Home » Modeling » Papyrus » members of the same base reference metamodel
members of the same base reference metamodel [message #1755318] Thu, 02 March 2017 05:25 Go to next message
Hallo,
When I validate my Profile model, I get the following warning:
"All elements imported via metaclass references or metamodel references owned by profile 'ProfileLifecycle_Profile' must be members of the same base reference metamodel."
I checked all metaclasses and they belong all to the same metamodel (UML 2.5.0 Metamodel).
Bernd
Re: members of the same base reference metamodel [message #1755623 is a reply to message #1755318] Mon, 06 March 2017 06:33 Go to previous messageGo to next message
do you have package or subProfiles in your profile?
If you do, the warning might come from the fact that you have no imported metaclass inside these package/subprofile (but use directly the imports from top model).
To remove the warning, import the involved metaclass in the package/profile.
Xavier
Re: members of the same base reference metamodel [message #1755624 is a reply to message #1755318] Mon, 06 March 2017 06:33 Go to previous messageGo to next message
Xavier
Re: members of the same base reference metamodel [message #1755713 is a reply to message #1755624] Tue, 07 March 2017 03:01 Go to previous messageGo to next message
Hallo,
I have 3 profiles; 2 "normal" profiles (OpenModelProfile and InterfaceModelProfile) and one profile (ProfileLifecycleProfile) which is applied to the other two "normal" profiles. Interesting enough, the warning appears only in the InterfaceModelProfile and the ProfileLifecycleProfile not in the OpenModelProfile.
The two profiles with the warnings are attached.
Bernd
Re: members of the same base reference metamodel [message #1755715 is a reply to message #1755713] Tue, 07 March 2017 03:15 Go to previous messageGo to next message
thank you for these inputs. The problem comes from the validation algorithm that does not seems to take into account package imports.
If you use directly elementImports on the metaclass the validation does not trigger warnings.
regards,
Xavier
Re: members of the same base reference metamodel [message #1755729 is a reply to message #1755715] Tue, 07 March 2017 04:40 Go to previous messageGo to next message
Hallo Xavier,
Thank you for the quick response Smile
What do you mean by "direct elementImport"?
Bernd
Re: members of the same base reference metamodel [message #1755730 is a reply to message #1755729] Tue, 07 March 2017 04:43 Go to previous messageGo to next message
Yeah sorry about that "direct" that has no meaning.
It is just an ElementImport. You can for example produce one with the "import metaclass" from the palette.
It produce an elementImport in your profile with only the metaclass involved imported.
With this you would't have anymore the warnings.
Bonus : Using this instead of importing the whole UML Package allow to track which Metaclass are extended by your profile.
Re: members of the same base reference metamodel [message #1755746 is a reply to message #1755730] Tue, 07 March 2017 07:35 Go to previous messageGo to next message
Hallo Xavier,
That works Smile ; thank you very much for your help.
Bernd
Re: members of the same base reference metamodel [message #1759111 is a reply to message #1755746] Thu, 06 April 2017 10:25 Go to previous message
after a lot of digging I hope I'm right here. I'm ceating a profile built up on SysML.
My Profile:
Stereotype <<System>> is created by generalization from SysML Stereotype Block
Stereotype <<User>> is created by extension from UML Metaclass Actor
When I test my profile using "Run as" I am facing the folowing phenomena:
<<System>> works fine Smile
<<User>> is not visible in the profile Sad
First I took the metaclass via drag and drop from the UML Metamodel tree. Now I have aplied your tip to use Import Metaclass. Depressingly with the same result Sad
Did I miss something?
Another Bernd
Previous Topic:Applying user defined stereotypes to the model elements in block definition diagram,SysML
Next Topic:color parts in a diagram according to the stereotype of its type
Current Time: Wed May 14 08:01:12 EDT 2025
Powered by FUDForum. Page generated in 0.06742 seconds
