plug-in.
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2017-03-27 18:16:35.039
!ENTRY org.eclipse.equinox.ds 1 0 2017-03-27 18:51:48.591
!MESSAGE Could not bind a reference of component org.eclipse.fx.core.internal.JUtilLoggerFactory. The reference is: Reference[name = registerHandler, interface = java.util.logging.Handler, policy = dynamic, policy-option = greedy, cardinality = 0..n, target = null, bind = registerHandler, unbind = unregisterHandler, updated = null]
!ENTRY org.eclipse.equinox.registry 4 1 2017-03-27 18:52:11.368
!MESSAGE Unable to create the selected preference page.
!STACK 0
java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.egit.ui (1702).
... 42 more
at org.eclipse.jgit.lib.Repository.<clinit>(Repository.java:112)
... 49 more
!ENTRY org.eclipse.ui 4 0 2017-03-27 18:52:21.777
!MESSAGE Class load Failure: 'org.eclipse.egit.ui.internal.actions.PushMenu'
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.egit.ui was unable to load class org.eclipse.egit.ui.internal.actions.PushMenu.
at org.eclipse.ui.internal.util.Util.safeLoadExecutableExtension(Util.java:812)
at org.eclipse.ui.internal.menus.DynamicMenuContributionItem.createContributionItem(DynamicMenuContributionItem.java:166)
at org.eclipse.ui.internal.menus.DynamicMenuContributionItem.getContributionItem(DynamicMenuContributionItem.java:159)
at org.eclipse.ui.internal.menus.DynamicMenuContributionItem.fill(DynamicMenuContributionItem.java:145)
at org.eclipse.jface.action.MenuManager.doItemFill(MenuManager.java:728)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java:810)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java:669)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.scheduleManagerUpdate(MenuManagerRenderer.java:1185)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.access$3(MenuManagerRenderer.java:1180)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer$3.handleEvent(MenuManagerRenderer.java:247)
at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setVisible(UIElementImpl.java:345)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributionRecord.updateVisibility(ContributionRecord.java:102)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRendererFilter.updateElementVisibility(MenuManagerRendererFilter.java:189)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRendererFilter.updateElementVisibility(MenuManagerRendererFilter.java:200)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerShowProcessor.showMenu(MenuManagerShowProcessor.java:232)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerShowProcessor.menuAboutToHide(MenuManagerShowProcessor.java:114)
at org.eclipse.jface.internal.MenuManagerEventHelper.showEventPostHelper(MenuManagerEventHelper.java:92)
at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java:471)
at org.eclipse.jface.action.MenuManager.access$1(MenuManager.java:465)
at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager.java:497)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:256)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1505)
at org.eclipse.swt.widgets.Menu.menuWillOpen(Menu.java:805)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5787)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
at org.eclipse.swt.internal.cocoa.NSMenu.popUpContextMenu(NSMenu.java:77)
at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:267)
at org.eclipse.swt.widgets.Display.runPopups(Display.java:4157)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3699)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.egit.ui (1702).
... 16 more
... 42 more
... 49 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2017-03-27 18:52:21.778
!MESSAGE Plug-in org.eclipse.egit.ui was unable to load class org.eclipse.egit.ui.internal.actions.PushMenu.
!STACK 0
at or
Re: egit Broken after upgrade [message #1758409 is a reply to message #1758243] Tue, 28 March 2017 13:21 Go to previous messageGo to next message
Brian de Alwis is currently offline Brian de AlwisFriend
SLF4j is a logging facade[/em] where it presents an API with several possible backend implementations. The key is that there should only be a single implementation. Your stack trace indicates that there are two backends available:
To work around this, you need to uninstall one of these logging backends. The 'easiest' way I can think of is:
  1. Open the Console view. From the Open Console[/em] drop down in the view toolbar, select Host OSGi Console[/em].
  2. Run ss slf4j[/em] to see the different bundles and fragments containing slf4j[/em]. Note the bundle numbers on the left-hand side.
  3. Figure out which bundle is the miscreant (see below), and then use uninstall BUNDLE#[/em].
  4. Run ss org.eclipse.egit.ui[/em], note its bundle #, and then issue refresh BUNDLE#[/em]. I think that should be enough to restart the bundle.
