Home » Newcomers » Newcomers » Fatal crash - Only works after reboot - EXCEPTION_FLT_DIVIDE_BY_ZERO
Fatal crash - Only works after reboot - EXCEPTION_FLT_DIVIDE_BY_ZERO [message #1757982] |
Wed, 22 March 2017 14:15 |
Pedro Gomes Messages: 4 Registered: March 2017 |
I'm having a exporadic fatal error running eclipse (1 to 3 times a day) that crashes the application.
After the crash I can only open eclipse again after a reebot.
Can you please help me resolve this issue?
log:
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_FLT_DIVIDE_BY_ZERO (0xc000008e) at pc=0x00000000031555f9, pid=4916, tid=0x00000000000016e4
# JRE version: Java(TM) SE Runtime Environment (8.0_121-b13) (build 1.8.0_121-b13)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.121-b13 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# j org.eclipse.ui.internal.themes.RGBContrastFactory.lightness(Lorg/eclipse/swt/graphics/RGB;)D+134
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
--------------- T H R E A D ---------------
Current thread (0x0000000003040800): JavaThread "main" [_thread_in_Java, id=5860, stack(0x0000000002f00000,0x0000000003000000)]
siginfo: ExceptionCode=0xc000008e, ExceptionInformation=0x0000000000000000
Registers:
RAX=0x0000000002ff1372, RBX=0x000000001846b3a0, RCX=0x000000002381aff0, RDX=0x0000000003148010
RSP=0x0000000002ffce50, RBP=0x0000000002ffcec8, RSI=0x00000000000001b8, RDI=0x000000001db1d468
R8 =0x0000000013815591, R9 =0x00000000c5767300, R10=0x000000006739d0d0, R11=0x00000000000000f0
R12=0x0000000000000000, R13=0x0000000002ffce68, R14=0x0000000002ffcf70, R15=0x0000000003040800
RIP=0x00000000031555f9, EFLAGS=0x0000000000010206
Top of Stack: (sp=0x0000000002ffce50)
0x0000000002ffce50: 0000000002ff1372 0000000002ff1372
0x0000000002ffce60: 0000000003148010 3fdb851eb851eb85
0x0000000002ffce70: 0000000000000000 0000000000000000
0x0000000002ffce80: 00000000faab22b0 0000000002ffce88
0x0000000002ffce90: 000000002381ab56 0000000002ffcf70
0x0000000002ffcea0: 000000002381aff0 0000000000000000
0x0000000002ffceb0: 000000002381ac70 0000000002ffce68
0x0000000002ffcec0: 0000000002ffcf68 0000000002ffcfb8
0x0000000002ffced0: 0000000003148010 0000000000000000
0x0000000002ffcee0: 0000000000000000 0000000000000000
0x0000000002ffcef0: 0000000000000000 0000000000000000
0x0000000002ffcf00: 0000000000000000 0000000000000000
0x0000000002ffcf10: 0000000000000000 0000000000000000
0x0000000002ffcf20: 0000000000000000 0000000000000000
0x0000000002ffcf30: 0000000000000000 0000000000000000
0x0000000002ffcf40: 0000000000000000 0000000000000000
Instructions: (pc=0x00000000031555f9)
0x00000000031555d9: d9 c1 d9 c1 48 83 ec 08 9b d9 3c 24 8b 04 24 81
0x00000000031555e9: c8 00 03 00 00 50 d9 2c 24 58 d9 f1 48 83 ec 08
0x00000000031555f9: d9 c0 d9 fc dc e9 db 1c 24 d9 f0 d9 e8 de c1 8b
0x0000000003155609: 04 24 b9 00 f8 ff ff 81 c0 ff 03 00 00 8b d0 c1
Register to memory mapping:
RAX=0x0000000002ff1372 is pointing into the stack for thread: 0x0000000003040800
RBX={method} {0x000000001846b3a8} 'pow' '(DD)D' in 'java/lang/Math'
RCX=0x000000002381aff0 is pointing into metadata
RDX=0x0000000003148010 is at code_begin+1456 in an Interpreter codelet
invoke return entry points [0x0000000003147a60, 0x0000000003148440] 2528 bytes
RSP=0x0000000002ffce50 is pointing into the stack for thread: 0x0000000003040800
RBP=0x0000000002ffcec8 is pointing into the stack for thread: 0x0000000003040800
RSI=0x00000000000001b8 is an unknown value
RDI=0x000000001db1d468 is pointing into metadata
R8 =0x0000000013815591 is an unknown value
R9 =0x00000000c5767300 is an oop
org.eclipse.swt.widgets.Display
- klass: 'org/eclipse/swt/widgets/Display'
R10=0x000000006739d0d0 is an unknown value
R11=0x00000000000000f0 is an unknown value
R12=0x0000000000000000 is an unknown value
R13=0x0000000002ffce68 is pointing into the stack for thread: 0x0000000003040800
R14=0x0000000002ffcf70 is pointing into the stack for thread: 0x0000000003040800
R15=0x0000000003040800 is a thread
Stack: [0x0000000002f00000,0x0000000003000000], sp=0x0000000002ffce50, free space=1011k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C 0x00000000031555f9
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x000000001b840800 JavaThread "org.eclipse.jdt.internal.ui.text.JavaReconciler" daemon [_thread_blocked, id=2380, stack(0x000000004bac0000,0x000000004bbc0000)]
0x000000001b833000 JavaThread "Worker-70" [_thread_blocked, id=2640, stack(0x000000004b3c0000,0x000000004b4c0000)]
0x0000000025c44000 JavaThread "tern.eclipse.ide.jsdt.internal.ui.JSDTDocumentRegionProcessor" daemon [_thread_blocked, id=6236, stack(0x00000000493f0000,0x00000000494f0000)]
0x0000000025c46800 JavaThread "org.eclipse.wst.jsdt.internal.ui.text.JavaReconciler" daemon [_thread_blocked, id=3980, stack(0x00000000492f0000,0x00000000493f0000)]
0x0000000019d71000 JavaThread "Worker-64" [_thread_blocked, id=6464, stack(0x00000000488f0000,0x00000000489f0000)]
0x0000000031bdc800 JavaThread "org.eclipse.jdt.internal.ui.text.JavaReconciler" daemon [_thread_blocked, id=10620, stack(0x000000007b620000,0x000000007b720000)]
0x0000000019d7d000 JavaThread "Provisioning Event Dispatcher" daemon [_thread_blocked, id=812, stack(0x000000002ed10000,0x000000002ee10000)]
0x0000000019d72800 JavaThread "JavaScript indexing" daemon [_thread_blocked, id=9760, stack(0x000000002dab0000,0x000000002dbb0000)]
0x000000001b836000 JavaThread "[ThreadPool Manager] - Idle Thread" daemon [_thread_blocked, id=3516, stack(0x0000000026b80000,0x0000000026c80000)]
0x000000001b833800 JavaThread "EventAdmin Async Event Dispatcher Thread" daemon [_thread_blocked, id=2768, stack(0x0000000025010000,0x0000000025110000)]
0x000000001b184800 JavaThread "Java indexing" daemon [_thread_blocked, id=9584, stack(0x0000000023140000,0x0000000023240000)]
0x000000001b183800 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=9504, stack(0x0000000021780000,0x0000000021880000)]
0x000000001b025800 JavaThread "EMF Reference Cleaner" daemon [_thread_blocked, id=9388, stack(0x000000001d8c0000,0x000000001d9c0000)]
0x000000001aa42800 JavaThread "Worker-JM" [_thread_blocked, id=9384, stack(0x000000001d7c0000,0x000000001d8c0000)]
0x000000001abef000 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=9324, stack(0x000000001d0c0000,0x000000001d1c0000)]
0x000000001bce3800 JavaThread "Start Level: Equinox Container: 41cc9139-cb8a-4039-9df3-fd82f2875260" daemon [_thread_blocked, id=9316, stack(0x000000001cdc0000,0x000000001cec0000)]
0x000000001bdff800 JavaThread "Framework Event Dispatcher: org.eclipse.osgi.internal.framework.EquinoxEventPublisher@10bea4" daemon [_thread_blocked, id=9312, stack(0x000000001ccc0000,0x000000001cdc0000)]
0x000000001b317800 JavaThread "Active Thread: Equinox Container: 41cc9139-cb8a-4039-9df3-fd82f2875260" [_thread_blocked, id=9292, stack(0x000000001cbc0000,0x000000001ccc0000)]
0x0000000018da3800 JavaThread "Service Thread" daemon [_thread_blocked, id=9236, stack(0x0000000019970000,0x0000000019a70000)]
0x0000000018d3a000 JavaThread "C1 CompilerThread2" daemon [_thread_blocked, id=9232, stack(0x0000000019870000,0x0000000019970000)]
0x0000000018d31000 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=9228, stack(0x0000000019770000,0x0000000019870000)]
0x0000000018cea000 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=9224, stack(0x0000000019670000,0x0000000019770000)]
0x0000000018ce7000 JavaThread "Attach Listener" daemon [_thread_blocked, id=9220, stack(0x0000000019570000,0x0000000019670000)]
0x0000000018ce4800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=6060, stack(0x0000000019470000,0x0000000019570000)]
0x0000000018d30800 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=5192, stack(0x0000000019370000,0x0000000019470000)]
0x0000000018ccb800 JavaThread "Finalizer" daemon [_thread_blocked, id=5264, stack(0x0000000019180000,0x0000000019280000)]
0x0000000018cc3000 JavaThread "Reference Handler" daemon [_thread_blocked, id=5176, stack(0x0000000019080000,0x0000000019180000)]
=>0x0000000003040800 JavaThread "main" [_thread_in_Java, id=5860, stack(0x0000000002f00000,0x0000000003000000)]
Other Threads:
0x000000001805e000 VMThread [stack: 0x0000000018f80000,0x0000000019080000] [id=5380]
0x0000000018df2800 WatcherThread [stack: 0x0000000019a70000,0x0000000019b70000] [id=9240]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap:
garbage-first heap total 1048576K, used 455499K [0x00000000c0000000, 0x00000000c0102000, 0x0000000100000000)
region size 1024K, 103 young (105472K), 17 survivors (17408K)
Metaspace used 192767K, capacity 209820K, committed 210036K, reserved 1232896K
class space used 22513K, capacity 26952K, committed 27080K, reserved 1048576K
Heap Regions: (Y=young(eden), SU=young(survivor), HS=humongous(starts), HC=humongous(continues), CS=collection set, F=free, TS=gc time stamp, PTAMS=previous top-at-mark-start, NTAMS=next top-at-mark-start)
AC 0 O TS 0 PTAMS 0x00000000c00ffff0 NTAMS 0x00000000c00ffff0 space 1024K, 99% used [0x00000000c0000000, 0x00000000c0100000)
AC 0 O TS 0 PTAMS 0x00000000c0200000 NTAMS 0x00000000c0200000 space 1024K, 100% used [0x00000000c0100000, 0x00000000c0200000)
AC 0 O TS 0 PTAMS 0x00000000c0300000 NTAMS 0x00000000c0300000 space 1024K, 100% used [0x00000000c0200000, 0x00000000c0300000)
AC 0 O TS 0 PTAMS 0x00000000c03fffd8 NTAMS 0x00000000c03fffd8 space 1024K, 99% used [0x00000000c0300000, 0x00000000c0400000)
AC 0 O TS 0 PTAMS 0x00000000c0500000 NTAMS 0x00000000c0500000 space 1024K, 100% used [0x00000000c0400000, 0x00000000c0500000)
AC 0 O TS 0 PTAMS 0x00000000c05fffe8 NTAMS 0x00000000c05fffe8 space 1024K, 99% used [0x00000000c0500000, 0x00000000c0600000)
AC 0 O TS 0 PTAMS 0x00000000c0700000 NTAMS 0x00000000c0700000 space 1024K, 100% used [0x00000000c0600000, 0x00000000c0700000)
AC 0 O TS 0 PTAMS 0x00000000c07fffb0 NTAMS 0x00000000c07fffb0 space 1024K, 99% used [0x00000000c0700000, 0x00000000c0800000)
AC 0 O TS 0 PTAMS 0x00000000c08ffff0 NTAMS 0x00000000c08ffff0 space 1024K, 99% used [0x00000000c0800000, 0x00000000c0900000)
AC 0 O TS 0 PTAMS 0x00000000c09ffff0 NTAMS 0x00000000c09ffff0 space 1024K, 99% used [0x00000000c0900000, 0x00000000c0a00000)
