gendoc - instance model [message #1755138] |
Tue, 28 February 2017 06:35  |
Hi. I'm new on this Forum and i need help.
I can generate reports with Gendoc using an ecore model.
But i need to generate reports with an instance from this ecore model and i can't. The only solution i have for now is to execute my .editor as "Eclipse Application".
This will open a new eclipse instance where i can create my instance model then generate report without problem.
I would like to create this instance model without using a new Eclipse instance.
I also tried before all to create a file with XMI structure and use it as Model in Gendoc but i got this error message:
See details. The execution of a script failed: The model Model can not be loaded from URL: "[model_path]" can not be loaded
FUDForum. Page generated in 0.06428 seconds