Here's what I did in my system. There are two backends available: Logback (ch.qos.logback.slf4j) and Log4j (org.slf4j.impl.log4j12). I uninstalled the Log4j backend.
osgi> ss slf4j
"Framework is launched."
id	State       Bundle
18	ACTIVE    ch.qos.logback.slf4j_1.0.7.v201505121915
	            Master=650
368	RESOLVED    org.eclipse.m2e.maven.runtime.slf4j.simple_1.8.0.20160921-2001
650	RESOLVED    org.slf4j.api_1.7.2.v20121108-1250
	            Fragments=18, 1111
939	RESOLVED    org.slf4j.api_1.7.10.v20160921-1923
1111	RESOLVED    org.slf4j.impl.log4j12_1.7.2.v20131105-2200
	            Master=650
osgi> uninstall 1111
It looks like EGit brings in the Log4j backend, and m2eclipse brings in the Logback backend?
Hope that helps, and YMMV etc.
Brian.
Eclipse Platform committer. Ask me about Eclipse support, training, and consulting.
Re: egit Broken after upgrade [message #1758411 is a reply to message #1758409] Tue, 28 March 2017 13:27 Go to previous messageGo to next message
Opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=514326
Re: egit Broken after upgrade [message #1758439 is a reply to message #1758303] Tue, 28 March 2017 16:56 Go to previous messageGo to next message
deleting the line in the config file solved the problem for me. Razz
Dieter
[Updated on: Tue, 28 March 2017 16:57]
Report message to a moderator
Re: egit Broken after upgrade [message #1758468 is a reply to message #1758303] Wed, 29 March 2017 02:12 Go to previous messageGo to next message
Thanks Jens!!
This appears to have corrected the problem for me. I just initially checked the repair and so far it looks good.
I'm rather new to the internals of Eclipse so frankly didn't even have a clue as to where to look to even try to debug the problem. Or to put it another way I'm more of. user than a developer or Eclipse hacker.
Again thanks.
Jens Reimann wrote on Mon, 27 March 2017 12:21
Re: egit Broken after upgrade [message #1758533 is a reply to message #1758468] Wed, 29 March 2017 17:09 Go to previous messageGo to next message
Bela Bodecs is currently offline Bela BodecsFriend
The solution/workaround was good for me also on Win7-prof-64bit. Thank you!
Re: egit Broken after upgrade [message #1758635 is a reply to message #1758533] Thu, 30 March 2017 21:11 Go to previous messageGo to next message
Michael Rosenhahn is currently offline Michael RosenhahnFriend
I have the same issue, after updating to Neon.3 egit is now unusable. The suggested above fixes do not work for me.
I get the following error when I attempt to import an existing git repository
 !ENTRY org.eclipse.ui 4 0 2017-03-30 13:58:17.763
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.nio.file.InvalidPathException: Illegal char <"> at index 0: "C:\Users\mrosenha"\.gitconfig
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:65)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:282)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:264)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
	at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:494)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:488)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
	at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:353)
	at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:340)
	at org.eclipse.egit.ui.UIUtils.executeCommand(UIUtils.java:717)
	at org.eclipse.egit.ui.UIUtils.executeCommand(UIUtils.java:704)
	at org.eclipse.egit.ui.internal.repository.RepositoriesView$8.linkActivated(RepositoriesView.java:320)
	at org.eclipse.ui.forms.widgets.AbstractHyperlink.handleActivate(AbstractHyperlink.java:228)
	at org.eclipse.ui.forms.widgets.AbstractHyperlink.handleMouseUp(AbstractHyperlink.java:322)
	at org.eclipse.ui.forms.widgets.AbstractHyperlink.access$2(AbstractHyperlink.java:306)
	at org.eclipse.ui.forms.widgets.AbstractHyperlink$4.handleEvent(AbstractHyperlink.java:129)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4418)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4236)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3824)
Caused by: java.nio.file.InvalidPathException: Illegal char <"> at index 0: "C:\Users\mrosenha"\.gitconfig
	at sun.nio.fs.WindowsPathParser.normalize(Unknown Source)
	at sun.nio.fs.WindowsPathParser.parse(Unknown Source)
	at sun.nio.fs.WindowsPath.parse(Unknown Source)
	at sun.nio.fs.WindowsFileSystem.getPath(Unknown Source)
	at java.io.File.toPath(Unknown Source)
	at org.eclipse.jgit.util.FileUtils.lastModified(FileUtils.java:563)