AC 0 O TS 0 PTAMS 0x00000000c0affff8 NTAMS 0x00000000c0affff8 space 1024K, 99% used [0x00000000c0a00000, 0x00000000c0b00000)
AC 0 O TS 0 PTAMS 0x00000000c0bffff8 NTAMS 0x00000000c0bffff8 space 1024K, 99% used [0x00000000c0b00000, 0x00000000c0c00000)
AC 0 O TS 0 PTAMS 0x00000000c0cfffe8 NTAMS 0x00000000c0cfffe8 space 1024K, 99% used [0x00000000c0c00000, 0x00000000c0d00000)
AC 0 O TS 0 PTAMS 0x00000000c0dfffd8 NTAMS 0x00000000c0dfffd8 space 1024K, 99% used [0x00000000c0d00000, 0x00000000c0e00000)
AC 0 O TS 0 PTAMS 0x00000000c0effd50 NTAMS 0x00000000c0effd50 space 1024K, 99% used [0x00000000c0e00000, 0x00000000c0f00000)
AC 0 O TS 0 PTAMS 0x00000000c0ffff98 NTAMS 0x00000000c0ffff98 space 1024K, 99% used [0x00000000c0f00000, 0x00000000c1000000)
AC 0 O TS 0 PTAMS 0x00000000c10ffff0 NTAMS 0x00000000c10ffff0 space 1024K, 99% used [0x00000000c1000000, 0x00000000c1100000)
AC 0 O TS 0 PTAMS 0x00000000c11ffff0 NTAMS 0x00000000c11ffff0 space 1024K, 99% used [0x00000000c1100000, 0x00000000c1200000)
AC 0 O TS 0 PTAMS 0x00000000c12f4db0 NTAMS 0x00000000c12f4db0 space 1024K, 95% used [0x00000000c1200000, 0x00000000c1300000)
AC 0 O TS 0 PTAMS 0x00000000c1400000 NTAMS 0x00000000c1400000 space 1024K, 100% used [0x00000000c1300000, 0x00000000c1400000)
AC 0 O TS 0 PTAMS 0x00000000c14fffc8 NTAMS 0x00000000c14fffc8 space 1024K, 99% used [0x00000000c1400000, 0x00000000c1500000)
AC 0 O TS 0 PTAMS 0x00000000c15fffd8 NTAMS 0x00000000c15fffd8 space 1024K, 99% used [0x00000000c1500000, 0x00000000c1600000)
AC 0 O TS 0 PTAMS 0x00000000c16ffff8 NTAMS 0x00000000c16ffff8 space 1024K, 99% used [0x00000000c1600000, 0x00000000c1700000)
AC 0 O TS 0 PTAMS 0x00000000c17fffc8 NTAMS 0x00000000c17fffc8 space 1024K, 99% used [0x00000000c1700000, 0x00000000c1800000)
AC 0 O TS 0 PTAMS 0x00000000c1900000 NTAMS 0x00000000c1900000 space 1024K, 100% used [0x00000000c1800000, 0x00000000c1900000)
AC 0 O TS 0 PTAMS 0x00000000c19fffe0 NTAMS 0x00000000c19fffe0 space 1024K, 99% used [0x00000000c1900000, 0x00000000c1a00000)
AC 0 O TS 0 PTAMS 0x00000000c1affc80 NTAMS 0x00000000c1affc80 space 1024K, 99% used [0x00000000c1a00000, 0x00000000c1b00000)
AC 0 O TS 0 PTAMS 0x00000000c1bfffe8 NTAMS 0x00000000c1bfffe8 space 1024K, 99% used [0x00000000c1b00000, 0x00000000c1c00000)
AC 0 O TS 0 PTAMS 0x00000000c1cffff8 NTAMS 0x00000000c1cffff8 space 1024K, 99% used [0x00000000c1c00000, 0x00000000c1d00000)
AC 0 O TS 0 PTAMS 0x00000000c1dfffd8 NTAMS 0x00000000c1dfffd8 space 1024K, 99% used [0x00000000c1d00000, 0x00000000c1e00000)
AC 0 O TS 0 PTAMS 0x00000000c1ec0960 NTAMS 0x00000000c1ec0960 space 1024K, 75% used [0x00000000c1e00000, 0x00000000c1f00000)
AC 0 O TS 0 PTAMS 0x00000000c1fffff8 NTAMS 0x00000000c1fffff8 space 1024K, 99% used [0x00000000c1f00000, 0x00000000c2000000)
AC 0 O TS 0 PTAMS 0x00000000c20ffff8 NTAMS 0x00000000c20ffff8 space 1024K, 99% used [0x00000000c2000000, 0x00000000c2100000)
AC 0 O TS 0 PTAMS 0x00000000c21fff68 NTAMS 0x00000000c21fff68 space 1024K, 99% used [0x00000000c2100000, 0x00000000c2200000)
AC 0 O TS 0 PTAMS 0x00000000c22fffe0 NTAMS 0x00000000c22fffe0 space 1024K, 99% used [0x00000000c2200000, 0x00000000c2300000)
AC 0 O TS 0 PTAMS 0x00000000c23fffe0 NTAMS 0x00000000c23fffe0 space 1024K, 99% used [0x00000000c2300000, 0x00000000c2400000)
AC 0 O TS 0 PTAMS 0x00000000c24ffff8 NTAMS 0x00000000c24ffff8 space 1024K, 99% used [0x00000000c2400000, 0x00000000c2500000)
AC 0 O TS 0 PTAMS 0x00000000c25f1168 NTAMS 0x00000000c25f1168 space 1024K, 94% used [0x00000000c2500000, 0x00000000c2600000)
AC 0 O TS 0 PTAMS 0x00000000c2700000 NTAMS 0x00000000c2700000 space 1024K, 100% used [0x00000000c2600000, 0x00000000c2700000)
AC 0 O TS 0 PTAMS 0x00000000c27fa6c8 NTAMS 0x00000000c27fa6c8 space 1024K, 97% used [0x00000000c2700000, 0x00000000c2800000)
AC 0 O TS 0 PTAMS 0x00000000c2900000 NTAMS 0x00000000c2900000 space 1024K, 100% used [0x00000000c2800000, 0x00000000c2900000)
AC 0 O TS 0 PTAMS 0x00000000c29fffe8 NTAMS 0x00000000c29fffe8 space 1024K, 99% used [0x00000000c2900000, 0x00000000c2a00000)
AC 0 O TS 0 PTAMS 0x00000000c2affff0 NTAMS 0x00000000c2affff0 space 1024K, 99% used [0x00000000c2a00000, 0x00000000c2b00000)
AC 0 O TS 0 PTAMS 0x00000000c2bffff8 NTAMS 0x00000000c2bffff8 space 1024K, 99% used [0x00000000c2b00000, 0x00000000c2c00000)
AC 0 O TS 0 PTAMS 0x00000000c2cffff0 NTAMS 0x00000000c2cffff0 space 1024K, 99% used [0x00000000c2c00000, 0x00000000c2d00000)
AC 0 O TS 0 PTAMS 0x00000000c2dffff8 NTAMS 0x00000000c2dffff8 space 1024K, 99% used [0x00000000c2d00000, 0x00000000c2e00000)
AC 0 O TS 0 PTAMS 0x00000000c2effff8 NTAMS 0x00000000c2effff8 space 1024K, 99% used [0x00000000c2e00000, 0x00000000c2f00000)
AC 0 O TS 0 PTAMS 0x00000000c2ffffc8 NTAMS 0x00000000c2ffffc8 space 1024K, 99% used [0x00000000c2f00000, 0x00000000c3000000)
AC 0 O TS 0 PTAMS 0x00000000c30ffff8 NTAMS 0x00000000c30ffff8 space 1024K, 99% used [0x00000000c3000000, 0x00000000c3100000)
AC 0 O TS 0 PTAMS 0x00000000c31ffff8 NTAMS 0x00000000c31ffff8 space 1024K, 99% used [0x00000000c3100000, 0x00000000c3200000)
AC 0 O TS 0 PTAMS 0x00000000c32ffff8 NTAMS 0x00000000c32ffff8 space 1024K, 99% used [0x00000000c3200000, 0x00000000c3300000)
AC 0 O TS 0 PTAMS 0x00000000c33fffd8 NTAMS 0x00000000c33fffd8 space 1024K, 99% used [0x00000000c3300000, 0x00000000c3400000)
AC 0 O TS 0 PTAMS 0x00000000c34fce68 NTAMS 0x00000000c34fce68 space 1024K, 98% used [0x00000000c3400000, 0x00000000c3500000)
AC 0 O TS 0 PTAMS 0x00000000c35ffd08 NTAMS 0x00000000c35ffd08 space 1024K, 99% used [0x00000000c3500000, 0x00000000c3600000)
AC 0 O TS 0 PTAMS 0x00000000c36ffff0 NTAMS 0x00000000c36ffff0 space 1024K, 99% used [0x00000000c3600000, 0x00000000c3700000)
AC 0 O TS 0 PTAMS 0x00000000c37fffe0 NTAMS 0x00000000c37fffe0 space 1024K, 99% used [0x00000000c3700000, 0x00000000c3800000)
AC 0 O TS 0 PTAMS 0x00000000c38ffff8 NTAMS 0x00000000c38ffff8 space 1024K, 99% used [0x00000000c3800000, 0x00000000c3900000)
AC 0 HS TS 0 PTAMS 0x00000000c3980010 NTAMS 0x00000000c3980010 space 1024K, 50% used [0x00000000c3900000, 0x00000000c3a00000)
AC 0 O TS 0 PTAMS 0x00000000c3b00000 NTAMS 0x00000000c3b00000 space 1024K, 100% used [0x00000000c3a00000, 0x00000000c3b00000)
AC 0 O TS 0 PTAMS 0x00000000c3bffff0 NTAMS 0x00000000c3bffff0 space 1024K, 99% used [0x00000000c3b00000, 0x00000000c3c00000)
AC 0 O TS 0 PTAMS 0x00000000c3cfe3e8 NTAMS 0x00000000c3cfe3e8 space 1024K, 99% used [0x00000000c3c00000, 0x00000000c3d00000)
AC 0 O TS 0 PTAMS 0x00000000c3dff380 NTAMS 0x00000000c3dff380 space 1024K, 99% used [0x00000000c3d00000, 0x00000000c3e00000)
AC 0 O TS 0 PTAMS 0x00000000c3efffd8 NTAMS 0x00000000c3efffd8 space 1024K, 99% used [0x00000000c3e00000, 0x00000000c3f00000)
AC 0 O TS 0 PTAMS 0x00000000c3ffffe8 NTAMS 0x00000000c3ffffe8 space 1024K, 99% used [0x00000000c3f00000, 0x00000000c4000000)
AC 0 O TS 0 PTAMS 0x00000000c40ffff8 NTAMS 0x00000000c40ffff8 space 1024K, 99% used [0x00000000c4000000, 0x00000000c4100000)
AC 0 O TS 0 PTAMS 0x00000000c41ffff0 NTAMS 0x00000000c41ffff0 space 1024K, 99% used [0x00000000c4100000, 0x00000000c4200000)
AC 0 O TS 0 PTAMS 0x00000000c42fffe0 NTAMS 0x00000000c42fffe0 space 1024K, 99% used [0x00000000c4200000, 0x00000000c4300000)
AC 0 O TS 0 PTAMS 0x00000000c43e4668 NTAMS 0x00000000c43e4668 space 1024K, 89% used [0x00000000c4300000, 0x00000000c4400000)
AC 0 O TS 0 PTAMS 0x00000000c44ffff0 NTAMS 0x00000000c44ffff0 space 1024K, 99% used [0x00000000c4400000, 0x00000000c4500000)
AC 0 O TS 0 PTAMS 0x00000000c45ffdb8 NTAMS 0x00000000c45ffdb8 space 1024K, 99% used [0x00000000c4500000, 0x00000000c4600000)
AC 0 O TS 0 PTAMS 0x00000000c46e46c0 NTAMS 0x00000000c46e46c0 space 1024K, 89% used [0x00000000c4600000, 0x00000000c4700000)
AC 0 O TS 0 PTAMS 0x00000000c4800000 NTAMS 0x00000000c4800000 space 1024K, 100% used [0x00000000c4700000, 0x00000000c4800000)
AC 0 O TS 0 PTAMS 0x00000000c48fe8a0 NTAMS 0x00000000c48fe8a0 space 1024K, 99% used [0x00000000c4800000, 0x00000000c4900000)
AC 0 O TS 0 PTAMS 0x00000000c49fffe8 NTAMS 0x00000000c49fffe8 space 1024K, 99% used [0x00000000c4900000, 0x00000000c4a00000)
AC 0 HS TS 0 PTAMS 0x00000000c4b00010 NTAMS 0x00000000c4b00010 space 2048K, 50% used [0x00000000c4a00000, 0x00000000c4c00000)
AC 0 HC TS 0 PTAMS 0x00000000c4b00000 NTAMS 0x00000000c4b00000 space 1024K, 0% used [0x00000000c4b00000, 0x00000000c4c00000)
AC 0 O TS 0 PTAMS 0x00000000c4cffc40 NTAMS 0x00000000c4cffc40 space 1024K, 99% used [0x00000000c4c00000, 0x00000000c4d00000)
AC 0 O TS 0 PTAMS 0x00000000c4e00000 NTAMS 0x00000000c4e00000 space 1024K, 100% used [0x00000000c4d00000, 0x00000000c4e00000)
AC 0 O TS 0 PTAMS 0x00000000c4efffd0 NTAMS 0x00000000c4efffd0 space 1024K, 99% used [0x00000000c4e00000, 0x00000000c4f00000)
AC 0 O TS 0 PTAMS 0x00000000c5000000 NTAMS 0x00000000c5000000 space 1024K, 100% used [0x00000000c4f00000, 0x00000000c5000000)
AC 0 O TS 0 PTAMS 0x00000000c50fffd8 NTAMS 0x00000000c50fffd8 space 1024K, 99% used [0x00000000c5000000, 0x00000000c5100000)
AC 0 O TS 0 PTAMS 0x00000000c51ffff8 NTAMS 0x00000000c51ffff8 space 1024K, 99% used [0x00000000c5100000, 0x00000000c5200000)
AC 0 O TS 0 PTAMS 0x00000000c52ffff8 NTAMS 0x00000000c52ffff8 space 1024K, 99% used [0x00000000c5200000, 0x00000000c5300000)
AC 0 O TS 0 PTAMS 0x00000000c53fffc8 NTAMS 0x00000000c53fffc8 space 1024K, 99% used [0x00000000c5300000, 0x00000000c5400000)
AC 0 O TS 0 PTAMS 0x00000000c54fffc8 NTAMS 0x00000000c54fffc8 space 1024K, 99% used [0x00000000c5400000, 0x00000000c5500000)
AC 0 O TS 0 PTAMS 0x00000000c55ffff8 NTAMS 0x00000000c55ffff8 space 1024K, 99% used [0x00000000c5500000, 0x00000000c5600000)
AC 0 O TS 0 PTAMS 0x00000000c56ffff0 NTAMS 0x00000000c56ffff0 space 1024K, 99% used [0x00000000c5600000, 0x00000000c5700000)
AC 0 O TS 0 PTAMS 0x00000000c57f74c8 NTAMS 0x00000000c57f74c8 space 1024K, 96% used [0x00000000c5700000, 0x00000000c5800000)
AC 0 O TS 0 PTAMS 0x00000000c58fffb0 NTAMS 0x00000000c58fffb0 space 1024K, 99% used [0x00000000c5800000, 0x00000000c5900000)
AC 0 O TS 0 PTAMS 0x00000000c59fffe8 NTAMS 0x00000000c59fffe8 space 1024K, 99% used [0x00000000c5900000, 0x00000000c5a00000)
