Home » Archived » XML Schema Definition (XSD) » Bug in validation?
Re: Bug in validation? [message #33651 is a reply to message #33614] |
Tue, 25 November 2003 23:32 |
--------------3F6A288FBD1C346E8D762FE9
Content-Type: text/plain; charset=us-ascii
Lance,
When in an earlier note I said:
I've never tried unloading an XSDResourceImpl. The complex
include/import/redefine interdependencies between .xsd files makes
unloading just one .xsd resource likely not to work well.
I really wasn't kidding. Rebuilding a valid XSD model after trashing just single
..xsd resource simply doesn't work unless it is the "root" schema, i.e., any .xsd that
depends on the trashed .xsd will also need to be unloaded. Features like element
substitution groups even produce nasty back pointers from the group head out to group
members because a group head is defined to act as a <choice> of all the members of
the group; so if in doubt, unload it...
Lance Phillips wrote:
> Ed,
> I'm still after this problem where my problem markers do not seem to be
> correctly getting cleaned up when doing a validate after fixing a problem in
> an schema. Here is the scenario... Two Xsd files, one imports the other.
> Load them both into a ResourceSet and Validate. I get no errors. Delete
> the imported Xsd and run validation on the importing schema... I get an
> error (as expected). Re-load the imported schema and re-run validation. I
> still get validation errors when I wouldn't expect to.... I've attached a
> PdeJunit test that can be run. The last test is failing where I re-add the
> imported XSD back into the ResourceSet and revalidate the importing schema.
> I still end up with validation errors.....
> Obviously you won't be able to run the test case as is since I can not
> send the models or the referenced Metamatrix utility class... but you should
> be able to capture the spirit of the problem with this test case ;)
> thanks,
> lp
> PdeTestXsdValidation.java Type: unspecified type (application/octet-stream)
> Encoding: x-uuencode
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Lance,
<p>When in an earlier note I said:
<blockquote>I've never tried unloading an XSDResourceImpl. The complex
include/import/redefine interdependencies between .xsd files makes unloading
just one .xsd resource likely not to work well.</blockquote>
just single .xsd resource simply doesn't work unless it is the "root" schema,
i.e., any .xsd that depends on the trashed .xsd will also need to be unloaded.
Features like element substitution groups even produce nasty back pointers
from the group head out to group members because a group head is defined
to act as a <choice> of all the members of the group; so if in doubt,
unload it...
<br>
<p>Lance Phillips wrote:
<blockquote TYPE=CITE>Ed,
<br> I'm still after this problem where my problem markers
do not seem to be
<br>correctly getting cleaned up when doing a validate after fixing a problem
in
<br>an schema. Here is the scenario... Two Xsd files, one imports
the other.
<br>Load them both into a ResourceSet and Validate. I get no errors.
Delete
<br>the imported Xsd and run validation on the importing schema... I get
an
<br>error (as expected). Re-load the imported schema and re-run validation.
I
<br>still get validation errors when I wouldn't expect to.... I've
attached a
<br>PdeJunit test that can be run. The last test is failing where
I re-add the
<br>imported XSD back into the ResourceSet and revalidate the importing
schema.
<br>I still end up with validation errors.....
<p> Obviously you won't be able to run the test case
<br>send the models or the referenced Metamatrix utility class... but you
should
<br>be able to capture the spirit of the problem with this test case ;)
<p>thanks,
<p>lp
<p>
<br> PdeTestXsdValidation.java Type: unspecified
<br>
Encoding: x-uuencode</blockquote>
</html>
--------------3F6A288FBD1C346E8D762FE9--
Re: Bug in validation? [message #33680 is a reply to message #33651] |
Wed, 26 November 2003 13:52 |
Lance Phillips Messages: 210 Registered: July 2009 |
------=_NextPart_000_000D_01C3B3F2.30886AD0
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Wow, that certainly is bad news. I think this is the first time you've =
ever given us a really bad answer ;)
We run this builder as validation. Thus it is very nice for the user to =
be able to run validation PRIOR to performing a save. However, if I =
have to unload and reload all schemas to ensure validation is correct =
we'll have to force the user to save any XSD files prior to performing =
validation so that I can blow them all away and reload them. That is =
really going to suck for performance as well! If I unload a schema and =
reload it, do I even need to do the validation, or can I simply ask for =
the diagnostics? Also, what is the impact of unloading / reloading an =
XSD that is open in an editor... will the editor behave or barf?
thanks,
lp
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:3FC3E68A.8079E6F3@ca.ibm.com...
