Home » Eclipse Projects » EGit / JGit » EGit - Error while building EGit source code (EGit - Error while building EGit source code )
EGit - Error while building EGit source code [message #1756136] Mon, 13 March 2017 05:13 Go to next message
Suresh P is currently offline Suresh PFriend
HI,
I have to build the EGit Source code. I followed the steps specified in EGit Contributor Gudie - http://help.eclipse.org/neon/index.jsp?topic=%2Forg.eclipse.egit.doc%2Fhelp%2FEGit%2FContributor_Guide%2FContributor-Guide.html
I have used Eclipse Mars, JDK 8 and Maven 3.3 for building.
I have downloaded both JGit and EGit from clone and imported into same workspace.
Followed the below steps:
1. Open File > Import... and select Git > Projects from Git
Select URI
2. Enter the URLS below:
EGit URL - https://git.eclipse.org/r/egit/egit.git
JGit URL - https://git.eclipse.org/r/jgit/jgit.git
3. Selected 'master' branch
4. Import existing projects into the workspace from the newly created working directory.
5. After importing the projects to workspace, to resolve the build errors, I followed the steps specified in section "Development IDE Configuration".
6. Followed Option 1 (recommended): Use a Target Platform to add dependencies
7. Open the org.eclipse.egit.target project and selected egit-4.5.target for Eclispe Mars. In the editor, selected the "Set as Target Platform" link.
8. It open the popup "Load as Target Platform" and it is not closed even after 1 hour.
Let me know if you need any error logs to get more details about the issue.
Can you provide me all the steps required to build EGit project in Eclipse Mars.
I have attached the snapshot of "Load as Target Platform" Popup, to give some more context into this issue.
The progress bar shows 0% even after 1 hour.
[Updated on: Mon, 13 March 2017 06:11]
Report message to a moderator
Re: EGit - Error while building EGit source code [message #1756137 is a reply to message #1756136] Mon, 13 March 2017 05:26 Go to previous messageGo to next message
Re: EGit - Error while building EGit source code [message #1756142 is a reply to message #1756137] Mon, 13 March 2017 07:01 Go to previous messageGo to next message
There are the following instructions for doing all the setup automatically with EGit's Oomph setup:
https://wiki.eclipse.org/EGit/Contributor_Guide#Automated_Developer_Setup
I just tried these steps just now, but unless you pick Oxygen for the target platform on the Variables page (instead of Neon, which is the default selection on the Variables page), there is one error in org.eclipse.jgit.junit.http.AppServer.TestLoginService which cannot resolve its base class org.eclipse.jetty.security.AbstractLoginService which I assume must be new for Jetty in Oxygen.
In any case, the master branch will not fully compile against a Mars target platform. I tried activating the mars target, which worked for me, but the following compile errors are the result:
Description	Resource	Path	Location	Type
SmartImportJob cannot be resolved to a type	SmartImportWizardTest.java	/org.eclipse.egit.ui.importer.tests/src/org/eclipse/egit/ui/importer/tests	line 160	Java Problem
SmartImportRootWizardPage cannot be resolved to a type	SmartImportGitWizard.java	/org.eclipse.egit.ui.smartimport/src/org/eclipse/egit/ui/internal/clone	line 123	Java Problem
SmartImportRootWizardPage cannot be resolved to a type	SmartImportGitWizard.java	/org.eclipse.egit.ui.smartimport/src/org/eclipse/egit/ui/internal/clone	line 149	Java Problem
SmartImportWizard cannot be resolved to a type	SmartImportGitWizard.java	/org.eclipse.egit.ui.smartimport/src/org/eclipse/egit/ui/internal/clone	line 42	Java Problem
SmartImportWizard cannot be resolved to a type	SmartImportGitWizard.java	/org.eclipse.egit.ui.smartimport/src/org/eclipse/egit/ui/internal/clone	line 57	Java Problem
SmartImportWizard cannot be resolved to a type	SmartImportGitWizard.java	/org.eclipse.egit.ui.smartimport/src/org/eclipse/egit/ui/internal/clone	line 69	Java Problem
SmartImportWizard cannot be resolved to a type	SmartImportGitWizard.java	/org.eclipse.egit.ui.smartimport/src/org/eclipse/egit/ui/internal/clone	line 80	Java Problem
SmartImportWizard cannot be resolved to a type	SmartImportGitWizard.java	/org.eclipse.egit.ui.smartimport/src/org/eclipse/egit/ui/internal/clone	line 81	Java Problem
SmartImportWizard cannot be resolved to a type	SmartImportGitWizard.java	/org.eclipse.egit.ui.smartimport/src/org/eclipse/egit/ui/internal/clone	line 106	Java Problem
SmartImportWizard cannot be resolved to a type	SmartImportGitWizard.java	/org.eclipse.egit.ui.smartimport/src/org/eclipse/egit/ui/internal/clone	line 149	Java Problem
The import org.eclipse.ui.internal.wizards.datatransfer cannot be resolved	SmartImportWizardTest.java	/org.eclipse.egit.ui.importer.tests/src/org/eclipse/egit/ui/importer/tests	line 42	Java Problem
The import org.eclipse.ui.internal.wizards.datatransfer.SmartImportRootWizardPage cannot be resolved	SmartImportGitWizard.java	/org.eclipse.egit.ui.smartimport/src/org/eclipse/egit/ui/internal/clone	line 33	Java Problem
The import org.eclipse.ui.internal.wizards.datatransfer.SmartImportWizard cannot be resolved	SmartImportGitWizard.java	/org.eclipse.egit.ui.smartimport/src/org/eclipse/egit/ui/internal/clone	line 34	Java Problem
The method format(String, Object[]) in the type JFaceResources is not applicable for the arguments (String, Integer, Integer)	StorageSizeFieldEditor.java	/org.eclipse.egit.ui/src/org/eclipse/egit/ui/internal/preferences	line 35	Java Problem
Unsatisfied version constraint: 'org.eclipse.ui.ide: 3.12.0'	MANIFEST.MF	/org.eclipse.egit.ui.importer.tests/META-INF	line 14	Plug-in Problem
I.e., the new smart import wizard cannot compile against Mars.
Note to EGit developers, you should change your Oomph setup to replace http://download.eclipse.org/jetty/updates/jetty-bundles-9.x/9.2.13.v20150730 with http://download.eclipse.org/jetty/updates/jetty-bundles-9.x/9.4.1.v20170120 in all three of your targlet task's repository groups, and you should change /org.eclipse.jgit.junit.http/META-INF/MANIFEST.MF so that it specifies a proper lower bound for its dependency on the new AbstractLoginService class in the org.eclipse.jetty.security package:
org.eclipse.jetty.security;version="[9.4.0,10.0.0)",
Ed Merks
Re: EGit - Error while building EGit source code [message #1758251 is a reply to message #1756142] Sat, 25 March 2017 22:38 Go to previous message
Matthias Sohn is currently offline Matthias SohnFriend
fixed lower bound of jetty.security bundle in manifests in https://git.eclipse.org/r/#/c/93856/
updated Jetty to 9.4.3 also in Oomph setup in https://git.eclipse.org/r/#/c/93635/3/tools/oomph/EGit.setup
Previous Topic:How to get Team -> Show In History
Next Topic:gitattributes : macro binary
Current Time: Thu Oct 22 07:56:13 GMT 2020
Powered by FUDForum. Page generated in 0.01882 seconds