AC 0 O TS 0 PTAMS 0x00000000c5affff8 NTAMS 0x00000000c5affff8 space 1024K, 99% used [0x00000000c5a00000, 0x00000000c5b00000)
AC 0 O TS 0 PTAMS 0x00000000c5bfffd8 NTAMS 0x00000000c5bfffd8 space 1024K, 99% used [0x00000000c5b00000, 0x00000000c5c00000)
AC 0 O TS 0 PTAMS 0x00000000c5cffff8 NTAMS 0x00000000c5cffff8 space 1024K, 99% used [0x00000000c5c00000, 0x00000000c5d00000)
AC 0 O TS 0 PTAMS 0x00000000c5dffff0 NTAMS 0x00000000c5dffff0 space 1024K, 99% used [0x00000000c5d00000, 0x00000000c5e00000)
AC 0 O TS 0 PTAMS 0x00000000c5effff0 NTAMS 0x00000000c5effff0 space 1024K, 99% used [0x00000000c5e00000, 0x00000000c5f00000)
AC 0 O TS 0 PTAMS 0x00000000c5ff1df0 NTAMS 0x00000000c5ff1df0 space 1024K, 94% used [0x00000000c5f00000, 0x00000000c6000000)
AC 0 O TS 0 PTAMS 0x00000000c60ffff0 NTAMS 0x00000000c60ffff0 space 1024K, 99% used [0x00000000c6000000, 0x00000000c6100000)
AC 0 O TS 0 PTAMS 0x00000000c61fffe8 NTAMS 0x00000000c61fffe8 space 1024K, 99% used [0x00000000c6100000, 0x00000000c6200000)
AC 0 O TS 0 PTAMS 0x00000000c62fffe8 NTAMS 0x00000000c62fffe8 space 1024K, 99% used [0x00000000c6200000, 0x00000000c6300000)
AC 0 O TS 0 PTAMS 0x00000000c63ffff0 NTAMS 0x00000000c63ffff0 space 1024K, 99% used [0x00000000c6300000, 0x00000000c6400000)
AC 0 O TS 0 PTAMS 0x00000000c64fffe0 NTAMS 0x00000000c64fffe0 space 1024K, 99% used [0x00000000c6400000, 0x00000000c6500000)
AC 0 O TS 0 PTAMS 0x00000000c6600000 NTAMS 0x00000000c6600000 space 1024K, 100% used [0x00000000c6500000, 0x00000000c6600000)
AC 0 O TS 0 PTAMS 0x00000000c66ffff0 NTAMS 0x00000000c66ffff0 space 1024K, 99% used [0x00000000c6600000, 0x00000000c6700000)
AC 0 O TS 0 PTAMS 0x00000000c67ffff0 NTAMS 0x00000000c67ffff0 space 1024K, 99% used [0x00000000c6700000, 0x00000000c6800000)
AC 0 O TS 0 PTAMS 0x00000000c68ffff8 NTAMS 0x00000000c68ffff8 space 1024K, 99% used [0x00000000c6800000, 0x00000000c6900000)
AC 0 O TS 0 PTAMS 0x00000000c6a00000 NTAMS 0x00000000c6a00000 space 1024K, 100% used [0x00000000c6900000, 0x00000000c6a00000)
AC 0 O TS 0 PTAMS 0x00000000c6b00000 NTAMS 0x00000000c6b00000 space 1024K, 100% used [0x00000000c6a00000, 0x00000000c6b00000)
AC 0 O TS 0 PTAMS 0x00000000c6bfffd0 NTAMS 0x00000000c6bfffd0 space 1024K, 99% used [0x00000000c6b00000, 0x00000000c6c00000)
AC 0 O TS 0 PTAMS 0x00000000c6cffff8 NTAMS 0x00000000c6cffff8 space 1024K, 99% used [0x00000000c6c00000, 0x00000000c6d00000)
AC 0 O TS 0 PTAMS 0x00000000c6dff140 NTAMS 0x00000000c6dff140 space 1024K, 99% used [0x00000000c6d00000, 0x00000000c6e00000)
AC 0 O TS 0 PTAMS 0x00000000c6efffd0 NTAMS 0x00000000c6efffd0 space 1024K, 99% used [0x00000000c6e00000, 0x00000000c6f00000)
AC 0 O TS 0 PTAMS 0x00000000c6fffff0 NTAMS 0x00000000c6fffff0 space 1024K, 99% used [0x00000000c6f00000, 0x00000000c7000000)
AC 0 O TS 0 PTAMS 0x00000000c70ffe28 NTAMS 0x00000000c70ffe28 space 1024K, 99% used [0x00000000c7000000, 0x00000000c7100000)
AC 0 O TS 0 PTAMS 0x00000000c71fffd8 NTAMS 0x00000000c71fffd8 space 1024K, 99% used [0x00000000c7100000, 0x00000000c7200000)
AC 0 O TS 0 PTAMS 0x00000000c72ffff8 NTAMS 0x00000000c72ffff8 space 1024K, 99% used [0x00000000c7200000, 0x00000000c7300000)
AC 0 O TS 0 PTAMS 0x00000000c73da138 NTAMS 0x00000000c73da138 space 1024K, 85% used [0x00000000c7300000, 0x00000000c7400000)
AC 0 O TS 0 PTAMS 0x00000000c74fff78 NTAMS 0x00000000c74fff78 space 1024K, 99% used [0x00000000c7400000, 0x00000000c7500000)
AC 0 O TS 0 PTAMS 0x00000000c75ffff8 NTAMS 0x00000000c75ffff8 space 1024K, 99% used [0x00000000c7500000, 0x00000000c7600000)
AC 0 O TS 0 PTAMS 0x00000000c76fffc8 NTAMS 0x00000000c76fffc8 space 1024K, 99% used [0x00000000c7600000, 0x00000000c7700000)
AC 0 O TS 0 PTAMS 0x00000000c7800000 NTAMS 0x00000000c7800000 space 1024K, 100% used [0x00000000c7700000, 0x00000000c7800000)
AC 0 O TS 0 PTAMS 0x00000000c78fffd0 NTAMS 0x00000000c78fffd0 space 1024K, 99% used [0x00000000c7800000, 0x00000000c7900000)
AC 0 O TS 0 PTAMS 0x00000000c79e3e48 NTAMS 0x00000000c79e3e48 space 1024K, 89% used [0x00000000c7900000, 0x00000000c7a00000)
AC 0 O TS 0 PTAMS 0x00000000c7afffa8 NTAMS 0x00000000c7afffa8 space 1024K, 99% used [0x00000000c7a00000, 0x00000000c7b00000)
AC 0 O TS 0 PTAMS 0x00000000c7bfffe8 NTAMS 0x00000000c7bfffe8 space 1024K, 99% used [0x00000000c7b00000, 0x00000000c7c00000)
AC 0 O TS 0 PTAMS 0x00000000c7d00000 NTAMS 0x00000000c7d00000 space 1024K, 100% used [0x00000000c7c00000, 0x00000000c7d00000)
AC 0 O TS 0 PTAMS 0x00000000c7dffff8 NTAMS 0x00000000c7dffff8 space 1024K, 99% used [0x00000000c7d00000, 0x00000000c7e00000)
AC 0 O TS 0 PTAMS 0x00000000c7f00000 NTAMS 0x00000000c7f00000 space 1024K, 100% used [0x00000000c7e00000, 0x00000000c7f00000)
AC 0 O TS 0 PTAMS 0x00000000c7ffffc0 NTAMS 0x00000000c7ffffc0 space 1024K, 99% used [0x00000000c7f00000, 0x00000000c8000000)
AC 0 O TS 0 PTAMS 0x00000000c80f3ea0 NTAMS 0x00000000c80f3ea0 space 1024K, 95% used [0x00000000c8000000, 0x00000000c8100000)
AC 0 O TS 13 PTAMS 0x00000000c8100000 NTAMS 0x00000000c8100000 space 1024K, 100% used [0x00000000c8100000, 0x00000000c8200000)
AC 0 O TS 0 PTAMS 0x00000000c8300000 NTAMS 0x00000000c8300000 space 1024K, 100% used [0x00000000c8200000, 0x00000000c8300000)
AC 0 O TS 0 PTAMS 0x00000000c83fff48 NTAMS 0x00000000c83fff48 space 1024K, 99% used [0x00000000c8300000, 0x00000000c8400000)
AC 0 O TS 0 PTAMS 0x00000000c84fffc8 NTAMS 0x00000000c84fffc8 space 1024K, 99% used [0x00000000c8400000, 0x00000000c8500000)
AC 0 O TS 0 PTAMS 0x00000000c85ffff8 NTAMS 0x00000000c85ffff8 space 1024K, 99% used [0x00000000c8500000, 0x00000000c8600000)
AC 0 O TS 0 PTAMS 0x00000000c8700000 NTAMS 0x00000000c8700000 space 1024K, 100% used [0x00000000c8600000, 0x00000000c8700000)
AC 0 O TS 7 PTAMS 0x00000000c8700000 NTAMS 0x00000000c8700000 space 1024K, 100% used [0x00000000c8700000, 0x00000000c8800000)
AC 0 O TS 0 PTAMS 0x00000000c8900000 NTAMS 0x00000000c8900000 space 1024K, 100% used [0x00000000c8800000, 0x00000000c8900000)
AC 0 O TS 0 PTAMS 0x00000000c89ffff8 NTAMS 0x00000000c89ffff8 space 1024K, 99% used [0x00000000c8900000, 0x00000000c8a00000)
AC 0 O TS 0 PTAMS 0x00000000c8affff8 NTAMS 0x00000000c8affff8 space 1024K, 99% used [0x00000000c8a00000, 0x00000000c8b00000)
AC 0 O TS 0 PTAMS 0x00000000c8bffff0 NTAMS 0x00000000c8bffff0 space 1024K, 99% used [0x00000000c8b00000, 0x00000000c8c00000)
AC 0 O TS 0 PTAMS 0x00000000c8cfffc8 NTAMS 0x00000000c8cfffc8 space 1024K, 99% used [0x00000000c8c00000, 0x00000000c8d00000)
AC 0 O TS 0 PTAMS 0x00000000c8dffff8 NTAMS 0x00000000c8dffff8 space 1024K, 99% used [0x00000000c8d00000, 0x00000000c8e00000)
AC 0 O TS 0 PTAMS 0x00000000c8f00000 NTAMS 0x00000000c8f00000 space 1024K, 100% used [0x00000000c8e00000, 0x00000000c8f00000)
AC 0 O TS 0 PTAMS 0x00000000c9000000 NTAMS 0x00000000c9000000 space 1024K, 100% used [0x00000000c8f00000, 0x00000000c9000000)
AC 0 O TS 0 PTAMS 0x00000000c9100000 NTAMS 0x00000000c9100000 space 1024K, 100% used [0x00000000c9000000, 0x00000000c9100000)
AC 0 O TS 0 PTAMS 0x00000000c9200000 NTAMS 0x00000000c9200000 space 1024K, 100% used [0x00000000c9100000, 0x00000000c9200000)
AC 0 O TS 0 PTAMS 0x00000000c9300000 NTAMS 0x00000000c9300000 space 1024K, 100% used [0x00000000c9200000, 0x00000000c9300000)
AC 0 O TS 0 PTAMS 0x00000000c9400000 NTAMS 0x00000000c9400000 space 1024K, 100% used [0x00000000c9300000, 0x00000000c9400000)
AC 0 O TS 0 PTAMS 0x00000000c94fffd8 NTAMS 0x00000000c94fffd8 space 1024K, 99% used [0x00000000c9400000, 0x00000000c9500000)
AC 0 O TS 0 PTAMS 0x00000000c95ffff8 NTAMS 0x00000000c95ffff8 space 1024K, 99% used [0x00000000c9500000, 0x00000000c9600000)
AC 0 O TS 0 PTAMS 0x00000000c96ffc08 NTAMS 0x00000000c96ffc08 space 1024K, 99% used [0x00000000c9600000, 0x00000000c9700000)
AC 0 O TS 0 PTAMS 0x00000000c97e2e18 NTAMS 0x00000000c97e2e18 space 1024K, 88% used [0x00000000c9700000, 0x00000000c9800000)
AC 0 O TS 13 PTAMS 0x00000000c9800000 NTAMS 0x00000000c9800000 space 1024K, 100% used [0x00000000c9800000, 0x00000000c9900000)
AC 0 O TS 13 PTAMS 0x00000000c9900000 NTAMS 0x00000000c9900000 space 1024K, 100% used [0x00000000c9900000, 0x00000000c9a00000)
AC 0 O TS 13 PTAMS 0x00000000c9a00000 NTAMS 0x00000000c9a00000 space 1024K, 100% used [0x00000000c9a00000, 0x00000000c9b00000)
AC 0 O TS 0 PTAMS 0x00000000c9c00000 NTAMS 0x00000000c9c00000 space 1024K, 100% used [0x00000000c9b00000, 0x00000000c9c00000)
AC 0 O TS 0 PTAMS 0x00000000c9d00000 NTAMS 0x00000000c9d00000 space 1024K, 100% used [0x00000000c9c00000, 0x00000000c9d00000)
AC 0 O TS 0 PTAMS 0x00000000c9e00000 NTAMS 0x00000000c9e00000 space 1024K, 100% used [0x00000000c9d00000, 0x00000000c9e00000)
AC 0 O TS 13 PTAMS 0x00000000c9e00000 NTAMS 0x00000000c9e00000 space 1024K, 100% used [0x00000000c9e00000, 0x00000000c9f00000)
AC 0 O TS 13 PTAMS 0x00000000c9f00000 NTAMS 0x00000000c9f00000 space 1024K, 100% used [0x00000000c9f00000, 0x00000000ca000000)
AC 0 O TS 0 PTAMS 0x00000000ca100000 NTAMS 0x00000000ca100000 space 1024K, 100% used [0x00000000ca000000, 0x00000000ca100000)
AC 0 O TS 0 PTAMS 0x00000000ca200000 NTAMS 0x00000000ca200000 space 1024K, 100% used [0x00000000ca100000, 0x00000000ca200000)
AC 0 O TS 0 PTAMS 0x00000000ca300000 NTAMS 0x00000000ca300000 space 1024K, 100% used [0x00000000ca200000, 0x00000000ca300000)
AC 0 O TS 0 PTAMS 0x00000000ca400000 NTAMS 0x00000000ca400000 space 1024K, 100% used [0x00000000ca300000, 0x00000000ca400000)
AC 0 O TS 0 PTAMS 0x00000000ca4ffff0 NTAMS 0x00000000ca4ffff0 space 1024K, 99% used [0x00000000ca400000, 0x00000000ca500000)
AC 0 O TS 0 PTAMS 0x00000000ca600000 NTAMS 0x00000000ca600000 space 1024K, 100% used [0x00000000ca500000, 0x00000000ca600000)
AC 0 O TS 0 PTAMS 0x00000000ca6fffe8 NTAMS 0x00000000ca6fffe8 space 1024K, 99% used [0x00000000ca600000, 0x00000000ca700000)
AC 0 O TS 0 PTAMS 0x00000000ca800000 NTAMS 0x00000000ca800000 space 1024K, 100% used [0x00000000ca700000, 0x00000000ca800000)
AC 0 O TS 0 PTAMS 0x00000000ca900000 NTAMS 0x00000000ca900000 space 1024K, 100% used [0x00000000ca800000, 0x00000000ca900000)
AC 0 O TS 0 PTAMS 0x00000000caa00000 NTAMS 0x00000000caa00000 space 1024K, 100% used [0x00000000ca900000, 0x00000000caa00000)
AC 0 O TS 0 PTAMS 0x00000000caaffff0 NTAMS 0x00000000caaffff0 space 1024K, 99% used [0x00000000caa00000, 0x00000000cab00000)
