Home » Modeling » EMF » transformation to "Requiements diagram"(M2Text)
transformation to "Requiements diagram" [message #1757797] Mon, 20 March 2017 00:16 Go to next message
khalid nasr is currently offline khalid nasrFriend
No Message Body
[Updated on: Fri, 24 March 2017 20:59]
Report message to a moderator
Re: transformation to "Requiements diagram" [message #1757802 is a reply to message #1757797] Mon, 20 March 2017 04:28 Go to previous messageGo to next message
Given you want to generate sysml (requirement diagram), doesn't that you mean you want sysml (requirement diagram) file format?
Ed Merks
Re: transformation to "Requiements diagram" [message #1757823 is a reply to message #1757802] Mon, 20 March 2017 11:04 Go to previous messageGo to next message
No Message Body
[Updated on: Fri, 24 March 2017 20:58]
Re: transformation to "Requiements diagram" [message #1757831 is a reply to message #1757823] Mon, 20 March 2017 13:57 Go to previous messageGo to next message
What kind of answer are you expecting to a question that's effectively "how do I generate text that conforms to some format Foo"? Not only that, I have to wonder, is generating a text file really the best way? Probably generating the model instance and serializing that is the better way. Why did you decide on this approach? What have you done so far to answer your own questions?
Ed Merks
Re: transformation to "Requiements diagram" [message #1757834 is a reply to message #1757831] Mon, 20 March 2017 14:23 Go to previous messageGo to next message
Re: transformation to "Requiements diagram" [message #1757863 is a reply to message #1757834] Mon, 20 March 2017 20:56 Go to previous messageGo to next message
I noticed you didn't answer any of my questions and that you are simply repeating yourself. You shouldn't expect much from that approach.
Ed Merks
Re: transformation to "Requiements diagram" [message #1757898 is a reply to message #1757863] Tue, 21 March 2017 13:56 Go to previous messageGo to next message
[Updated on: Fri, 24 March 2017 21:00]
Re: transformation to "Requiements diagram" [message #1757911 is a reply to message #1757898] Tue, 21 March 2017 17:44 Go to previous messageGo to next message
Ideal would seem a model to model transformation technology (or just Java code) to create an instance of the SYSML model and then serialize it. I think Papyrus support for SYSML so I suppose they have an Ecore model for it. But note that this is the EMF forum, not the M2T, M2M, nor Papyrus forum.
Ed Merks
Re: transformation to "Requiements diagram" [message #1757920 is a reply to message #1757911] Tue, 21 March 2017 20:34 Go to previous messageGo to next message
Thanks a lot M. Merks For your patience
Re: transformation to "Requiements diagram" [message #1758230 is a reply to message #1757920] Sat, 25 March 2017 06:24 Go to previous messageGo to next message
I'm not sure the point in deleting a bunch of your messages, but it's poor behavior. Answering questions takes effort but the answers can be useful for other people. That's no longer the case if you delete the question.
Ed Merks
Re: transformation to "Requiements diagram" [message #1758329 is a reply to message #1758230] Mon, 27 March 2017 17:08 Go to previous message
Denis Roy is currently offline Denis RoyFriend
Agree that it's poor behaviour. This person contacted the forum moderator about a response in another thread, where, as is the case here, all the poster's questions and comments have been deleted.
Denis Roy
Eclipse Webmaster -- webmaster@eclipse.org
Previous Topic:[CDO] Client side ID generation
Next Topic:[EMF/EMFForms] RCP Bundle Dependencies / Requirements Guide
Current Time: Sat Mar 06 06:47:16 GMT 2021
Powered by FUDForum. Page generated in 0.02594 seconds
