Home » Eclipse Projects » Papyrus for Real Time » How to access port index of an incoming message
How to access port index of an incoming message [message #1755496] Fri, 03 March 2017 19:57 Go to next message
Tuhin Das is currently offline Tuhin DasFriend
I am designing a Papyrus-RT model which has a capsule named 'X' and the
'X' capsule has a port "y:Y" having a multiplicity of 5. Now, if a message
arrives in this port, in the 'X' capsule behaviour how would we access the
particular port index where the message arrived?
Re: How to access port index of an incoming message [message #1755498 is a reply to message #1755496] Fri, 03 March 2017 20:05 Go to previous messageGo to next message
Ernesto Posse is currently offline Ernesto PosseFriend
Hi.
In action code you can obtain the index using either
getMsg().sapIndex()
or
getMsg().sapIndex0()
The difference between the two is that in the first one, indices are counted from 1, whereas in the second, they are counted from 0.
Re: How to access port index of an incoming message [message #1755504 is a reply to message #1755498] Fri, 03 March 2017 21:16 Go to previous message
Thank you, Ernesto. It worked with a slight modification to replace the '.' operator with '->'.
Previous Topic:Ignoring Unexpected Messages
Next Topic:Papyrus-rt gets stock
Current Time: Sat Nov 28 08:43:29 GMT 2020
Powered by FUDForum. Page generated in 0.01965 seconds