AC 0 O TS 0 PTAMS 0x00000000cac00000 NTAMS 0x00000000cac00000 space 1024K, 100% used [0x00000000cab00000, 0x00000000cac00000)
AC 0 O TS 0 PTAMS 0x00000000cacffff8 NTAMS 0x00000000cacffff8 space 1024K, 99% used [0x00000000cac00000, 0x00000000cad00000)
AC 0 O TS 0 PTAMS 0x00000000cadfff58 NTAMS 0x00000000cadfff58 space 1024K, 99% used [0x00000000cad00000, 0x00000000cae00000)
AC 0 O TS 0 PTAMS 0x00000000caf00000 NTAMS 0x00000000caf00000 space 1024K, 100% used [0x00000000cae00000, 0x00000000caf00000)
AC 0 O TS 0 PTAMS 0x00000000cb000000 NTAMS 0x00000000cb000000 space 1024K, 100% used [0x00000000caf00000, 0x00000000cb000000)
AC 0 O TS 0 PTAMS 0x00000000cb0ffff0 NTAMS 0x00000000cb0ffff0 space 1024K, 99% used [0x00000000cb000000, 0x00000000cb100000)
AC 0 O TS 0 PTAMS 0x00000000cb1fff98 NTAMS 0x00000000cb1fff98 space 1024K, 99% used [0x00000000cb100000, 0x00000000cb200000)
AC 0 O TS 0 PTAMS 0x00000000cb300000 NTAMS 0x00000000cb300000 space 1024K, 100% used [0x00000000cb200000, 0x00000000cb300000)
AC 0 O TS 0 PTAMS 0x00000000cb400000 NTAMS 0x00000000cb400000 space 1024K, 100% used [0x00000000cb300000, 0x00000000cb400000)
AC 0 O TS 0 PTAMS 0x00000000cb500000 NTAMS 0x00000000cb500000 space 1024K, 100% used [0x00000000cb400000, 0x00000000cb500000)
AC 0 O TS 0 PTAMS 0x00000000cb600000 NTAMS 0x00000000cb600000 space 1024K, 100% used [0x00000000cb500000, 0x00000000cb600000)
AC 0 O TS 13 PTAMS 0x00000000cb600000 NTAMS 0x00000000cb600000 space 1024K, 100% used [0x00000000cb600000, 0x00000000cb700000)
AC 0 O TS 13 PTAMS 0x00000000cb700000 NTAMS 0x00000000cb700000 space 1024K, 100% used [0x00000000cb700000, 0x00000000cb800000)
AC 0 O TS 13 PTAMS 0x00000000cb800000 NTAMS 0x00000000cb800000 space 1024K, 100% used [0x00000000cb800000, 0x00000000cb900000)
AC 0 O TS 13 PTAMS 0x00000000cb900000 NTAMS 0x00000000cb900000 space 1024K, 100% used [0x00000000cb900000, 0x00000000cba00000)
AC 0 O TS 0 PTAMS 0x00000000cbb00000 NTAMS 0x00000000cbb00000 space 1024K, 100% used [0x00000000cba00000, 0x00000000cbb00000)
AC 0 O TS 0 PTAMS 0x00000000cbc00000 NTAMS 0x00000000cbc00000 space 1024K, 100% used [0x00000000cbb00000, 0x00000000cbc00000)
AC 0 O TS 13 PTAMS 0x00000000cbc00000 NTAMS 0x00000000cbc00000 space 1024K, 100% used [0x00000000cbc00000, 0x00000000cbd00000)
AC 0 O TS 0 PTAMS 0x00000000cbe00000 NTAMS 0x00000000cbe00000 space 1024K, 100% used [0x00000000cbd00000, 0x00000000cbe00000)
AC 0 O TS 0 PTAMS 0x00000000cbf00000 NTAMS 0x00000000cbf00000 space 1024K, 100% used [0x00000000cbe00000, 0x00000000cbf00000)
AC 0 O TS 13 PTAMS 0x00000000cbf00000 NTAMS 0x00000000cbf00000 space 1024K, 100% used [0x00000000cbf00000, 0x00000000cc000000)
AC 0 O TS 0 PTAMS 0x00000000cc100000 NTAMS 0x00000000cc100000 space 1024K, 100% used [0x00000000cc000000, 0x00000000cc100000)
AC 0 O TS 0 PTAMS 0x00000000cc200000 NTAMS 0x00000000cc200000 space 1024K, 100% used [0x00000000cc100000, 0x00000000cc200000)
AC 0 O TS 0 PTAMS 0x00000000cc300000 NTAMS 0x00000000cc300000 space 1024K, 100% used [0x00000000cc200000, 0x00000000cc300000)
AC 0 O TS 5 PTAMS 0x00000000cc300000 NTAMS 0x00000000cc300000 space 1024K, 100% used [0x00000000cc300000, 0x00000000cc400000)
AC 0 O TS 13 PTAMS 0x00000000cc400000 NTAMS 0x00000000cc400000 space 1024K, 100% used [0x00000000cc400000, 0x00000000cc500000)
AC 0 O TS 13 PTAMS 0x00000000cc500000 NTAMS 0x00000000cc500000 space 1024K, 100% used [0x00000000cc500000, 0x00000000cc600000)
AC 0 O TS 7 PTAMS 0x00000000cc600000 NTAMS 0x00000000cc600000 space 1024K, 100% used [0x00000000cc600000, 0x00000000cc700000)
AC 0 O TS 0 PTAMS 0x00000000cc800000 NTAMS 0x00000000cc800000 space 1024K, 100% used [0x00000000cc700000, 0x00000000cc800000)
AC 0 O TS 3 PTAMS 0x00000000cc800000 NTAMS 0x00000000cc800000 space 1024K, 100% used [0x00000000cc800000, 0x00000000cc900000)
AC 0 O TS 13 PTAMS 0x00000000cc900000 NTAMS 0x00000000cc900000 space 1024K, 100% used [0x00000000cc900000, 0x00000000cca00000)
AC 0 O TS 3 PTAMS 0x00000000cca00000 NTAMS 0x00000000cca00000 space 1024K, 100% used [0x00000000cca00000, 0x00000000ccb00000)
AC 0 O TS 0 PTAMS 0x00000000ccc00000 NTAMS 0x00000000ccc00000 space 1024K, 100% used [0x00000000ccb00000, 0x00000000ccc00000)
AC 0 O TS 3 PTAMS 0x00000000ccc00000 NTAMS 0x00000000ccc00000 space 1024K, 100% used [0x00000000ccc00000, 0x00000000ccd00000)
AC 0 O TS 0 PTAMS 0x00000000cce00000 NTAMS 0x00000000cce00000 space 1024K, 100% used [0x00000000ccd00000, 0x00000000cce00000)
AC 0 O TS 13 PTAMS 0x00000000cce00000 NTAMS 0x00000000cce00000 space 1024K, 100% used [0x00000000cce00000, 0x00000000ccf00000)
AC 0 O TS 0 PTAMS 0x00000000cd000000 NTAMS 0x00000000cd000000 space 1024K, 100% used [0x00000000ccf00000, 0x00000000cd000000)
AC 0 O TS 0 PTAMS 0x00000000cd100000 NTAMS 0x00000000cd100000 space 1024K, 100% used [0x00000000cd000000, 0x00000000cd100000)
AC 0 O TS 0 PTAMS 0x00000000cd200000 NTAMS 0x00000000cd200000 space 1024K, 100% used [0x00000000cd100000, 0x00000000cd200000)
AC 0 O TS 13 PTAMS 0x00000000cd200000 NTAMS 0x00000000cd200000 space 1024K, 100% used [0x00000000cd200000, 0x00000000cd300000)
AC 0 O TS 13 PTAMS 0x00000000cd300000 NTAMS 0x00000000cd300000 space 1024K, 100% used [0x00000000cd300000, 0x00000000cd400000)
AC 0 O TS 13 PTAMS 0x00000000cd400000 NTAMS 0x00000000cd400000 space 1024K, 100% used [0x00000000cd400000, 0x00000000cd500000)
AC 0 O TS 13 PTAMS 0x00000000cd500000 NTAMS 0x00000000cd500000 space 1024K, 100% used [0x00000000cd500000, 0x00000000cd600000)
AC 0 O TS 3 PTAMS 0x00000000cd600000 NTAMS 0x00000000cd600000 space 1024K, 100% used [0x00000000cd600000, 0x00000000cd700000)
AC 0 O TS 3 PTAMS 0x00000000cd700000 NTAMS 0x00000000cd700000 space 1024K, 100% used [0x00000000cd700000, 0x00000000cd800000)
AC 0 O TS 13 PTAMS 0x00000000cd800000 NTAMS 0x00000000cd800000 space 1024K, 100% used [0x00000000cd800000, 0x00000000cd900000)
AC 0 O TS 13 PTAMS 0x00000000cd900000 NTAMS 0x00000000cd900000 space 1024K, 100% used [0x00000000cd900000, 0x00000000cda00000)
AC 0 O TS 0 PTAMS 0x00000000cdb00000 NTAMS 0x00000000cdb00000 space 1024K, 100% used [0x00000000cda00000, 0x00000000cdb00000)
AC 0 O TS 13 PTAMS 0x00000000cdb00000 NTAMS 0x00000000cdb00000 space 1024K, 100% used [0x00000000cdb00000, 0x00000000cdc00000)
AC 0 O TS 0 PTAMS 0x00000000cdd00000 NTAMS 0x00000000cdd00000 space 1024K, 100% used [0x00000000cdc00000, 0x00000000cdd00000)
AC 0 O TS 0 PTAMS 0x00000000cde00000 NTAMS 0x00000000cde00000 space 1024K, 100% used [0x00000000cdd00000, 0x00000000cde00000)
AC 0 O TS 5 PTAMS 0x00000000cde00000 NTAMS 0x00000000cde00000 space 1024K, 100% used [0x00000000cde00000, 0x00000000cdf00000)
AC 0 O TS 13 PTAMS 0x00000000cdf00000 NTAMS 0x00000000cdf00000 space 1024K, 100% used [0x00000000cdf00000, 0x00000000ce000000)
AC 0 O TS 7 PTAMS 0x00000000ce000000 NTAMS 0x00000000ce000000 space 1024K, 100% used [0x00000000ce000000, 0x00000000ce100000)
AC 0 O TS 13 PTAMS 0x00000000ce100000 NTAMS 0x00000000ce100000 space 1024K, 100% used [0x00000000ce100000, 0x00000000ce200000)
AC 0 O TS 0 PTAMS 0x00000000ce300000 NTAMS 0x00000000ce300000 space 1024K, 100% used [0x00000000ce200000, 0x00000000ce300000)
AC 0 O TS 7 PTAMS 0x00000000ce300000 NTAMS 0x00000000ce300000 space 1024K, 100% used [0x00000000ce300000, 0x00000000ce400000)
AC 0 O TS 0 PTAMS 0x00000000ce500000 NTAMS 0x00000000ce500000 space 1024K, 100% used [0x00000000ce400000, 0x00000000ce500000)
AC 0 O TS 0 PTAMS 0x00000000ce600000 NTAMS 0x00000000ce600000 space 1024K, 100% used [0x00000000ce500000, 0x00000000ce600000)
AC 0 O TS 13 PTAMS 0x00000000ce600000 NTAMS 0x00000000ce600000 space 1024K, 100% used [0x00000000ce600000, 0x00000000ce700000)
AC 0 O TS 0 PTAMS 0x00000000ce800000 NTAMS 0x00000000ce800000 space 1024K, 100% used [0x00000000ce700000, 0x00000000ce800000)
AC 0 O TS 13 PTAMS 0x00000000ce800000 NTAMS 0x00000000ce800000 space 1024K, 100% used [0x00000000ce800000, 0x00000000ce900000)
AC 0 O TS 0 PTAMS 0x00000000cea00000 NTAMS 0x00000000cea00000 space 1024K, 100% used [0x00000000ce900000, 0x00000000cea00000)
AC 0 O TS 13 PTAMS 0x00000000cea00000 NTAMS 0x00000000cea00000 space 1024K, 100% used [0x00000000cea00000, 0x00000000ceb00000)
AC 0 O TS 0 PTAMS 0x00000000cec00000 NTAMS 0x00000000cec00000 space 1024K, 100% used [0x00000000ceb00000, 0x00000000cec00000)
AC 0 O TS 0 PTAMS 0x00000000ced00000 NTAMS 0x00000000ced00000 space 1024K, 100% used [0x00000000cec00000, 0x00000000ced00000)
AC 0 O TS 13 PTAMS 0x00000000ced00000 NTAMS 0x00000000ced00000 space 1024K, 100% used [0x00000000ced00000, 0x00000000cee00000)
AC 0 O TS 0 PTAMS 0x00000000cef00000 NTAMS 0x00000000cef00000 space 1024K, 100% used [0x00000000cee00000, 0x00000000cef00000)
AC 0 O TS 7 PTAMS 0x00000000cef00000 NTAMS 0x00000000cef00000 space 1024K, 100% used [0x00000000cef00000, 0x00000000cf000000)
AC 0 O TS 0 PTAMS 0x00000000cf100000 NTAMS 0x00000000cf100000 space 1024K, 100% used [0x00000000cf000000, 0x00000000cf100000)
AC 0 O TS 13 PTAMS 0x00000000cf100000 NTAMS 0x00000000cf100000 space 1024K, 100% used [0x00000000cf100000, 0x00000000cf200000)
AC 0 O TS 0 PTAMS 0x00000000cf300000 NTAMS 0x00000000cf300000 space 1024K, 100% used [0x00000000cf200000, 0x00000000cf300000)
AC 0 O TS 0 PTAMS 0x00000000cf400000 NTAMS 0x00000000cf400000 space 1024K, 100% used [0x00000000cf300000, 0x00000000cf400000)
AC 0 O TS 0 PTAMS 0x00000000cf500000 NTAMS 0x00000000cf500000 space 1024K, 100% used [0x00000000cf400000, 0x00000000cf500000)
AC 0 O TS 0 PTAMS 0x00000000cf600000 NTAMS 0x00000000cf600000 space 1024K, 100% used [0x00000000cf500000, 0x00000000cf600000)
AC 0 O TS 13 PTAMS 0x00000000cf600000 NTAMS 0x00000000cf600000 space 1024K, 100% used [0x00000000cf600000, 0x00000000cf700000)
AC 0 O TS 0 PTAMS 0x00000000cf800000 NTAMS 0x00000000cf800000 space 1024K, 100% used [0x00000000cf700000, 0x00000000cf800000)
AC 0 O TS 0 PTAMS 0x00000000cf900000 NTAMS 0x00000000cf900000 space 1024K, 100% used [0x00000000cf800000, 0x00000000cf900000)
AC 0 O TS 0 PTAMS 0x00000000cfa00000 NTAMS 0x00000000cfa00000 space 1024K, 100% used [0x00000000cf900000, 0x00000000cfa00000)
AC 0 O TS 7 PTAMS 0x00000000cfa00000 NTAMS 0x00000000cfa00000 space 1024K, 100% used [0x00000000cfa00000, 0x00000000cfb00000)
