Home » Modeling » EMF » Xtext validation fails on travis-ci
Xtext validation fails on travis-ci [message #1755062] Mon, 27 February 2017 17:14 Go to next message
Nicolas Rouquette is currently offline Nicolas RouquetteFriend
Member
I have a DSL that is split in 5 *.xcore files for which I've defined an Xtext grammar.
I have been careful in ensuring that my builds are reproducible in my development environment.
However, I'm stumped with Xtext validation errors that happen only on travis-ci:
https://travis-ci.org/JPL-IMCE/jpl.imce.oml.specification.parent/builds/205865402
This is a build of this project:
https://github.com/JPL-IMCE/jpl.imce.oml.specification.parent
(branch: xtext2.11)
In my development environment; I can execute the same build script without errors:
./scripts/travis-build.sh
But on travis-ci, Xtext validation fails when generating the grammar for my dsl.
:jpl.imce.oml.specification:generateXtextLanguage
0    [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/emf/2002/Ecore' from 'platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel'
32   [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.w3.org/XML/1998/namespace' from 'platform:/resource/org.eclipse.emf.ecore/model/XMLNamespace.genmodel'
58   [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/emf/2003/XMLType' from 'platform:/resource/org.eclipse.emf.ecore/model/XMLType.genmodel'
149  [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Adding generated EPackage 'org.eclipse.xtext.xbase.XbasePackage'
235  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
271  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
289  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xbase' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
290  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://www.eclipse.org/xtext/common/JavaVMTypes' from 'platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel'
2605 [main] INFO  text.xtext.generator.XtextGenerator  - Initializing Xtext generator
2606 [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Adding generated EPackage 'org.eclipse.xtext.common.types.TypesPackage'
2743 [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering project jpl.imce.oml.specification at 'file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/'
2744 [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering project jpl.imce.oml.specification.tests at 'file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification.tests/'
2744 [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering project jpl.imce.oml.specification.ide at 'file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification.ide/'
2744 [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering project jpl.imce.oml.specification.ui at 'file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification.ui/'
2744 [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering project jpl.imce.oml.specification.ui.tests at 'file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification.ui.tests/'
2744 [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering project jpl.imce.oml.specification.idea at 'file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification.idea/'
2745 [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Registering project jpl.imce.oml.specification.web at 'file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification.web/'
2767 [main] INFO  lipse.emf.mwe.utils.StandaloneSetup  - Using resourceSet registry. The registered Packages will not be registered in the global EPackage.Registry.INSTANCE!
5088 [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'xcore.lang' from 'platform:/resource/org.eclipse.emf.ecore.xcore.lib/model/XcoreLang.xcore'
6869 [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://imce.jpl.nasa.gov/oml/common' from 'platform:/resource/jpl.imce.oml.specification.ecore/model/OMLCommon.xcore'
6878 [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://imce.jpl.nasa.gov/oml/terminologies' from 'platform:/resource/jpl.imce.oml.specification.ecore/model/OMLTerminologies.xcore'
6878 [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://imce.jpl.nasa.gov/oml/graphs' from 'platform:/resource/jpl.imce.oml.specification.ecore/model/OMLGraphs.xcore'
6878 [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://imce.jpl.nasa.gov/oml/bundles' from 'platform:/resource/jpl.imce.oml.specification.ecore/model/OMLBundles.xcore'
6879 [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel 'http://imce.jpl.nasa.gov/oml/descriptions' from 'platform:/resource/jpl.imce.oml.specification.ecore/model/OMLDescriptions.xcore'
15757 [main] INFO  erator.parser.antlr.AntlrToolFacade  - downloading file from 'http://download.itemis.com/antlr-generator-3.2.0-patch.jar' ...
17219 [main] INFO  erator.parser.antlr.AntlrToolFacade  - finished downloading.
17238 [main] INFO  text.xtext.generator.XtextGenerator  - Generating jpl.imce.oml.specification.OntologicalModelingLanguage
51980 [main] INFO  text.xtext.generator.XtextGenerator  - Generating common infrastructure
52007 [main] INFO  .emf.mwe2.runtime.workflow.Workflow  - Done.