Lance,=20
When in an earlier note I said:=20
I've never tried unloading an XSDResourceImpl. The complex =
include/import/redefine interdependencies between .xsd files makes =
I really wasn't kidding. Rebuilding a valid XSD model after trashing =
just single .xsd resource simply doesn't work unless it is the "root" =
schema, i.e., any .xsd that depends on the trashed .xsd will also need =
to be unloaded. Features like element substitution groups even produce =
nasty back pointers from the group head out to group members because a =
group head is defined to act as a <choice> of all the members of the =
group; so if in doubt, unload it...=20
=20
Lance Phillips wrote:=20
Ed,=20
I'm still after this problem where my problem markers do not =
seem to be=20
correctly getting cleaned up when doing a validate after fixing a =
problem in=20
an schema. Here is the scenario... Two Xsd files, one imports the =
other.=20
Load them both into a ResourceSet and Validate. I get no errors. =
Delete=20
the imported Xsd and run validation on the importing schema... I get =
an=20
error (as expected). Re-load the imported schema and re-run =
validation. I=20
still get validation errors when I wouldn't expect to.... I've =
attached a=20
PdeJunit test that can be run. The last test is failing where I =
re-add the=20
imported XSD back into the ResourceSet and revalidate the importing =
schema.=20
I still end up with validation errors.....=20
Obviously you won't be able to run the test case as is since I =
can not=20
send the models or the referenced Metamatrix utility class... but =
you should=20
be able to capture the spirit of the problem with this test case ;)=20
thanks,=20
lp=20
PdeTestXsdValidation.java Type: unspecified type =
(application/octet-stream)=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1276" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Wow, that certainly is bad news. =
I think this=20
is the first time you've ever given us a really bad answer =
;)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>We run this builder =
as validation. Thus=20
it is very nice for the user to be able to run validation PRIOR to =
performing a=20
save. However, if I have to unload and reload all schemas to =
ensure=20
validation is correct we'll have to force the user to save any XSD files =
prior=20
to performing validation so that I can blow them all away and reload =
them. =20
That is really going to suck for performance as well! If I unload =
a schema=20
and reload it, do I even need to do the validation, or can I simply ask =
for the=20
XSD that=20
is open in an editor... will the editor behave or barf?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>thanks,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>lp</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:3FC3E68A.8079E6F3@ca.ibm.com">news:3FC3E68A.8079E6F3@ca.ibm.=
com</A>...</DIV>Lance,=20
<P>When in an earlier note I said:=20
<BLOCKQUOTE>I've never tried unloading an XSDResourceImpl. The =
complex=20
unloading=20
just one .xsd resource likely not to work well.</BLOCKQUOTE>I really =
wasn't=20
kidding. Rebuilding a valid XSD model after trashing just single =
..xsd=20
resource simply doesn't work unless it is the "root" schema, i.e., any =
..xsd=20
that depends on the trashed .xsd will also need to be unloaded. =
Features=20
like element substitution groups even produce nasty back pointers from =
the=20
group head out to group members because a group head is defined to act =
as a=20
<choice> of all the members of the group; so if in doubt, unload =
it...=20
<BR> =20
<P>Lance Phillips wrote:=20
<BLOCKQUOTE TYPE=3D"CITE">Ed, <BR> I'm still after =
this=20
problem where my problem markers do not seem to be <BR>correctly =
getting=20
cleaned up when doing a validate after fixing a problem in <BR>an=20
other.=20
<BR>Load them both into a ResourceSet and Validate. I get no=20
errors. Delete <BR>the imported Xsd and run validation on the=20
importing schema... I get an <BR>error (as expected). Re-load =
the=20
imported schema and re-run validation. I <BR>still get =
validation=20
errors when I wouldn't expect to.... I've attached a =
<BR>PdeJunit test=20
that can be run. The last test is failing where I re-add the=20
<BR>imported XSD back into the ResourceSet and revalidate the =
importing=20
schema. <BR>I still end up with validation errors.....=20
<P> Obviously you won't be able to run the test =
case as is=20
since I can not <BR>send the models or the referenced Metamatrix =
utility=20
class... but you should <BR>be able to capture the spirit of the =
problem=20
<P>thanks,=20
<P>lp=20
<P> &nbs=
p; &nbs p; &nbs p=
;   ; =20
Name: PdeTestXsdValidation.java <BR> =20
PdeTestXsdValidation.java Type: unspecified type=20
<BR> &nb=
sp; &nb sp; &nb s=
p; =20
Encoding: x-uuencode</P></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_000D_01C3B3F2.30886AD0--
Re: Bug in validation? [message #33706 is a reply to message #33680] |
Wed, 26 November 2003 17:19 |
--------------4EFC86FE32D865D323BE7F0A
Lance,
I tell it like it is... ;-)
XML Schema as some horrible dependency issues between files. A schema
that is valid in one context may not be valid in another. In fact,
simply by resolving an import, you may go from having a valid schema to
having an invalid one. There really isn't a such notion as global
correctness, it's all a relative thing given a set of root schemas.
I'm not really sure what kind of global state you are maintaining or the
context in which you are doing the unload. Each sample editor maintains
it's own local state and it does no listening for workbench deltas, so
it won't know that you've saved anything.