AC 0 O TS 0 PTAMS 0x00000000cfc00000 NTAMS 0x00000000cfc00000 space 1024K, 100% used [0x00000000cfb00000, 0x00000000cfc00000)
AC 0 O TS 0 PTAMS 0x00000000cfd00000 NTAMS 0x00000000cfd00000 space 1024K, 100% used [0x00000000cfc00000, 0x00000000cfd00000)
AC 0 O TS 0 PTAMS 0x00000000cfe00000 NTAMS 0x00000000cfe00000 space 1024K, 100% used [0x00000000cfd00000, 0x00000000cfe00000)
AC 0 O TS 7 PTAMS 0x00000000cfe00000 NTAMS 0x00000000cfe00000 space 1024K, 100% used [0x00000000cfe00000, 0x00000000cff00000)
AC 0 O TS 0 PTAMS 0x00000000d0000000 NTAMS 0x00000000d0000000 space 1024K, 100% used [0x00000000cff00000, 0x00000000d0000000)
AC 0 O TS 13 PTAMS 0x00000000d0000000 NTAMS 0x00000000d0000000 space 1024K, 100% used [0x00000000d0000000, 0x00000000d0100000)
AC 0 O TS 13 PTAMS 0x00000000d0100000 NTAMS 0x00000000d0100000 space 1024K, 100% used [0x00000000d0100000, 0x00000000d0200000)
AC 0 O TS 13 PTAMS 0x00000000d0200000 NTAMS 0x00000000d0200000 space 1024K, 100% used [0x00000000d0200000, 0x00000000d0300000)
AC 0 O TS 0 PTAMS 0x00000000d0400000 NTAMS 0x00000000d0400000 space 1024K, 100% used [0x00000000d0300000, 0x00000000d0400000)
AC 0 O TS 0 PTAMS 0x00000000d0500000 NTAMS 0x00000000d0500000 space 1024K, 100% used [0x00000000d0400000, 0x00000000d0500000)
AC 0 O TS 13 PTAMS 0x00000000d0500000 NTAMS 0x00000000d0500000 space 1024K, 100% used [0x00000000d0500000, 0x00000000d0600000)
AC 0 O TS 7 PTAMS 0x00000000d0600000 NTAMS 0x00000000d0600000 space 1024K, 100% used [0x00000000d0600000, 0x00000000d0700000)
AC 0 O TS 0 PTAMS 0x00000000d0800000 NTAMS 0x00000000d0800000 space 1024K, 100% used [0x00000000d0700000, 0x00000000d0800000)
AC 0 O TS 7 PTAMS 0x00000000d0800000 NTAMS 0x00000000d0800000 space 1024K, 100% used [0x00000000d0800000, 0x00000000d0900000)
AC 0 O TS 0 PTAMS 0x00000000d0a00000 NTAMS 0x00000000d0a00000 space 1024K, 100% used [0x00000000d0900000, 0x00000000d0a00000)
AC 0 O TS 7 PTAMS 0x00000000d0a00000 NTAMS 0x00000000d0a00000 space 1024K, 100% used [0x00000000d0a00000, 0x00000000d0b00000)
AC 0 O TS 0 PTAMS 0x00000000d0c00000 NTAMS 0x00000000d0c00000 space 1024K, 100% used [0x00000000d0b00000, 0x00000000d0c00000)
AC 0 O TS 0 PTAMS 0x00000000d0d00000 NTAMS 0x00000000d0d00000 space 1024K, 100% used [0x00000000d0c00000, 0x00000000d0d00000)
AC 0 O TS 0 PTAMS 0x00000000d0e00000 NTAMS 0x00000000d0e00000 space 1024K, 100% used [0x00000000d0d00000, 0x00000000d0e00000)
AC 0 O TS 0 PTAMS 0x00000000d0f00000 NTAMS 0x00000000d0f00000 space 1024K, 100% used [0x00000000d0e00000, 0x00000000d0f00000)
AC 0 O TS 0 PTAMS 0x00000000d1000000 NTAMS 0x00000000d1000000 space 1024K, 100% used [0x00000000d0f00000, 0x00000000d1000000)
AC 0 O TS 0 PTAMS 0x00000000d1100000 NTAMS 0x00000000d1100000 space 1024K, 100% used [0x00000000d1000000, 0x00000000d1100000)
AC 0 O TS 13 PTAMS 0x00000000d1100000 NTAMS 0x00000000d1100000 space 1024K, 100% used [0x00000000d1100000, 0x00000000d1200000)
AC 0 O TS 7 PTAMS 0x00000000d1200000 NTAMS 0x00000000d1200000 space 1024K, 100% used [0x00000000d1200000, 0x00000000d1300000)
AC 0 O TS 0 PTAMS 0x00000000d1400000 NTAMS 0x00000000d1400000 space 1024K, 100% used [0x00000000d1300000, 0x00000000d1400000)
AC 0 O TS 0 PTAMS 0x00000000d1500000 NTAMS 0x00000000d1500000 space 1024K, 100% used [0x00000000d1400000, 0x00000000d1500000)
AC 0 O TS 0 PTAMS 0x00000000d1600000 NTAMS 0x00000000d1600000 space 1024K, 100% used [0x00000000d1500000, 0x00000000d1600000)
AC 0 HS TS 0 PTAMS 0x00000000d16ac948 NTAMS 0x00000000d16ac948 space 1024K, 67% used [0x00000000d1600000, 0x00000000d1700000)
AC 0 O TS 7 PTAMS 0x00000000d1700000 NTAMS 0x00000000d1700000 space 1024K, 100% used [0x00000000d1700000, 0x00000000d1800000)
AC 0 HS TS 0 PTAMS 0x00000000d19496f8 NTAMS 0x00000000d19496f8 space 2048K, 64% used [0x00000000d1800000, 0x00000000d1a00000)
AC 0 HC TS 0 PTAMS 0x00000000d1900000 NTAMS 0x00000000d1900000 space 1024K, 28% used [0x00000000d1900000, 0x00000000d1a00000)
AC 0 O TS 7 PTAMS 0x00000000d1a00000 NTAMS 0x00000000d1a00000 space 1024K, 100% used [0x00000000d1a00000, 0x00000000d1b00000)
AC 0 O TS 0 PTAMS 0x00000000d1c00000 NTAMS 0x00000000d1c00000 space 1024K, 100% used [0x00000000d1b00000, 0x00000000d1c00000)
AC 0 O TS 7 PTAMS 0x00000000d1c00000 NTAMS 0x00000000d1c00000 space 1024K, 100% used [0x00000000d1c00000, 0x00000000d1d00000)
AC 0 O TS 0 PTAMS 0x00000000d1e00000 NTAMS 0x00000000d1e00000 space 1024K, 100% used [0x00000000d1d00000, 0x00000000d1e00000)
AC 0 O TS 0 PTAMS 0x00000000d1f00000 NTAMS 0x00000000d1f00000 space 1024K, 100% used [0x00000000d1e00000, 0x00000000d1f00000)
AC 0 O TS 0 PTAMS 0x00000000d2000000 NTAMS 0x00000000d2000000 space 1024K, 100% used [0x00000000d1f00000, 0x00000000d2000000)
AC 0 O TS 0 PTAMS 0x00000000d2100000 NTAMS 0x00000000d2100000 space 1024K, 100% used [0x00000000d2000000, 0x00000000d2100000)
AC 0 O TS 0 PTAMS 0x00000000d2200000 NTAMS 0x00000000d2200000 space 1024K, 100% used [0x00000000d2100000, 0x00000000d2200000)
AC 0 O TS 0 PTAMS 0x00000000d2300000 NTAMS 0x00000000d2300000 space 1024K, 100% used [0x00000000d2200000, 0x00000000d2300000)
AC 0 O TS 13 PTAMS 0x00000000d2300000 NTAMS 0x00000000d2300000 space 1024K, 100% used [0x00000000d2300000, 0x00000000d2400000)
AC 0 O TS 0 PTAMS 0x00000000d2500000 NTAMS 0x00000000d2500000 space 1024K, 100% used [0x00000000d2400000, 0x00000000d2500000)
AC 0 O TS 13 PTAMS 0x00000000d2500000 NTAMS 0x00000000d2500000 space 1024K, 100% used [0x00000000d2500000, 0x00000000d2600000)
AC 0 O TS 0 PTAMS 0x00000000d2700000 NTAMS 0x00000000d2700000 space 1024K, 100% used [0x00000000d2600000, 0x00000000d2700000)
AC 0 O TS 13 PTAMS 0x00000000d2700000 NTAMS 0x00000000d2700000 space 1024K, 100% used [0x00000000d2700000, 0x00000000d2800000)
AC 0 O TS 0 PTAMS 0x00000000d2900000 NTAMS 0x00000000d2900000 space 1024K, 100% used [0x00000000d2800000, 0x00000000d2900000)
AC 0 O TS 0 PTAMS 0x00000000d2a00000 NTAMS 0x00000000d2a00000 space 1024K, 100% used [0x00000000d2900000, 0x00000000d2a00000)
AC 0 O TS 0 PTAMS 0x00000000d2b00000 NTAMS 0x00000000d2b00000 space 1024K, 100% used [0x00000000d2a00000, 0x00000000d2b00000)
AC 0 O TS 0 PTAMS 0x00000000d2c00000 NTAMS 0x00000000d2c00000 space 1024K, 100% used [0x00000000d2b00000, 0x00000000d2c00000)
AC 0 O TS 0 PTAMS 0x00000000d2d00000 NTAMS 0x00000000d2d00000 space 1024K, 100% used [0x00000000d2c00000, 0x00000000d2d00000)
AC 0 O TS 0 PTAMS 0x00000000d2e00000 NTAMS 0x00000000d2e00000 space 1024K, 100% used [0x00000000d2d00000, 0x00000000d2e00000)
AC 0 O TS 0 PTAMS 0x00000000d2f00000 NTAMS 0x00000000d2f00000 space 1024K, 100% used [0x00000000d2e00000, 0x00000000d2f00000)
AC 0 O TS 13 PTAMS 0x00000000d2f00000 NTAMS 0x00000000d2f00000 space 1024K, 100% used [0x00000000d2f00000, 0x00000000d3000000)
AC 0 HS TS 0 PTAMS 0x00000000d33c6e98 NTAMS 0x00000000d33c6e98 space 4096K, 94% used [0x00000000d3000000, 0x00000000d3400000)
AC 0 HC TS 0 PTAMS 0x00000000d3100000 NTAMS 0x00000000d3100000 space 1024K, 100% used [0x00000000d3100000, 0x00000000d3200000)
AC 0 HC TS 0 PTAMS 0x00000000d3200000 NTAMS 0x00000000d3200000 space 1024K, 100% used [0x00000000d3200000, 0x00000000d3300000)
AC 0 HC TS 0 PTAMS 0x00000000d3300000 NTAMS 0x00000000d3300000 space 1024K, 77% used [0x00000000d3300000, 0x00000000d3400000)
AC 0 O TS 0 PTAMS 0x00000000d3500000 NTAMS 0x00000000d3500000 space 1024K, 100% used [0x00000000d3400000, 0x00000000d3500000)
AC 0 O TS 0 PTAMS 0x00000000d3600000 NTAMS 0x00000000d3600000 space 1024K, 100% used [0x00000000d3500000, 0x00000000d3600000)
AC 0 O TS 0 PTAMS 0x00000000d3700000 NTAMS 0x00000000d3700000 space 1024K, 100% used [0x00000000d3600000, 0x00000000d3700000)
AC 0 O TS 0 PTAMS 0x00000000d3800000 NTAMS 0x00000000d3800000 space 1024K, 100% used [0x00000000d3700000, 0x00000000d3800000)
AC 0 O TS 13 PTAMS 0x00000000d3800000 NTAMS 0x00000000d3800000 space 1024K, 22% used [0x00000000d3800000, 0x00000000d3900000)
AC 0 O TS 0 PTAMS 0x00000000d3a00000 NTAMS 0x00000000d3a00000 space 1024K, 100% used [0x00000000d3900000, 0x00000000d3a00000)
AC 0 O TS 0 PTAMS 0x00000000d3b00000 NTAMS 0x00000000d3b00000 space 1024K, 100% used [0x00000000d3a00000, 0x00000000d3b00000)
AC 0 O TS 0 PTAMS 0x00000000d3c00000 NTAMS 0x00000000d3c00000 space 1024K, 100% used [0x00000000d3b00000, 0x00000000d3c00000)
AC 0 O TS 0 PTAMS 0x00000000d3d00000 NTAMS 0x00000000d3d00000 space 1024K, 100% used [0x00000000d3c00000, 0x00000000d3d00000)
AC 0 O TS 0 PTAMS 0x00000000d3e00000 NTAMS 0x00000000d3e00000 space 1024K, 100% used [0x00000000d3d00000, 0x00000000d3e00000)
AC 0 HS TS 0 PTAMS 0x00000000d3e8a2e8 NTAMS 0x00000000d3e8a2e8 space 1024K, 53% used [0x00000000d3e00000, 0x00000000d3f00000)
AC 0 O TS 0 PTAMS 0x00000000d4000000 NTAMS 0x00000000d4000000 space 1024K, 100% used [0x00000000d3f00000, 0x00000000d4000000)
AC 0 O TS 0 PTAMS 0x00000000d4100000 NTAMS 0x00000000d4100000 space 1024K, 100% used [0x00000000d4000000, 0x00000000d4100000)
AC 0 O TS 0 PTAMS 0x00000000d4200000 NTAMS 0x00000000d4200000 space 1024K, 100% used [0x00000000d4100000, 0x00000000d4200000)
AC 0 HS TS 0 PTAMS 0x00000000d42ede68 NTAMS 0x00000000d42ede68 space 1024K, 92% used [0x00000000d4200000, 0x00000000d4300000)
AC 0 O TS 0 PTAMS 0x00000000d4400000 NTAMS 0x00000000d4400000 space 1024K, 100% used [0x00000000d4300000, 0x00000000d4400000)
AC 0 O TS 0 PTAMS 0x00000000d4500000 NTAMS 0x00000000d4500000 space 1024K, 100% used [0x00000000d4400000, 0x00000000d4500000)
AC 0 O TS 0 PTAMS 0x00000000d4600000 NTAMS 0x00000000d4600000 space 1024K, 100% used [0x00000000d4500000, 0x00000000d4600000)
AC 0 O TS 0 PTAMS 0x00000000d4700000 NTAMS 0x00000000d4700000 space 1024K, 100% used [0x00000000d4600000, 0x00000000d4700000)
AC 0 O TS 0 PTAMS 0x00000000d4800000 NTAMS 0x00000000d4800000 space 1024K, 100% used [0x00000000d4700000, 0x00000000d4800000)
AC 0 O TS 0 PTAMS 0x00000000d4900000 NTAMS 0x00000000d4900000 space 1024K, 100% used [0x00000000d4800000, 0x00000000d4900000)
AC 0 O TS 0 PTAMS 0x00000000d4a00000 NTAMS 0x00000000d4a00000 space 1024K, 100% used [0x00000000d4900000, 0x00000000d4a00000)
