Home » Modeling » Compare » can't find kind=ADD(can't find kind=ADD)
can't find kind=ADD [message #1756264] Tue, 14 March 2017 16:59 Go to next message
taghreed altamimi is currently offline taghreed altamimiFriend
I saved the comparison result as text file and using Epsilon query language to query the comparison as XML file and i got all information i need using identifiers (matching the identifiers in the comparison with the identifiers in the compared UML models)but i noticed that difference kind =ADD is missing i mean that the difference is available but the tag name kind is missing although its there when the difference is delete or change .
<submatches>
        <differences xsi:type="compare:ReferenceChange" equivalence="//@equivalences.2">
          <reference href="http://www.eclipse.org/uml2/5.0.0/UML#//ActivityEdge/inPartition"/>
          <value href="platform:/resource/evolving%20Source%20Model/changedExample1.uml#_miVR0DrKEeWwIYjMw9yGdw"/>
        </differences>
        <left href="platform:/resource/evolving%20Source%20Model/changedExample1.uml#_7TFn8MYgEeaBfprPkglx7w"/>
        <right href="platform:/resource/evolving%20Source%20Model/Example1.uml#_7TFn8MYgEeaBfprPkglx7w"/>
      </submatches>
<submatches>
        <differences xsi:type="compare:ReferenceChange" requires="//@matches.0/@submatches.0/@differences.8" requiredBy="//@matches.0/@submatches.0/@differences.9" kind="CHANGE" equivalence="//@equivalences.8">
          <reference href="http://www.eclipse.org/uml2/5.0.0/UML#//ActivityEdge/target"/>
          <value href="platform:/resource/evolving%20Source%20Model/changedExample1.uml#_NPctIP7HEea76e2Bdrm2fA"/>
        </differences>
        <left href="platform:/resource/evolving%20Source%20Model/changedExample1.uml#_RXhEcDrLEeWwIYjMw9yGdw"/>
        <right href="platform:/resource/evolving%20Source%20Model/Example1.uml#_RXhEcDrLEeWwIYjMw9yGdw"/>
      </submatches>
Is there any trick to see kind ="ADD".
I attached the comparison file.
Taghreed
Re: can't find kind=ADD [message #1756359 is a reply to message #1756264] Wed, 15 March 2017 20:17 Go to previous messageGo to next message
Philip Langer is currently offline Philip LangerFriend
Member
I haven't double-checked, but I guess the explicitly specified difference kind ADD is missing, because it is the default value. Default values are omitted in the XMI serialization.
If this is the case, then you can either just assume that no explicit difference kind means ADD, or you may check if there is a serialization option to turn on the serialization of default values (not sure there is one though).
Best wishes,
Philip
Philip Langer
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Philip Langer
Re: can't find kind=ADD [message #1756363 is a reply to message #1756359] Wed, 15 March 2017 20:42 Go to previous message
Thanks very much
Previous Topic:Ignoring attributes depending on their value
Next Topic:Comparing two structurally equal EObjects yields PSEUDO conflict [updated]
Current Time: Fri Mar 05 00:48:08 GMT 2021
Powered by FUDForum. Page generated in 0.01846 seconds