:jpl.imce.oml.specification:generateXtextWarning: NLS unused message: auth_alreadySpecified in: org.eclipse.core.internal.runtime.messages
Warning: NLS missing message: line_separator_platform_mac_os_9 in: org.eclipse.core.internal.runtime.messages
ERROR:The method getAnnotationPropertyAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 57 column : 41)
ERROR:The method getAnnotationPropertyAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 58 column : 41)
ERROR:The method getAnnotationAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 64 column : 33)
ERROR:The method getAnnotationAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 65 column : 33)
ERROR:The method getTerminologyGraphAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 72 column : 39)
ERROR:The method getTerminologyGraphAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 73 column : 39)
ERROR:The method getTerminologyGraphAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 75 column : 52)
ERROR:The method getTerminologyGraphAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 76 column : 52)
ERROR:The method getTerminologyGraphAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 99 column : 42)
ERROR:The method getTerminologyGraphAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 100 column : 42)
ERROR:The method getTerminologyGraphAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 128 column : 50)
ERROR:The method getTerminologyGraphAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 129 column : 50)
ERROR:The method getAspectAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 140 column : 29)
ERROR:The method getAspectAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 141 column : 29)
ERROR:The method getTerminologyExtensionAxiomAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 146 column : 25)
ERROR:The method getTerminologyExtensionAxiomAccess() from the type OntologicalModelingLanguageGrammarAccess refers to the missing type Object (file:/home/travis/build/JPL-IMCE/jpl.imce.oml.specification.parent/jpl.imce.oml.specification/src/jpl/imce/oml/specification/formatting2/OntologicalModelingLanguageFormatter.xtend line : 147 column : 25)
 FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':jpl.imce.oml.specification:generateXtext'.
> Xtext validation failed, see build log for details.
* Try:
Run with --info or --debug option to get more log output.
* Exception is:
org.gradle.api.tasks.TaskExecutionException: Execution failed for task ':jpl.imce.oml.specification:generateXtext'.
	at org.gradle.api.internal.tasks.execution.ExecuteActionsTaskExecuter.executeActions(ExecuteActionsTaskExecuter.java:84)
	at org.gradle.api.internal.tasks.execution.ExecuteActionsTaskExecuter.execute(ExecuteActionsTaskExecuter.java:55)
	at org.gradle.api.internal.tasks.execution.SkipUpToDateTaskExecuter.execute(SkipUpToDateTaskExecuter.java:62)
	at org.gradle.api.internal.tasks.execution.ValidatingTaskExecuter.execute(ValidatingTaskExecuter.java:58)
	at org.gradle.api.internal.tasks.execution.SkipEmptySourceFilesTaskExecuter.execute(SkipEmptySourceFilesTaskExecuter.java:88)
	at org.gradle.api.internal.tasks.execution.ResolveTaskArtifactStateTaskExecuter.execute(ResolveTaskArtifactStateTaskExecuter.java:46)
	at org.gradle.api.internal.tasks.execution.SkipTaskWithNoActionsExecuter.execute(SkipTaskWithNoActionsExecuter.java:51)
	at org.gradle.api.internal.tasks.execution.SkipOnlyIfTaskExecuter.execute(SkipOnlyIfTaskExecuter.java:54)
	at org.gradle.api.internal.tasks.execution.ExecuteAtMostOnceTaskExecuter.execute(ExecuteAtMostOnceTaskExecuter.java:43)
	at org.gradle.api.internal.tasks.execution.CatchExceptionTaskExecuter.execute(CatchExceptionTaskExecuter.java:34)