AC 0 O TS 0 PTAMS 0x00000000d4b00000 NTAMS 0x00000000d4b00000 space 1024K, 100% used [0x00000000d4a00000, 0x00000000d4b00000)
AC 0 HS TS 0 PTAMS 0x00000000d4c41da0 NTAMS 0x00000000d4c41da0 space 2048K, 62% used [0x00000000d4b00000, 0x00000000d4d00000)
AC 0 HC TS 0 PTAMS 0x00000000d4c00000 NTAMS 0x00000000d4c00000 space 1024K, 25% used [0x00000000d4c00000, 0x00000000d4d00000)
AC 0 O TS 0 PTAMS 0x00000000d4e00000 NTAMS 0x00000000d4e00000 space 1024K, 100% used [0x00000000d4d00000, 0x00000000d4e00000)
AC 0 HS TS 0 PTAMS 0x00000000d4e00000 NTAMS 0x00000000d4e00000 space 1024K, 68% used [0x00000000d4e00000, 0x00000000d4f00000)
AC 0 HS TS 0 PTAMS 0x00000000d4f00000 NTAMS 0x00000000d4f00000 space 1024K, 57% used [0x00000000d4f00000, 0x00000000d5000000)
AC 0 O TS 7 PTAMS 0x00000000d5000000 NTAMS 0x00000000d5000000 space 1024K, 100% used [0x00000000d5000000, 0x00000000d5100000)
AC 0 O TS 7 PTAMS 0x00000000d5100000 NTAMS 0x00000000d5100000 space 1024K, 100% used [0x00000000d5100000, 0x00000000d5200000)
AC 0 O TS 7 PTAMS 0x00000000d5200000 NTAMS 0x00000000d5200000 space 1024K, 100% used [0x00000000d5200000, 0x00000000d5300000)
AC 0 O TS 13 PTAMS 0x00000000d5300000 NTAMS 0x00000000d5300000 space 1024K, 100% used [0x00000000d5300000, 0x00000000d5400000)
AC 0 F TS 0 PTAMS 0x00000000d5400000 NTAMS 0x00000000d5400000 space 1024K, 0% used [0x00000000d5400000, 0x00000000d5500000)
AC 0 F TS 0 PTAMS 0x00000000d5500000 NTAMS 0x00000000d5500000 space 1024K, 0% used [0x00000000d5500000, 0x00000000d5600000)
AC 0 F TS 0 PTAMS 0x00000000d5600000 NTAMS 0x00000000d5600000 space 1024K, 0% used [0x00000000d5600000, 0x00000000d5700000)
AC 0 F TS 0 PTAMS 0x00000000d5700000 NTAMS 0x00000000d5700000 space 1024K, 0% used [0x00000000d5700000, 0x00000000d5800000)
AC 0 F TS 0 PTAMS 0x00000000d5800000 NTAMS 0x00000000d5800000 space 1024K, 0% used [0x00000000d5800000, 0x00000000d5900000)
AC 0 F TS 0 PTAMS 0x00000000d5900000 NTAMS 0x00000000d5900000 space 1024K, 0% used [0x00000000d5900000, 0x00000000d5a00000)
AC 0 F TS 0 PTAMS 0x00000000d5a00000 NTAMS 0x00000000d5a00000 space 1024K, 0% used [0x00000000d5a00000, 0x00000000d5b00000)
AC 0 F TS 0 PTAMS 0x00000000d5b00000 NTAMS 0x00000000d5b00000 space 1024K, 0% used [0x00000000d5b00000, 0x00000000d5c00000)
AC 0 F TS 0 PTAMS 0x00000000d5c00000 NTAMS 0x00000000d5c00000 space 1024K, 0% used [0x00000000d5c00000, 0x00000000d5d00000)
AC 0 F TS 0 PTAMS 0x00000000d5d00000 NTAMS 0x00000000d5d00000 space 1024K, 0% used [0x00000000d5d00000, 0x00000000d5e00000)
AC 0 F TS 0 PTAMS 0x00000000d5e00000 NTAMS 0x00000000d5e00000 space 1024K, 0% used [0x00000000d5e00000, 0x00000000d5f00000)
AC 0 F TS 0 PTAMS 0x00000000d5f00000 NTAMS 0x00000000d5f00000 space 1024K, 0% used [0x00000000d5f00000, 0x00000000d6000000)
AC 0 F TS 0 PTAMS 0x00000000d6000000 NTAMS 0x00000000d6000000 space 1024K, 0% used [0x00000000d6000000, 0x00000000d6100000)
AC 0 F TS 0 PTAMS 0x00000000d6100000 NTAMS 0x00000000d6100000 space 1024K, 0% used [0x00000000d6100000, 0x00000000d6200000)
AC 0 F TS 0 PTAMS 0x00000000d6200000 NTAMS 0x00000000d6200000 space 1024K, 0% used [0x00000000d6200000, 0x00000000d6300000)
AC 0 F TS 0 PTAMS 0x00000000d6300000 NTAMS 0x00000000d6300000 space 1024K, 0% used [0x00000000d6300000, 0x00000000d6400000)
AC 0 F TS 0 PTAMS 0x00000000d6400000 NTAMS 0x00000000d6400000 space 1024K, 0% used [0x00000000d6400000, 0x00000000d6500000)
AC 0 F TS 0 PTAMS 0x00000000d6500000 NTAMS 0x00000000d6500000 space 1024K, 0% used [0x00000000d6500000, 0x00000000d6600000)
AC 0 F TS 0 PTAMS 0x00000000d6600000 NTAMS 0x00000000d6600000 space 1024K, 0% used [0x00000000d6600000, 0x00000000d6700000)
AC 0 F TS 0 PTAMS 0x00000000d6700000 NTAMS 0x00000000d6700000 space 1024K, 0% used [0x00000000d6700000, 0x00000000d6800000)
AC 0 F TS 0 PTAMS 0x00000000d6800000 NTAMS 0x00000000d6800000 space 1024K, 0% used [0x00000000d6800000, 0x00000000d6900000)
AC 0 F TS 0 PTAMS 0x00000000d6900000 NTAMS 0x00000000d6900000 space 1024K, 0% used [0x00000000d6900000, 0x00000000d6a00000)
AC 0 F TS 0 PTAMS 0x00000000d6a00000 NTAMS 0x00000000d6a00000 space 1024K, 0% used [0x00000000d6a00000, 0x00000000d6b00000)
AC 0 F TS 0 PTAMS 0x00000000d6b00000 NTAMS 0x00000000d6b00000 space 1024K, 0% used [0x00000000d6b00000, 0x00000000d6c00000)
AC 0 F TS 0 PTAMS 0x00000000d6c00000 NTAMS 0x00000000d6c00000 space 1024K, 0% used [0x00000000d6c00000, 0x00000000d6d00000)
AC 0 F TS 0 PTAMS 0x00000000d6d00000 NTAMS 0x00000000d6d00000 space 1024K, 0% used [0x00000000d6d00000, 0x00000000d6e00000)
AC 0 F TS 0 PTAMS 0x00000000d6e00000 NTAMS 0x00000000d6e00000 space 1024K, 0% used [0x00000000d6e00000, 0x00000000d6f00000)
AC 0 F TS 0 PTAMS 0x00000000d6f00000 NTAMS 0x00000000d6f00000 space 1024K, 0% used [0x00000000d6f00000, 0x00000000d7000000)
AC 0 F TS 0 PTAMS 0x00000000d7000000 NTAMS 0x00000000d7000000 space 1024K, 0% used [0x00000000d7000000, 0x00000000d7100000)
AC 0 F TS 0 PTAMS 0x00000000d7100000 NTAMS 0x00000000d7100000 space 1024K, 0% used [0x00000000d7100000, 0x00000000d7200000)
AC 0 F TS 0 PTAMS 0x00000000d7200000 NTAMS 0x00000000d7200000 space 1024K, 0% used [0x00000000d7200000, 0x00000000d7300000)
AC 0 F TS 0 PTAMS 0x00000000d7300000 NTAMS 0x00000000d7300000 space 1024K, 0% used [0x00000000d7300000, 0x00000000d7400000)
AC 0 O TS 0 PTAMS 0x00000000d7500000 NTAMS 0x00000000d7500000 space 1024K, 100% used [0x00000000d7400000, 0x00000000d7500000)
AC 0 F TS 0 PTAMS 0x00000000d7500000 NTAMS 0x00000000d7500000 space 1024K, 0% used [0x00000000d7500000, 0x00000000d7600000)
AC 0 F TS 0 PTAMS 0x00000000d7600000 NTAMS 0x00000000d7600000 space 1024K, 0% used [0x00000000d7600000, 0x00000000d7700000)
AC 0 F TS 0 PTAMS 0x00000000d7700000 NTAMS 0x00000000d7700000 space 1024K, 0% used [0x00000000d7700000, 0x00000000d7800000)
AC 0 F TS 0 PTAMS 0x00000000d7800000 NTAMS 0x00000000d7800000 space 1024K, 0% used [0x00000000d7800000, 0x00000000d7900000)
AC 0 F TS 0 PTAMS 0x00000000d7900000 NTAMS 0x00000000d7900000 space 1024K, 0% used [0x00000000d7900000, 0x00000000d7a00000)
AC 0 F TS 0 PTAMS 0x00000000d7a00000 NTAMS 0x00000000d7a00000 space 1024K, 0% used [0x00000000d7a00000, 0x00000000d7b00000)
AC 0 F TS 0 PTAMS 0x00000000d7b00000 NTAMS 0x00000000d7b00000 space 1024K, 0% used [0x00000000d7b00000, 0x00000000d7c00000)
AC 0 F TS 0 PTAMS 0x00000000d7c00000 NTAMS 0x00000000d7c00000 space 1024K, 0% used [0x00000000d7c00000, 0x00000000d7d00000)
AC 0 F TS 0 PTAMS 0x00000000d7d00000 NTAMS 0x00000000d7d00000 space 1024K, 0% used [0x00000000d7d00000, 0x00000000d7e00000)
AC 0 F TS 0 PTAMS 0x00000000d7e00000 NTAMS 0x00000000d7e00000 space 1024K, 0% used [0x00000000d7e00000, 0x00000000d7f00000)
AC 0 F TS 0 PTAMS 0x00000000d7f00000 NTAMS 0x00000000d7f00000 space 1024K, 0% used [0x00000000d7f00000, 0x00000000d8000000)
AC 0 F TS 0 PTAMS 0x00000000d8000000 NTAMS 0x00000000d8000000 space 1024K, 0% used [0x00000000d8000000, 0x00000000d8100000)
AC 0 F TS 0 PTAMS 0x00000000d8100000 NTAMS 0x00000000d8100000 space 1024K, 0% used [0x00000000d8100000, 0x00000000d8200000)
AC 0 F TS 0 PTAMS 0x00000000d8200000 NTAMS 0x00000000d8200000 space 1024K, 0% used [0x00000000d8200000, 0x00000000d8300000)
AC 0 F TS 0 PTAMS 0x00000000d8300000 NTAMS 0x00000000d8300000 space 1024K, 0% used [0x00000000d8300000, 0x00000000d8400000)
AC 0 F TS 0 PTAMS 0x00000000d8400000 NTAMS 0x00000000d8400000 space 1024K, 0% used [0x00000000d8400000, 0x00000000d8500000)
AC 0 F TS 0 PTAMS 0x00000000d8500000 NTAMS 0x00000000d8500000 space 1024K, 0% used [0x00000000d8500000, 0x00000000d8600000)
AC 0 F TS 0 PTAMS 0x00000000d8600000 NTAMS 0x00000000d8600000 space 1024K, 0% used [0x00000000d8600000, 0x00000000d8700000)
AC 0 F TS 0 PTAMS 0x00000000d8700000 NTAMS 0x00000000d8700000 space 1024K, 0% used [0x00000000d8700000, 0x00000000d8800000)
AC 0 F TS 0 PTAMS 0x00000000d8800000 NTAMS 0x00000000d8800000 space 1024K, 0% used [0x00000000d8800000, 0x00000000d8900000)
AC 0 F TS 0 PTAMS 0x00000000d8900000 NTAMS 0x00000000d8900000 space 1024K, 0% used [0x00000000d8900000, 0x00000000d8a00000)
AC 0 F TS 0 PTAMS 0x00000000d8a00000 NTAMS 0x00000000d8a00000 space 1024K, 0% used [0x00000000d8a00000, 0x00000000d8b00000)
AC 0 F TS 0 PTAMS 0x00000000d8b00000 NTAMS 0x00000000d8b00000 space 1024K, 0% used [0x00000000d8b00000, 0x00000000d8c00000)
AC 0 F TS 0 PTAMS 0x00000000d8c00000 NTAMS 0x00000000d8c00000 space 1024K, 0% used [0x00000000d8c00000, 0x00000000d8d00000)
AC 0 F TS 0 PTAMS 0x00000000d8d00000 NTAMS 0x00000000d8d00000 space 1024K, 0% used [0x00000000d8d00000, 0x00000000d8e00000)
AC 0 F TS 0 PTAMS 0x00000000d8e00000 NTAMS 0x00000000d8e00000 space 1024K, 0% used [0x00000000d8e00000, 0x00000000d8f00000)
AC 0 F TS 0 PTAMS 0x00000000d8f00000 NTAMS 0x00000000d8f00000 space 1024K, 0% used [0x00000000d8f00000, 0x00000000d9000000)
AC 0 F TS 0 PTAMS 0x00000000d9000000 NTAMS 0x00000000d9000000 space 1024K, 0% used [0x00000000d9000000, 0x00000000d9100000)
AC 0 F TS 0 PTAMS 0x00000000d9100000 NTAMS 0x00000000d9100000 space 1024K, 0% used [0x00000000d9100000, 0x00000000d9200000)
AC 0 F TS 0 PTAMS 0x00000000d9200000 NTAMS 0x00000000d9200000 space 1024K, 0% used [0x00000000d9200000, 0x00000000d9300000)
AC 0 F TS 0 PTAMS 0x00000000d9300000 NTAMS 0x00000000d9300000 space 1024K, 0% used [0x00000000d9300000, 0x00000000d9400000)
AC 0 F TS 11 PTAMS 0x00000000d9400000 NTAMS 0x00000000d9400000 space 1024K, 0% used [0x00000000d9400000, 0x00000000d9500000)
AC 0 F TS 11 PTAMS 0x00000000d9500000 NTAMS 0x00000000d9500000 space 1024K, 0% used [0x00000000d9500000, 0x00000000d9600000)
AC 0 F TS 11 PTAMS 0x00000000d9600000 NTAMS 0x00000000d9600000 space 1024K, 0% used [0x00000000d9600000, 0x00000000d9700000)
AC 0 F TS 11 PTAMS 0x00000000d9700000 NTAMS 0x00000000d9700000 space 1024K, 0% used [0x00000000d9700000, 0x00000000d9800000)
AC 0
Re: Fatal crash - Only works after reboot - EXCEPTION_FLT_DIVIDE_BY_ZERO [message #1758075 is a reply to message #1758050] |
Thu, 23 March 2017 10:10 |
Pedro Gomes Messages: 4 Registered: March 2017 |
Yes, I didn't notice the log was cut in the first post.
I'm running eclipse with the classic theme, didn't changed anything else. This was happening also with the default appeareace settings and with multiple previous versions of eclipse.
