Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMF Forms: How to disable the add button for references field
EMF Forms: How to disable the add button for references field [message #1755477] Fri, 03 March 2017 15:32 Go to next message
Jim 20100 is currently offline Jim 20100Friend
Member
If someone has a guideline to do that in EMF Forms:
I am very interested for that.
Rgds
Jim
Re: EMF Forms: How to disable the add button for references field [message #1755602 is a reply to message #1755477] Mon, 06 March 2017 09:38 Go to previous messageGo to next message
Eugen Neufeld is currently offline Eugen NeufeldFriend
Hi Jim,
you have to provide a custom renderer for this.
So you have to subclass org.eclipse.emf.ecp.view.internal.control.multireference.MultiReferenceSWTRenderer.MultiReferenceSWTRenderer(VControl, ViewModelContext, ReportService, EMFFormsDatabinding, EMFFormsLabelProvider, VTViewTemplateProvider, ImageRegistryService) and here you can overwrite eg org.eclipse.emf.ecp.view.internal.control.multireference.MultiReferenceSWTRenderer.showAddNewButton() .
You will also need the service which registers the control, check this blog post for this:http://eclipsesource.com/blogs/tutorials/how-to-customize-emf-forms/#customizecontrols
Eugen
Eugen Neufeld
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: EMF Forms: How to disable the add button for references field [message #1755637 is a reply to message #1755602] Mon, 06 March 2017 13:04 Go to previous messageGo to next message
Member
Thx but to fight against such documentation is not easy.
I am not sure that a normal developer as I am can manage easily the task.
Especially to inject the ImageRegistryService?
I don't see any doc...
I am even not sure that it will work in my Eclipse 3 application? as if I remember I tested such @inject annotations, and it works only in Eclipse 4 application?
Can you help me pls?
Re: EMF Forms: How to disable the add button for references field [message #1755639 is a reply to message #1755637] Mon, 06 March 2017 13:22 Go to previous messageGo to next message
Member
I finally managed to add the Image Registry.
So I added my plugin to my final product but it seems that the registration of the service is not done.
the isApplicable Method is not called in my debug mode.
Here is the code:
package biz.astron.sales.quoting.ui.renderer.levelscontrol;
import org.eclipse.core.databinding.property.value.IValueProperty;
import org.eclipse.emf.ecore.EStructuralFeature;
import org.eclipse.emf.ecp.view.spi.context.ViewModelContext;
import org.eclipse.emf.ecp.view.spi.model.VControl;
import org.eclipse.emf.ecp.view.spi.model.VElement;
import org.eclipse.emfforms.spi.common.report.ReportService;
import org.eclipse.emfforms.spi.core.services.databinding.DatabindingFailedException;
import org.eclipse.emfforms.spi.core.services.databinding.DatabindingFailedReport;
import org.eclipse.emfforms.spi.core.services.databinding.EMFFormsDatabinding;
import org.eclipse.emfforms.spi.swt.core.AbstractSWTRenderer;
import org.eclipse.emfforms.spi.swt.core.di.EMFFormsDIRendererService;
import biz.astron.sales.quoting.QuotingPackage;
public class LevelsControlSWTRendererService implements EMFFormsDIRendererService<VControl> {
private EMFFormsDatabinding databindingService;
private ReportService reportService;
* Called by the initializer to set the EMFFormsDatabinding.
* @param databindingService The EMFFormsDatabinding
protected void setEMFFormsDatabinding(EMFFormsDatabinding databindingService) {
this.databindingService = databindingService;
* Called by the initializer to set the ReportService.
* @param reportService The ReportService
protected void setReportService(ReportService reportService) {
this.reportService = reportService;
* {@inheritDoc}
* @see org.eclipse.emfforms.spi.swt.core.di.EMFFormsDIRendererService#isApplicable(VElement,ViewModelContext)
public double isApplicable(VElement vElement, ViewModelContext viewModelContext) {
if (!VControl.class.isInstance(vElement)) {
return NOT_APPLICABLE;
final VControl control = (VControl) vElement;
if (control.getDomainModelReference() == null) {
@SuppressWarnings("rawtypes")
IValueProperty valueProperty;
try {
valueProperty = databindingService.getValueProperty(control.getDomainModelReference(),
viewModelContext.getDomainModel());
} catch (final DatabindingFailedException ex) {
reportService.report(new DatabindingFailedReport(ex));
final EStructuralFeature eStructuralFeature = EStructuralFeature.class.cast(valueProperty.getValueType());
if (QuotingPackage.eINSTANCE.getEngineeringPart_Levels().equals(eStructuralFeature)) {
return 10;
* {@inheritDoc}
* @see org.eclipse.emfforms.spi.swt.core.di.EMFFormsDIRendererService#getRendererClass()
public Class<? extends AbstractSWTRenderer<VControl>> getRendererClass() {
return LevelsControlRenderer.class;
Re: EMF Forms: How to disable the add button for references field [message #1755642 is a reply to message #1755639] Mon, 06 March 2017 13:43 Go to previous message
Member
It works finally.
Thx Eugen
Previous Topic:Extending ECPReferenceService
Next Topic:EMF Forms: Customize derived field - Modification is ignored
Current Time: Wed May 25 00:55:45 GMT 2022
Powered by FUDForum. Page generated in 0.02720 seconds
