Home » Archived » Eclipse Process Manager (Stardust) » tomcat startup exception(Cannot find class [com.infinity.bpm.rt.integration.spring.jms.JmsResourceRefBinding] )
tomcat startup exception [message #1757825] Mon, 20 March 2017 11:16
chris suen is currently offline chris suenFriend
I was following this https://wiki.eclipse.org/Stardust/Knowledge_Base/Deployment/SpringConfigurations
when I got the following exception during tomcat startup. Can someone assist?
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.springframework.beans.factory.config.CustomScopeConfigurer#1' defined in URL [jar:file:/C:/eclipse-neon2/workspace/.metadata/.plugins/org.eclipse.wst.server.core/tmp2/wtpwebapps/JMStest/WEB-INF/lib/stardust-web-modeler.jar!/META-INF/spring/ipp-web-modeler-context.xml]: Cannot create inner bean 'org.eclipse.stardust.ui.web.modeler.integration.spring.scope.ModelingSessionScopeProvider#4d80c4' of type [org.eclipse.stardust.ui.web.modeler.integration.spring.scope.ModelingSessionScopeProvider] while setting bean property 'scopes' with key [TypedStringValue: value [modelingSession], target type [null]]; nested exception is org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'org.eclipse.stardust.ui.web.modeler.integration.spring.scope.ModelingSessionScopeProvider#4d80c4' defined in URL [jar:file:/C:/eclipse-neon2/workspace/.metadata/.plugins/org.eclipse.wst.server.core/tmp2/wtpwebapps/JMStest/WEB-INF/lib/stardust-web-modeler.jar!/META-INF/spring/ipp-web-modeler-context.xml]: Unsatisfied dependency expressed through constructor argument with index 0 of type [org.eclipse.stardust.ui.web.modeler.common.ModelingSessionLocator]: : Cannot find class [com.infinity.bpm.rt.integration.spring.jms.JmsResourceRefBinding] for bean with name 'com.infinity.bpm.rt.integration.spring.jms.JmsResourceRefBinding#0' defined in ServletContext resource [/WEB-INF/config/ipp/spring/carnot-spring-jms-context.xml]; nested exception is java.lang.ClassNotFoundException: com.infinity.bpm.rt.integration.spring.jms.JmsResourceRefBinding; nested exception is org.springframework.beans.factory.CannotLoadBeanClassException: Cannot find class [com.infinity.bpm.rt.integration.spring.jms.JmsResourceRefBinding] for bean with name 'com.infinity.bpm.rt.integration.spring.jms.JmsResourceRefBinding#0' defined in ServletContext resource [/WEB-INF/config/ipp/spring/carnot-spring-jms-context.xml]; nested exception is java.lang.ClassNotFoundException: com.infinity.bpm.rt.integration.spring.jms.JmsResourceRefBinding
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:287)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:122)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveManagedMap(BeanDefinitionValueResolver.java:384)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:165)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1419)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1160)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:458)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:293)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:223)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:290)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:195)
at org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1127)
at org.springframework.context.support.AbstractApplicationContext.invokeBeanFactoryPostProcessors(AbstractApplicationContext.java:679)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:461)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:410)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:306)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:112)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:5118)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5634)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:145)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1571)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1561)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Caused by: org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'org.eclipse.stardust.ui.web.modeler.integration.spring.scope.ModelingSessionScopeProvider#4d80c4' defined in URL [jar:file:/C:/eclipse-neon2/workspace/.metadata/.plugins/org.eclipse.wst.server.core/tmp2/wtpwebapps/JMStest/WEB-INF/lib/stardust-web-modeler.jar!/META-INF/spring/ipp-web-modeler-context.xml]: Unsatisfied dependency expressed through constructor argument with index 0 of type [org.eclipse.stardust.ui.web.modeler.common.ModelingSessionLocator]: : Cannot find class [com.infinity.bpm.rt.integration.spring.jms.JmsResourceRefBinding] for bean with name 'com.infinity.bpm.rt.integration.spring.jms.JmsResourceRefBinding#0' defined in ServletContext resource [/WEB-INF/config/ipp/spring/carnot-spring-jms-context.xml]; nested exception is java.lang.ClassNotFoundException: com.infinity.bpm.rt.integration.spring.jms.JmsResourceRefBinding; nested exception is org.springframework.beans.factory.CannotLoadBeanClassException: Cannot find class [com.infinity.bpm.rt.integration.spring.jms.JmsResourceRefBinding] for bean with name 'com.infinity.bpm.rt.integration.spring.jms.JmsResourceRefBinding#0' defined in ServletContext resource [/WEB-INF/config/ipp/spring/carnot-spring-jms-context.xml]; nested exception is java.lang.ClassNotFoundException: com.infinity.bpm.rt.integration.spring.jms.JmsResourceRefBinding
at org.springframework.beans.factory.support.ConstructorResolver.createArgumentArray(ConstructorResolver.java:752)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:193)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1077)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:981)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:487)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:276)
... 26 more
Caused by: org.springframework.beans.factory.CannotLoadBeanClassException: Cannot find class [com.infinity.bpm.rt.integration.spring.jms.JmsResourceRefBinding] for bean with name 'com.infinity.bpm.rt.integration.spring.jms.JmsResourceRefBinding#0' defined in ServletContext resource [/WEB-INF/config/ipp/spring/carnot-spring-jms-context.xml]; nested exception is java.lang.ClassNotFoundException: com.infinity.bpm.rt.integration.spring.jms.JmsResourceRefBinding
at org.springframework.beans.factory.support.AbstractBeanFactory.resolveBeanClass(AbstractBeanFactory.java:1278)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.predictBeanType(AbstractAutowireCapableBeanFactory.java:575)
at org.springframework.beans.factory.support.AbstractBeanFactory.isFactoryBean(AbstractBeanFactory.java:1347)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.doGetBeanNamesForType(DefaultListableBeanFactory.java:358)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeanNamesForType(DefaultListableBeanFactory.java:327)
at org.springframework.beans.factory.BeanFactoryUtils.beanNamesForTypeIncludingAncestors(BeanFactoryUtils.java:186)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.findAutowireCandidates(DefaultListableBeanFactory.java:906)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.doResolveDependency(DefaultListableBeanFactory.java:864)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.resolveDependency(DefaultListableBeanFactory.java:779)
at org.springframework.beans.factory.support.ConstructorResolver.resolveAutowiredArgument(ConstructorResolver.java:817)
at org.springframework.beans.factory.support.ConstructorResolver.createArgumentArray(ConstructorResolver.java:745)
... 32 more
Caused by: java.lang.ClassNotFoundException: com.infinity.bpm.rt.integration.spring.jms.JmsResourceRefBinding
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1892)
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1735)
at org.springframework.util.ClassUtils.forName(ClassUtils.java:265)
at org.springframework.beans.factory.support.AbstractBeanDefinition.resolveBeanClass(AbstractBeanDefinition.java:419)
at org.springframework.beans.factory.support.AbstractBeanFactory.doResolveBeanClass(AbstractBeanFactory.java:1299)
at org.springframework.beans.factory.support.AbstractBeanFactory.resolveBeanClass(AbstractBeanFactory.java:1270)
... 42 more
Mar 20, 2017 6:58:04 PM org.apache.catalina.core.StandardContext listenerStart
SEVERE: Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
... 26 more
... 32 more
... 42 more
Previous Topic:spi programming examples
Next Topic:Documentation: multilingual/tanslations available?
Current Time: Thu Sep 23 06:08:03 GMT 2021
Powered by FUDForum. Page generated in 0.01933 seconds
