Home » Language IDEs » Java Development Tools (JDT) » Only add JREContainerEntry when not yet set(Programmatically update JREContainerEntry when JavaProject doesnt contain one)
Only add JREContainerEntry when not yet set [message #1756440] Thu, 16 March 2017 17:36 Go to next message
Hello everyone.
I am working on a importer for Bndtools and facing the problem that I dont want to add a JRE-Container if the Java-Project which has existing settings already has one.
List<IClasspathEntry> entries = new ArrayList<>(Arrays.asList(javaProject.getRawClasspath()));
entries.add(JavaRuntime.getDefaultJREContainerEntry());
javaProject.setRawClasspath(entries.toArray(new IClasspathEntry[entries.size()]), monitor);
Thats what I am doing now, but this way, I could easily end up with two Container within the project. For example the java-project which I create already defined a JRE-7 container, but in my environment JRE-8 is the default. Unfortunately, the ClasspathEntries provide no real information which I could use to check if this entry is a JRE-container.
So, how can I check if a Java project has a JRE-container?
[Updated on: Thu, 16 March 2017 17:38] by Moderator
Re: Only add JREContainerEntry when not yet set [message #1756447 is a reply to message #1756440] Fri, 17 March 2017 00:31 Go to previous messageGo to next message
It seems to me that you can use org.eclipse.jdt.core.IClasspathEntry.getEntryKind() and test for org.eclipse.jdt.core.IClasspathEntry.CPE_CONTAINER. And in that case, if it's a JRE container, the path will conform to what's described in org.eclipse.jdt.launching.JavaRuntime.JRE_CONTAINER. Perhaps there's a better way...
Re: Only add JREContainerEntry when not yet set [message #1756500 is a reply to message #1756447] Fri, 17 March 2017 16:49 Go to previous message
Thanks for the idea Ed.
edited:
The previous message was wrong because my workspace was already corrupted so that Classpath-entries were missing.
This is what I ended up with and seems to work for now
        boolean jreContainerAvailable = false;
        for (IClasspathEntry entry : entries) {
            if (entry.getEntryKind() == IClasspathEntry.CPE_CONTAINER && entry.getPath() != null && entry.getPath().toString().startsWith(JavaRuntime.JRE_CONTAINER)) {
                jreContainerAvailable = true;
                break;
        if (!jreContainerAvailable) {
[Updated on: Tue, 21 March 2017 08:10] by Moderator
Previous Topic:Measuring compilation time of a Java project
Next Topic:JUnit Plug-In Test is run over and over again
Current Time: Fri Jun 20 07:45:21 EDT 2025
Powered by FUDForum. Page generated in 0.12425 seconds