Additional log:
Card table byte_map: [0x0000000013640000,0x0000000013840000] byte_map_base: 0x0000000013040000
Marking Bits (Prev, Next): (CMBitMap*) 0x0000000003077138, (CMBitMap*) 0x0000000003077190
Prev Bits: [0x0000000013a40000, 0x0000000014a40000)
Next Bits: [0x0000000014a40000, 0x0000000015a40000)
Polling page: 0x0000000002ed0000
CodeCache: size=245760Kb used=154665Kb max_used=157882Kb free=91094Kb
bounds [0x0000000003140000, 0x000000000cd30000, 0x0000000012140000]
total_blobs=38150 nmethods=37024 adapters=1026
compilation: enabled
Compilation events (10 events):
Event: 5757.496 Thread 0x0000000018d3a000 nmethod 58381 0x0000000008457310 code [0x0000000008457460, 0x0000000008457610]
Event: 5757.499 Thread 0x0000000018d3a000 58382 3 org.eclipse.ui.internal.WorkbenchWindow$9::changed (137 bytes)
Event: 5757.501 Thread 0x0000000018d3a000 nmethod 58382 0x000000000c7db210 code [0x000000000c7db480, 0x000000000c7dc548]
Event: 5757.509 Thread 0x0000000018d3a000 58383 3 org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer$5::changed (50 bytes)
Event: 5757.512 Thread 0x0000000018d3a000 nmethod 58383 0x000000000ba63f10 code [0x000000000ba642c0, 0x000000000ba66e28]
Event: 5769.700 Thread 0x0000000018cea000 58384 4 org.eclipse.swt.widgets.Control::isFocusControl (37 bytes)
Event: 5769.702 Thread 0x0000000018cea000 nmethod 58384 0x0000000004af8d10 code [0x0000000004af8e60, 0x0000000004af8f38]
Event: 5803.463 Thread 0x0000000018d3a000 58385 3 java.util.TreeMap::entrySet (27 bytes)
Event: 5803.464 Thread 0x0000000018d3a000 nmethod 58385 0x0000000007a0e190 code [0x0000000007a0e320, 0x0000000007a0e750]
Event: 5809.049 Thread 0x0000000018cea000 58386 4 java.util.Arrays::binarySearch0 (95 bytes)
GC Heap History (10 events):
Event: 5624.825 GC heap before
{Heap before GC invocations=641 (full 1):
garbage-first heap total 1048576K, used 542388K [0x00000000c0000000, 0x00000000c0102000, 0x0000000100000000)
region size 1024K, 51 young (52224K), 3 survivors (3072K)
Metaspace used 191462K, capacity 208432K, committed 208884K, reserved 1230848K
class space used 22370K, capacity 26764K, committed 26952K, reserved 1048576K
Event: 5624.855 GC heap after
Heap after GC invocations=642 (full 1):
garbage-first heap total 1048576K, used 393312K [0x00000000c0000000, 0x00000000c0102000, 0x0000000100000000)
region size 1024K, 7 young (7168K), 7 survivors (7168K)
Event: 5624.932 GC heap before
{Heap before GC invocations=642 (full 1):
garbage-first heap total 1048576K, used 438368K [0x00000000c0000000, 0x00000000c0102000, 0x0000000100000000)
region size 1024K, 51 young (52224K), 7 survivors (7168K)
Metaspace used 191467K, capacity 208432K, committed 208884K, reserved 1230848K
Event: 5624.981 GC heap after
Heap after GC invocations=643 (full 1):
garbage-first heap total 1048576K, used 315430K [0x00000000c0000000, 0x00000000c0102000, 0x0000000100000000)
region size 1024K, 5 young (5120K), 5 survivors (5120K)
Event: 5641.978 GC heap before
{Heap before GC invocations=643 (full 1):
garbage-first heap total 1048576K, used 874534K [0x00000000c0000000, 0x00000000c0102000, 0x0000000100000000)
region size 1024K, 551 young (564224K), 5 survivors (5120K)
Metaspace used 191615K, capacity 208526K, committed 208884K, reserved 1230848K
class space used 22373K, capacity 26769K, committed 26952K, reserved 1048576K
Event: 5642.060 GC heap after
Heap after GC invocations=644 (full 1):
garbage-first heap total 1048576K, used 341542K [0x00000000c0000000, 0x00000000c0102000, 0x0000000100000000)
region size 1024K, 31 young (31744K), 31 survivors (31744K)
Event: 5657.814 GC heap before
{Heap before GC invocations=644 (full 1):
garbage-first heap total 1048576K, used 881190K [0x00000000c0000000, 0x00000000c0102000, 0x0000000100000000)
region size 1024K, 558 young (571392K), 31 survivors (31744K)
Metaspace used 192516K, capacity 209508K, committed 209780K, reserved 1232896K
class space used 22496K, capacity 26916K, committed 27080K, reserved 1048576K
Event: 5657.868 GC heap after
Heap after GC invocations=645 (full 1):
garbage-first heap total 1048576K, used 364582K [0x00000000c0000000, 0x00000000c0102000, 0x0000000100000000)
region size 1024K, 53 young (54272K), 53 survivors (54272K)
Event: 5704.221 GC heap before
{Heap before GC invocations=645 (full 1):
garbage-first heap total 1048576K, used 878630K [0x00000000c0000000, 0x00000000c0102000, 0x0000000100000000)
region size 1024K, 555 young (568320K), 53 survivors (54272K)
Metaspace used 192695K, capacity 209814K, committed 210036K, reserved 1232896K
class space used 22502K, capacity 26951K, committed 27080K, reserved 1048576K
Event: 5704.289 GC heap after
Heap after GC invocations=646 (full 1):
garbage-first heap total 1048576K, used 368459K [0x00000000c0000000, 0x00000000c0102000, 0x0000000100000000)
region size 1024K, 17 young (17408K), 17 survivors (17408K)
Deoptimization events (10 events):
Event: 5689.478 Thread 0x0000000019d6f800 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x000000000bbe50ac method=org.eclipse.jdt.internal.compiler.lookup.TypeVariableBinding.constantPoolName()[C @ 11
Event: 5695.273 Thread 0x0000000003040800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x000000000c7eefbc method=org.eclipse.jdt.internal.corext.util.MethodOverrideTester.isSubsignature(Lorg/eclipse/jdt/core/IMethod;Lorg/eclipse/jdt/core/IMethod;)Z @ 1
Event: 5697.926 Thread 0x0000000003040800 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x000000000bbb5eb4 method=org.eclipse.jdt.ui.ProblemsLabelDecorator.computeAdornmentFlags(Ljava/lang/Object;)I @ 234
Event: 5698.037 Thread 0x0000000003040800 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x000000000bca5c90 method=org.eclipse.jface.viewers.StyledCellLabelProvider.getSharedTextLayout(Lorg/eclipse/swt/widgets/Display;)Lorg/eclipse/swt/graphics/TextLayout; @ 11
Event: 5737.579 Thread 0x0000000003040800 Uncommon trap: reason=bimorphic action=maybe_recompile pc=0x0000000009baf848 method=org.eclipse.swt.widgets.Control.windowProc(JIJJ)J @ 1209
Event: 5751.256 Thread 0x0000000003040800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x000000000a27da54 method=org.eclipse.swt.widgets.Table.checkData(Lorg/eclipse/swt/widgets/TableItem;Z)Z @ 7
Event: 5809.044 Thread 0x0000000003040800 Uncommon trap: reason=unstable_if action=reinterpret pc=0x000000000b65b358 method=org.eclipse.swt.widgets.Display.messageProc(JJJJ)J @ 1297
Internal exceptions (10 events):
Event: 5687.796 Thread 0x0000000003040800 Exception <a 'java/lang/ArrayIndexOutOfBoundsException'> (0x00000000ef8e10b8) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u121\8372\hotspot\src\share\vm\runtime\sharedRuntime.cpp, line 605]
Event: 5687.796 Thread 0x0000000003040800 Exception <a 'java/lang/ArrayIndexOutOfBoundsException'> (0x00000000ef8e57f0) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u121\8372\hotspot\src\share\vm\runtime\sharedRuntime.cpp, line 605]
Event: 5687.796 Thread 0x0000000003040800 Exception <a 'java/lang/ArrayIndexOutOfBoundsException'> (0x00000000ef8ea4d8) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u121\8372\hotspot\src\share\vm\runtime\sharedRuntime.cpp, line 605]
Event: 5687.796 Thread 0x0000000003040800 Exception <a 'java/lang/ArrayIndexOutOfBoundsException'> (0x00000000ef8efc70) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u121\8372\hotspot\src\share\vm\runtime\sharedRuntime.cpp, line 605]
Event: 5687.797 Thread 0x0000000003040800 Exception <a 'java/lang/ArrayIndexOutOfBoundsException'> (0x00000000ef8f5198) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u121\8372\hotspot\src\share\vm\runtime\sharedRuntime.cpp, line 605]
Event: 5687.807 Thread 0x0000000019d6f800 Exception <a 'java/lang/ArrayIndexOutOfBoundsException': 2616> (0x00000000ef63d790) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u121\8372\hotspot\src\share\vm\interpreter\interpreterRuntime.cpp, line 366]
Event: 5689.473 Thread 0x0000000019d6f800 Exception <a 'java/lang/ArrayIndexOutOfBoundsException'> (0x00000000ef553c30) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u121\8372\hotspot\src\share\vm\runtime\sharedRuntime.cpp, line 605]
Event: 5693.965 Thread 0x0000000003040800 Exception <a 'java/lang/ArrayIndexOutOfBoundsException'> (0x00000000eeadcd20) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u121\8372\hotspot\src\share\vm\runtime\sharedRuntime.cpp, line 605]
Event: 5695.269 Thread 0x0000000003040800 Exception <a 'java/lang/ArrayIndexOutOfBoundsException'> (0x00000000ee9dece0) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u121\8372\hotspot\src\share\vm\runtime\sharedRuntime.cpp, line 605]
Event: 5695.622 Thread 0x0000000003040800 Exception <a 'java/lang/ArrayIndexOutOfBoundsException'> (0x00000000ee7090b8) thrown at [C:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u121\8372\hotspot\src\share\vm\runtime\sharedRuntime.cpp, line 605]
Events (10 events):
Event: 5803.445 loading class org/eclipse/jface/dialogs/PopupDialog
Event: 5803.445 loading class org/eclipse/jface/dialogs/PopupDialog done
Event: 5803.464 Thread 0x0000000018d3a000 flushing nmethod 0x0000000008e53c50
Event: 5803.464 Thread 0x0000000018d3a000 flushing nmethod 0x0000000008e70e10
Event: 5803.465 Thread 0x0000000018d3a000 flushing nmethod 0x0000000009080d90
Event: 5803.466 Thread 0x0000000018d3a000 flushing nmethod 0x0000000009334850
Event: 5803.466 Thread 0x0000000018d3a000 flushing nmethod 0x0000000009538e50
Event: 5809.044 Thread 0x0000000003040800 Uncommon trap: trap_request=0xffffff65 fr.pc=0x000000000b65b358
Event: 5809.044 Thread 0x0000000003040800 DEOPT PACKING pc=0x000000000b65b358 sp=0x0000000002ffd7d0
Event: 5809.044 Thread 0x0000000003040800 DEOPT UNPACKING pc=0x000000000318582a sp=0x0000000002ffd7c8 mode 2
Dynamic libraries:
0x00007ff7eed90000 - 0x00007ff7eedc7000 <...>\Oracle\Java\javapath\javaw.exe
0x00007ffb931c0000 - 0x00007ffb93391000 C:\WINDOWS\SYSTEM32\ntdll.dll
0x00007ffb90750000 - 0x00007ffb907fb000 C:\WINDOWS\System32\KERNEL32.DLL
0x00007ffb8fa50000 - 0x00007ffb8fc6d000 C:\WINDOWS\System32\KERNELBASE.dll
0x00007ffb90830000 - 0x00007ffb908d2000 C:\WINDOWS\System32\ADVAPI32.dll
0x00007ffb928e0000 - 0x00007ffb9297e000 C:\WINDOWS\System32\msvcrt.dll
0x00007ffb92640000 - 0x00007ffb92699000 C:\WINDOWS\System32\sechost.dll
0x00007ffb92d20000 - 0x00007ffb92e41000 C:\WINDOWS\System32\RPCRT4.dll
0x00007ffb92e50000 - 0x00007ffb92fb5000 C:\WINDOWS\System32\USER32.dll
0x00007ffb8fa30000 - 0x00007ffb8fa4e000 C:\WINDOWS\System32\win32u.dll
0x00007ffb929a0000 - 0x00007ffb929d4000 C:\WINDOWS\System32\GDI32.dll
0x00007ffb8fc70000 - 0x00007ffb8fdf2000 C:\WINDOWS\System32\gdi32full.dll
0x00007ffb82760000 - 0x00007ffb829d9000 C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.14393.447_none_42191651c6827bb3\COMCTL32.dll
0x00007ffb92a40000 - 0x00007ffb92d08000 C:\WINDOWS\System32\combase.dll
0x00007ffb8f820000 - 0x00007ffb8f915000 C:\WINDOWS\System32\ucrtbase.dll
0x00007ffb8f760000 - 0x00007ffb8f7ca000 C:\WINDOWS\System32\bcryptPrimitives.dll
0x00007ffb90800000 - 0x00007ffb9082e000 C:\WINDOWS\System32\IMM32.DLL