	at org.eclipse.jgit.util.FS.lastModified(FS.java:299)
	at org.eclipse.jgit.internal.storage.file.FileSnapshot.save(FileSnapshot.java:109)
	at org.eclipse.jgit.storage.file.FileBasedConfig.load(FileBasedConfig.java:139)
	at org.eclipse.jgit.internal.storage.file.FileRepository.loadUserConfig(FileRepository.java:260)
	at org.eclipse.jgit.internal.storage.file.FileRepository.<init>(FileRepository.java:203)
	at org.eclipse.jgit.storage.file.FileRepositoryBuilder.build(FileRepositoryBuilder.java:92)
	at org.eclipse.jgit.storage.file.FileRepositoryBuilder.create(FileRepositoryBuilder.java:111)
	at org.eclipse.egit.core.RepositoryCache.lookupRepository(RepositoryCache.java:57)
	at org.eclipse.egit.core.internal.gerrit.GerritUtil.tryToAutoConfigureForGerrit(GerritUtil.java:263)
	at org.eclipse.egit.ui.internal.repository.tree.command.AddCommand.addRepository(AddCommand.java:66)
	at org.eclipse.egit.ui.internal.repository.tree.command.AddCommand.execute(AddCommand.java:59)
	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:295)
	at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
	... 42 more
The entries in my \eclipse\configuration\org.eclipse.equinox.simpleconfigurator\bundles.info for the slf4j are:
org.slf4j.api,1.7.2.v20121108-1250,file:/C:/Users/mrosenha/.p2/pool/plugins/org.slf4j.api_1.7.2.v20121108-1250.jar,4,false
org.slf4j.impl.log4j12,1.7.2.v20131105-2200,file:/C:/Users/mrosenha/.p2/pool/plugins/org.slf4j.impl.log4j12_1.7.2.v20131105-2200.jar,4,false
OS: Win10
Re: egit Broken after upgrade [message #1758704 is a reply to message #1758303] Fri, 31 March 2017 18:56 Go to previous messageGo to next message
Spencer Williams is currently offline Spencer WilliamsFriend
Yes!!! This helped me as well.
Jens Reimann wrote on Mon, 27 March 2017 06:21
Re: egit Broken after upgrade [message #1759464 is a reply to message #1758635] Tue, 11 April 2017 21:03 Go to previous messageGo to next message
Matthias Sohn is currently offline Matthias SohnFriend
Michael Rosenhahn wrote on Thu, 30 March 2017 17:11
[code]
!STACK 0
your ~/.gitconfig seems to contain some invalid configuration entry
Re: egit Broken after upgrade [message #1760646 is a reply to message #1759464] Sat, 29 April 2017 22:46 Go to previous messageGo to next message
after a recent update to Eclipse, Git isn't working at all for me. Doesn't even show up in Team. Looks like there are deeper issues here.
Re: egit Broken after upgrade [message #1760647 is a reply to message #1759464] Sat, 29 April 2017 22:47 Go to previous messageGo to next message
Re: egit Broken after upgrade [message #1764866 is a reply to message #1758193] Fri, 02 June 2017 17:02 Go to previous messageGo to next message
David Saunders is currently offline David SaundersFriend
Linux Fedora25
Eclipse Neon 4.6.3
gcc 7.1.0
clang 5.0 (upstream)
I have only been using Eclipse for the past 2 days, so there is a tremendous amount that I do not know .......
I too have the same problem. I removed the org.slf4j.api,1.7.2 lines as per earlier suggestions, and this enabled all the Git options in Preferences, but nothing shows up in Project>Team except Apply Patch, which does nothing. However I did manage to create a bare Repository via File>New.
Edit: Specifically I am unable to add a project to the repository.
Just wondering if there has been any progress on this?
Thanks in advance for any replies :+)
[Updated on: Fri, 02 June 2017 17:19]
Re: egit Broken after upgrade [message #1764873 is a reply to message #1758193] Fri, 02 June 2017 17:57 Go to previous messageGo to next message
I think there are a few threads out there about this problem...
Although one of the user's earlier solutions helped me at the time, I did something similar later and it did not help.
However, what I found that seemed to really solve the problem was to use the Eclipse Installer to simply install Eclipse once again in the same directory. This had the effect of adding extra entries for the eGit plugin in the Open Perspective dialog, but both of them actually work without those errors.
Re: egit Broken after upgrade [message #1764903 is a reply to message #1764873] Sat, 03 June 2017 09:55 Go to previous message
Hi Spencer,
Thanks for your reply, I ended up doing an update of everything (via Help>Check for Updates) - and that is working well now.
Cheers !
Previous Topic:Missing blob when doing a git diff with jgit
Next Topic:Custom JGit endpoint for Amazon S3
Current Time: Mon Feb 24 06:37:18 GMT 2020
Powered by FUDForum. Page generated in 0.06010 seconds
