Home » Modeling » Papyrus » C++ example loading fails
C++ example loading fails [message #1756472] Fri, 17 March 2017 14:11 Go to next message
Stephen Blackwell is currently offline Stephen BlackwellFriend
I tried to created the Papyrus C/C++ hello world example and it failed.
File->New->Example...
Select Papyrus Examples->C/C++ hello world example
index.php/fa/28788/0/
Am I missing something?
Steve
Re: C++ example loading fails [message #1757808 is a reply to message #1756472] Mon, 20 March 2017 08:30 Go to previous messageGo to next message
Ansgar Radermacher is currently offline Ansgar RadermacherFriend
Hi Stephen,
there has been a problem with the path to the class loading the example. This has been corrected and the examples have been restructured. The example you are looking is in the category "Papyrus designer examples based on direct code generation"
We will make a new release soon, in the mean-time you can use the nightly update-site:
https://hudson.eclipse.org/papyrus/view/Designer/job/papyrus-designer-neon-papyrusnightly/ws/releng/org.eclipse.papyrus.designer.p2/target/repository/
Re: C++ example loading fails [message #1757981 is a reply to message #1757808] Wed, 22 March 2017 14:08 Go to previous messageGo to next message
Thanks, I'll check it out.
Steve
Re: C++ example loading fails [message #1758125 is a reply to message #1757981] Thu, 23 March 2017 17:48 Go to previous message
It looks like I will have to wait for the official release. I'm behind a proxy that does not allow https.
Previous Topic:To SYML
Next Topic:Custom Diagram for DSML
Current Time: Tue Oct 15 01:19:46 GMT 2024
Powered by FUDForum. Page generated in 0.25355 seconds