0x0000000067440000 - 0x0000000067512000 <...>\jre1.8.0_121\bin\msvcr100.dll
0x0000000066ba0000 - 0x000000006743b000 <...>\jre1.8.0_121\bin\server\jvm.dll
0x00007ffb90b80000 - 0x00007ffb90b88000 C:\WINDOWS\System32\PSAPI.DLL
0x00007ffb83650000 - 0x00007ffb83659000 C:\WINDOWS\SYSTEM32\WSOCK32.dll
0x00007ffb8e1d0000 - 0x00007ffb8e1da000 C:\WINDOWS\SYSTEM32\VERSION.dll
0x00007ffb92700000 - 0x00007ffb9276a000 C:\WINDOWS\System32\WS2_32.dll
0x00007ffb8d730000 - 0x00007ffb8d753000 C:\WINDOWS\SYSTEM32\WINMM.dll
0x00007ffb8d700000 - 0x00007ffb8d72b000 C:\WINDOWS\SYSTEM32\WINMMBASE.dll
0x00007ffb8f7d0000 - 0x00007ffb8f812000 C:\WINDOWS\System32\cfgmgr32.dll
0x0000000066b90000 - 0x0000000066b9f000 <...>\jre1.8.0_121\bin\verify.dll
0x0000000066b60000 - 0x0000000066b89000 <...>\jre1.8.0_121\bin\java.dll
0x0000000066b40000 - 0x0000000066b56000 <...>\jre1.8.0_121\bin\zip.dll
0x00007ffb90ba0000 - 0x00007ffb920a9000 C:\WINDOWS\System32\SHELL32.dll
0x00007ffb8fe00000 - 0x00007ffb904da000 C:\WINDOWS\System32\windows.storage.dll
0x00007ffb8f660000 - 0x00007ffb8f6ac000 C:\WINDOWS\System32\powrprof.dll
0x00007ffb929e0000 - 0x00007ffb92a32000 C:\WINDOWS\System32\shlwapi.dll
0x00007ffb8f620000 - 0x00007ffb8f62f000 C:\WINDOWS\System32\kernel.appcore.dll
0x00007ffb8f6b0000 - 0x00007ffb8f759000 C:\WINDOWS\System32\shcore.dll
0x00007ffb8f640000 - 0x00007ffb8f654000 C:\WINDOWS\System32\profapi.dll
0x00007ffb8f0f0000 - 0x00007ffb8f107000 C:\WINDOWS\SYSTEM32\CRYPTSP.dll
0x00007ffb8eb70000 - 0x00007ffb8eba3000 C:\WINDOWS\system32\rsaenh.dll
0x00007ffb8f560000 - 0x00007ffb8f58b000 C:\WINDOWS\SYSTEM32\bcrypt.dll
0x00007ffb8edd0000 - 0x00007ffb8edef000 C:\WINDOWS\SYSTEM32\USERENV.dll
0x00007ffb8f110000 - 0x00007ffb8f11b000 C:\WINDOWS\SYSTEM32\CRYPTBASE.dll
0x0000000066b20000 - 0x0000000066b3a000 <...>\jre1.8.0_121\bin\net.dll
0x00007ffb8ef50000 - 0x00007ffb8efac000 C:\WINDOWS\system32\mswsock.dll
0x00007ffb8ece0000 - 0x00007ffb8ed18000 C:\WINDOWS\SYSTEM32\IPHLPAPI.DLL
0x00007ffb92d10000 - 0x00007ffb92d18000 C:\WINDOWS\System32\NSI.dll
0x00007ffb8b3f0000 - 0x00007ffb8b406000 C:\WINDOWS\SYSTEM32\dhcpcsvc6.DLL
0x00007ffb8b3d0000 - 0x00007ffb8b3ea000 C:\WINDOWS\SYSTEM32\dhcpcsvc.DLL
0x0000000066b00000 - 0x0000000066b11000 <...>\jre1.8.0_121\bin\nio.dll
0x0000000072000000 - 0x0000000072012000 <...>\eclipse-java-neon-2-win32-x86_64\plugins\org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.401.v20161122-1740\eclipse_1617.dll
0x00007ffb8d900000 - 0x00007ffb8d995000 C:\WINDOWS\system32\uxtheme.dll
0x00007ffb920b0000 - 0x00007ffb9220b000 C:\WINDOWS\System32\MSCTF.dll
0x00007ffb90ac0000 - 0x00007ffb90b7f000 C:\WINDOWS\System32\OLEAUT32.dll
0x00007ffb904e0000 - 0x00007ffb9057c000 C:\WINDOWS\System32\msvcp_win.dll
0x000000001cae0000 - 0x000000001cb87000 <...>\eclipse-java-neon-2-win32-x86_64\configuration\org.eclipse.osgi\390\0\.cp\swt-win32-4628.dll
0x00007ffb90980000 - 0x00007ffb90ab7000 C:\WINDOWS\System32\ole32.dll
0x00007ffb92770000 - 0x00007ffb9286a000 C:\WINDOWS\System32\comdlg32.dll
0x00007ffb90580000 - 0x00007ffb90749000 C:\WINDOWS\System32\CRYPT32.dll
0x00007ffb8f630000 - 0x00007ffb8f640000 C:\WINDOWS\System32\MSASN1.dll
0x00007ffb88750000 - 0x00007ffb887d5000 C:\WINDOWS\SYSTEM32\WINSPOOL.DRV
0x00007ffb81320000 - 0x00007ffb81339000 C:\WINDOWS\SYSTEM32\USP10.dll
0x00007ffb837e0000 - 0x00007ffb83a73000 C:\WINDOWS\SYSTEM32\WININET.dll
0x00007ffb8d6a0000 - 0x00007ffb8d6c6000 C:\WINDOWS\system32\dwmapi.dll
0x00007ffb8b9f0000 - 0x00007ffb8bb75000 C:\WINDOWS\SYSTEM32\propsys.dll
0x00007ffb908e0000 - 0x00007ffb9097f000 C:\WINDOWS\System32\clbcatq.dll
0x00007ffb6f710000 - 0x00007ffb6f720000 C:\WINDOWS\SYSTEM32\LINKINFO.dll
0x000000001e0c0000 - 0x000000001e0de000 <...>\eclipse-java-neon-2-win32-x86_64\configuration\org.eclipse.osgi\390\0\.cp\swt-gdip-win32-4628.dll
0x00007ffb82390000 - 0x00007ffb8252a000 C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.14393.321_none_72fe05dd211a5fae\gdiplus.dll
0x00007ffb8c7f0000 - 0x00007ffb8c998000 C:\WINDOWS\SYSTEM32\WindowsCodecs.dll
0x0000000180000000 - 0x0000000180012000 <...>\eclipse-java-neon-2-win32-x86_64\configuration\org.eclipse.osgi\80\0\.cp\os\win32\x86_64\localfile_1_0_0.dll
0x00007ffb8e1e0000 - 0x00007ffb8e3e1000 <...> (x86)\Forefront TMG Client\FwcWsp64.dll
0x00007ffb8f920000 - 0x00007ffb8f975000 C:\WINDOWS\System32\WINTRUST.dll
0x00007ffb8e1b0000 - 0x00007ffb8e1c8000 C:\WINDOWS\SYSTEM32\NETAPI32.dll
0x00007ffb8e1a0000 - 0x00007ffb8e1aa000 C:\WINDOWS\SYSTEM32\DSROLE.DLL
0x00007ffb79450000 - 0x00007ffb79466000 C:\WINDOWS\system32\napinsp.dll
0x00007ffb79430000 - 0x00007ffb7944a000 C:\WINDOWS\system32\pnrpnsp.dll
0x00007ffb8cb50000 - 0x00007ffb8cb68000 C:\WINDOWS\system32\NLAapi.dll
0x00007ffb8ed20000 - 0x00007ffb8edc0000 C:\WINDOWS\SYSTEM32\DNSAPI.dll
0x00007ffb79470000 - 0x00007ffb7947e000 C:\WINDOWS\System32\winrnr.dll
0x00007ffb79480000 - 0x00007ffb79495000 C:\WINDOWS\System32\wshbth.dll
0x00007ffb8e000000 - 0x00007ffb8e192000 C:\WINDOWS\SYSTEM32\DBGHELP.DLL
0x000000001e1e0000 - 0x000000001e1e3000 C:\WINDOWS\SYSTEM32\security.dll
0x00007ffb8dff0000 - 0x00007ffb8dffc000 C:\WINDOWS\SYSTEM32\SECUR32.DLL
0x00007ffb8f2f0000 - 0x00007ffb8f31c000 C:\WINDOWS\SYSTEM32\SSPICLI.DLL
0x00007ffb8eee0000 - 0x00007ffb8ef47000 C:\WINDOWS\system32\msv1_0.DLL
0x00007ffb8eed0000 - 0x00007ffb8eedc000 C:\WINDOWS\SYSTEM32\NtlmShared.dll
0x00007ffb8efb0000 - 0x00007ffb8efc5000 C:\WINDOWS\SYSTEM32\cryptdll.dll
0x00007ffb877d0000 - 0x00007ffb877da000 C:\Windows\System32\rasadhlp.dll
0x00007ffb8c770000 - 0x00007ffb8c7da000 C:\WINDOWS\System32\fwpuclnt.dll
0x00007ffb86b30000 - 0x00007ffb86b41000 <...>\eclipse-java-neon-2-win32-x86_64\configuration\org.eclipse.osgi\83\0\.cp\jWinHttp-1.0.0.dll
0x00007ffb8bcc0000 - 0x00007ffb8bd8d000 C:\WINDOWS\SYSTEM32\WINHTTP.dll
0x00007ffb76dd0000 - 0x00007ffb76e35000 C:\WINDOWS\SYSTEM32\oleacc.dll
0x00007ffb74850000 - 0x00007ffb74857000 C:\WINDOWS\SYSTEM32\msimg32.dll
0x00007ffb6f900000 - 0x00007ffb6f93f000 C:\WINDOWS\system32\mlang.dll
0x0000000066ad0000 - 0x0000000066af4000 <...>\jre1.8.0_121\bin\sunec.dll
0x00007ffb76d80000 - 0x00007ffb76dc9000 C:\WINDOWS\system32\dataexchange.dll
0x00007ffb8bda0000 - 0x00007ffb8c056000 C:\WINDOWS\system32\d3d11.dll
0x00007ffb8ce60000 - 0x00007ffb8cfb1000 C:\WINDOWS\system32\dcomp.dll
0x00007ffb8e5b0000 - 0x00007ffb8e64f000 C:\WINDOWS\system32\dxgi.dll
0x00007ffb8dbe0000 - 0x00007ffb8dcfc000 C:\WINDOWS\system32\twinapi.appcore.dll
0x00007ffb83260000 - 0x00007ffb834c9000 C:\WINDOWS\SYSTEM32\DWrite.dll
0x00007ffb768d0000 - 0x00007ffb76d54000 C:\WINDOWS\system32\explorerframe.dll
0x00007ffb8ea40000 - 0x00007ffb8ea72000 C:\WINDOWS\SYSTEM32\ntmarta.dll
0x00007ffb8d310000 - 0x00007ffb8d38a000 C:\WINDOWS\SYSTEM32\apphelp.dll
0x00007ffb75cd0000 - 0x00007ffb75da2000 C:\WINDOWS\system32\ntshrui.dll
0x00007ffb7e3a0000 - 0x00007ffb7e3c6000 C:\WINDOWS\system32\srvcli.dll
0x00007ffb75f40000 - 0x00007ffb75f52000 C:\WINDOWS\SYSTEM32\cscapi.dll
0x00007ffb8edc0000 - 0x00007ffb8edcd000 C:\WINDOWS\system32\netutils.dll
0x00007ffb92870000 - 0x00007ffb928de000 C:\WINDOWS\System32\coml2.dll
0x00007ffb6e9f0000 - 0x00007ffb6eb17000 C:\WINDOWS\system32\NetworkExplorer.dll
0x00007ffb7e470000 - 0x00007ffb7e48b000 C:\WINDOWS\SYSTEM32\MPR.dll
0x00007ffb868d0000 - 0x00007ffb868e6000 C:\WINDOWS\System32\ntlanman.dll
0x00007ffb8d5c0000 - 0x00007ffb8d5cb000 C:\WINDOWS\System32\drprov.dll
0x00007ffb8e750000 - 0x00007ffb8e7a6000 C:\WINDOWS\System32\WINSTA.dll
0x00007ffb836b0000 - 0x00007ffb836d0000 C:\WINDOWS\System32\davclnt.dll
0x00007ffb86af0000 - 0x00007ffb86afc000 C:\WINDOWS\System32\DAVHLPR.dll
0x0000000066ac0000 - 0x0000000066acb000 <...>\jre1.8.0_121\bin\sunmscapi.dll
0x00007ffb8f4c0000 - 0x00007ffb8f558000 C:\WINDOWS\SYSTEM32\sxs.dll
0x00007ffb75c70000 - 0x00007ffb75cc3000 C:\Windows\System32\thumbcache.dll
0x00007ffb84100000 - 0x00007ffb84143000 C:\WINDOWS\SYSTEM32\policymanager.dll
0x00007ffb8dd00000 - 0x00007ffb8dd91000 C:\WINDOWS\SYSTEM32\msvcp110_win.dll
0x00007ffb84210000 - 0x00007ffb844b3000 C:\Windows\System32\iertutil.dll
0x00007ffb83a90000 - 0x00007ffb83c52000 C:\WINDOWS\SYSTEM32\urlmon.dll
0x00007ffb43f70000 - 0x00007ffb4561c000 C:\Windows\System32\mshtml.dll
0x00007ffb6f8d0000 - 0x00007ffb6f8f6000 C:\Windows\System32\srpapi.dll
0x00007ffb6f180000 - 0x00007ffb6f317000 C:\Windows\System32\ieapfltr.dll
0x00007ffb4cbd0000 - 0x00007ffb4d061000 C:\Windows\System32\jscript9.dll
0x00007ffb78710000 - 0x00007ffb78752000 C:\WINDOWS\SYSTEM32\edputil.dll
0x00007ffb7e490000 - 0x00007ffb7e4a5000 C:\WINDOWS\SYSTEM32\ondemandconnroutehelper.dll
VM Arguments:
jvm_args: -Dosgi.requiredJavaVersion=1.8 -XX:+UseG1GC -XX:+UseStringDeduplication -Dosgi.requiredJavaVersion=1.8 -Xms256m -Xmx1024m
java_command: <...>\eclipse-java-neon-2-win32-x86_64\\plugins/org.eclipse.equinox.launcher_1.3.201.v20161025-1711.jar -os win32 -ws win32 -arch x86_64 -showsplash <...>\eclipse-java-neon-2-win32-x86_64\\plugins\org.eclipse.platform_4.6.2.v20161124-1400\splash.bmp -launcher <...>\eclipse-java-neon-2-win32-x86_64\eclipse.exe -name Eclipse --launcher.library <...>\eclipse-java-neon-2-win32-x86_64\\plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.401.v20161122-1740\eclipse_1617.dll -startup <...>\eclipse-java-neon-2-win32-x86_64\\plugins/org.eclipse.equinox.launcher_1.3.201.v20161025-1711.jar --launcher.appendVmargs -exitdata 1694_dc -product org.eclipse.epp.package.java.product -vm <...>\Oracle\Java\javapath\javaw.exe -vmargs -Dosgi.requiredJavaVersion=1.8 -XX:+UseG1GC -XX:+UseStringDeduplication -Dosgi.requiredJavaVersion=1.8 -Xms256m -Xmx1024m -jar <...>\eclipse-java-neon-2-win32-x86_64\\plugins/org.eclipse.equinox.launcher_1.3.201.v20161025-1711.jar
java_class_path (initial): <...>\eclipse-java-neon-2-win32-x86_64\\plugins/org.eclipse.equinox.launcher_1.3.201.v20161025-1711.jar
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=<...>\bin\Sencha\Cmd\5.1.3.61;<...>\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;<...>\Git\cmd;<...> (x86)\Vagrant\bin;C:\Ruby23-x64\bin;<...> (x86)\RobAutocopy;<...>\nodejs\;<...>\AppData\Local\Microsoft\WindowsApps;<...>\AppData\Local\atom\bin;<...>\AppData\Roaming\npm
USERNAME=NB14770
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 78 Stepping 3, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 10.0 , 64 bit Build 14393 (10.0.14393.0)
CPU:total 4 (2 cores per cpu, 2 threads per core) family 6 model 78 stepping 3, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, avx2, aes, clmul, erms, 3dnowpref, lzcnt, ht, tsc, tscinvbit, bmi1, bmi2, adx
Memory: 4k page, physical 16654940k(6961988k free), swap 19145308k(7827480k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (25.121-b13) for windows-amd64 JRE (1.8.0_121-b13), built on Dec 12 2016 18:21:36 by "java_re" with MS VC++ 10.0 (VS2010)
time: Wed Mar 22 12:00:42 2017
elapsed time: 5809 seconds (0d 1h 36m 49s)
[Updated on: Thu, 23 March 2017 17:24] Report message to a moderator
Current Time: Thu Apr 25 09:17:00 GMT 2024
Powered by FUDForum. Page generated in 0.08497 seconds