> you've ever given us a really bad answer ;) We run this builder as
> validation. Thus it is very nice for the user to be able to run
> validation PRIOR to performing a save. However, if I have to unload
> and reload all schemas to ensure validation is correct we'll have to
> force the user to save any XSD files prior to performing validation so
> that I can blow them all away and reload them. That is really going
> to suck for performance as well! If I unload a schema and reload it,
> do I even need to do the validation, or can I simply ask for the
> diagnostics? Also, what is the impact of unloading / reloading an XSD
> barf? thanks, lp
> news:3FC3E68A.8079E6F3@ca.ibm.com...Lance,
> The complex include/import/redefine
> work well.
> trashing just single .xsd resource simply doesn't work
> unless it is the "root" schema, i.e., any .xsd that depends
> members of the group; so if in doubt, unload it...
> > Ed,
> > do not seem to be
> > fixing a problem in
> > imports the other.
> > errors. Delete
> > schema... I get an
> > I've attached a
> > where I re-add the
> > importing schema.
> > since I can not
> > test case ;)
> > thanks,
> > lp
> > Name:
<html>
<body bgcolor="#FFFFFF">
Lance,
<p>I tell it like it is... ;-)
<p>XML Schema as some horrible dependency issues between files. A
schema that is valid in one context may not be valid in another.
In fact, simply by resolving an import, you may go from having a valid
schema to having an invalid one. There really isn't a such notion
as global correctness, it's all a relative thing given a set of root schemas.
<br>
<blockquote TYPE=CITE><style></style>
<font face="Arial"><font size=-1>Wow,
ever given us a really bad answer ;)</font></font> <font face="Arial"><font size=-1>We
to be able to run validation PRIOR to performing a save. However,
if I have to unload and reload all schemas to ensure validation is correct
is really going to suck for performance as well! If I unload a schema
for the diagnostics? Also, what is the impact of unloading / reloading
an XSD that is open in an editor... will the editor behave or barf?</font></font> <font face="Arial"><font size=-1>thanks,</font></font> <font face="Arial"><font size=-1>lp</font></font>
<blockquote dir=ltr
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">"Ed
Merks" <<a href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>> wrote
in message <a href="news:3FC3E68A.8079E6F3@ca.ibm.com">news:3FC3E68A.8079E6F3@ca.ibm.com</a>...Lance,
unload it...
<br>
<blockquote TYPE="CITE">Ed,
do not seem to be
in
the other.
Delete
an
I
attached a
I re-add the
schema.
should
<p>thanks,
<p>lp
<p>
<br>
</blockquote>
</blockquote>
</body>
</html>
--------------4EFC86FE32D865D323BE7F0A--
Re: Bug in validation? [message #581139 is a reply to message #33614] |
Ed Merks Messages: 33141 Registered: July 2009 |
Lance,
> Ed,
> thanks,
> lp
<html>
Lance,
unload it...
<br>
do not seem to be
in
the other.
Delete
an
I
attached a
I re-add the
schema.
should
<p>thanks,
<p>lp
<p>
<br>
</html>
Ed Merks
Re: Bug in validation? [message #581159 is a reply to message #33651] |
thanks,
lp
Lance,=20
=20
Ed,=20
seem to be=20
problem in=20
other.=20
Delete=20
an=20
validation. I=20
attached a=20
re-add the=20
schema.=20
can not=20
you should=20
thanks,=20
lp=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
I think this=20
;)</FONT></DIV>
performing a=20
ensure=20
prior=20
them. =20
a schema=20
for the=20
XSD that=20
complex=20
unloading=20
wasn't=20
..xsd=20
..xsd=20
Features=20
the=20
as a=20
it...=20
<BR> =20
this=20
getting=20
other.=20
the=20
validation=20
importing=20
case as is=20
utility=20
problem=20
<P>thanks,=20
<P>lp=20
<P> &nbs=
p; &nbs p; &nbs p=
;   ; =20
<BR> &nb=
sp; &nb sp; &nb s=
p; =20
Re: Bug in validation? [message #581181 is a reply to message #33680] |
Lance,
> barf? thanks, lp
> work well.
> > Ed,
> > do not seem to be
> > fixing a problem in
> > imports the other.
> > errors. Delete
> > schema... I get an
> > I've attached a
> > where I re-add the
> > importing schema.
> > since I can not
> > test case ;)
> > thanks,
> > lp
> > Name:
<html>
Lance,
<br>
<blockquote dir=ltr
unload it...
<br>
do not seem to be
in
the other.
Delete
an
I
attached a
I re-add the
schema.
should
<p>thanks,
<p>lp
<p>
<br>
</blockquote>
</blockquote>
</body>
</html>
Ed Merks
Current Time: Thu Apr 25 16:43:18 GMT 2024
Powered by FUDForum. Page generated in 0.03738 seconds