	at org.gradle.execution.taskgraph.DefaultTaskGraphExecuter$EventFiringTaskWorker$1.execute(DefaultTaskGraphExecuter.java:236)
	at org.gradle.execution.taskgraph.DefaultTaskGraphExecuter$EventFiringTaskWorker$1.execute(DefaultTaskGraphExecuter.java:228)
	at org.gradle.internal.Transformers$4.transform(Transformers.java:169)
	at org.gradle.internal.progress.DefaultBuildOperationExecutor.run(DefaultBuildOperationExecutor.java:106)
	at org.gradle.internal.progress.DefaultBuildOperationExecutor.run(DefaultBuildOperationExecutor.java:61)
	at org.gradle.execution.taskgraph.DefaultTaskGraphExecuter$EventFiringTaskWorker.execute(DefaultTaskGraphExecuter.java:228)
	at org.gradle.execution.taskgraph.DefaultTaskGraphExecuter$EventFiringTaskWorker.execute(DefaultTaskGraphExecuter.java:215)
	at org.gradle.execution.taskgraph.AbstractTaskPlanExecutor$TaskExecutorWorker.processTask(AbstractTaskPlanExecutor.java:77)
	at org.gradle.execution.taskgraph.AbstractTaskPlanExecutor$TaskExecutorWorker.run(AbstractTaskPlanExecutor.java:58)
	at org.gradle.execution.taskgraph.DefaultTaskPlanExecutor.process(DefaultTaskPlanExecutor.java:32)
	at org.gradle.execution.taskgraph.DefaultTaskGraphExecuter.execute(DefaultTaskGraphExecuter.java:113)
	at org.gradle.execution.SelectedTaskExecutionAction.execute(SelectedTaskExecutionAction.java:37)
	at org.gradle.execution.DefaultBuildExecuter.execute(DefaultBuildExecuter.java:37)
	at org.gradle.execution.DefaultBuildExecuter.access$000(DefaultBuildExecuter.java:23)
	at org.gradle.execution.DefaultBuildExecuter$1.proceed(DefaultBuildExecuter.java:43)
	at org.gradle.execution.DryRunBuildExecutionAction.execute(DryRunBuildExecutionAction.java:32)
	at org.gradle.execution.DefaultBuildExecuter.execute(DefaultBuildExecuter.java:30)
	at org.gradle.initialization.DefaultGradleLauncher$RunTasksAction.execute(DefaultGradleLauncher.java:256)
	at org.gradle.initialization.DefaultGradleLauncher$RunTasksAction.execute(DefaultGradleLauncher.java:253)
	at org.gradle.internal.progress.DefaultBuildOperationExecutor.run(DefaultBuildOperationExecutor.java:56)
	at org.gradle.initialization.DefaultGradleLauncher.doBuildStages(DefaultGradleLauncher.java:175)
	at org.gradle.initialization.DefaultGradleLauncher.doBuild(DefaultGradleLauncher.java:119)
	at org.gradle.initialization.DefaultGradleLauncher.run(DefaultGradleLauncher.java:102)
	at org.gradle.launcher.exec.GradleBuildController.run(GradleBuildController.java:71)
	at org.gradle.tooling.internal.provider.ExecuteBuildActionRunner.run(ExecuteBuildActionRunner.java:28)
	at org.gradle.launcher.exec.ChainingBuildActionRunner.run(ChainingBuildActionRunner.java:35)
	at org.gradle.launcher.exec.InProcessBuildActionExecuter.execute(InProcessBuildActionExecuter.java:41)
	at org.gradle.launcher.exec.InProcessBuildActionExecuter.execute(InProcessBuildActionExecuter.java:26)
	at org.gradle.tooling.internal.provider.ContinuousBuildActionExecuter.execute(ContinuousBuildActionExecuter.java:75)
	at org.gradle.tooling.internal.provider.ContinuousBuildActionExecuter.execute(ContinuousBuildActionExecuter.java:49)
	at org.gradle.tooling.internal.provider.ServicesSetupBuildActionExecuter.execute(ServicesSetupBuildActionExecuter.java:49)
	at org.gradle.tooling.internal.provider.ServicesSetupBuildActionExecuter.execute(ServicesSetupBuildActionExecuter.java:31)
	at org.gradle.launcher.daemon.server.exec.ExecuteBuild.doBuild(ExecuteBuild.java:67)
	at org.gradle.launcher.daemon.server.exec.BuildCommandOnly.execute(BuildCommandOnly.java:36)
	at org.gradle.launcher.daemon.server.api.DaemonCommandExecution.proceed(DaemonCommandExecution.java:120)
	at org.gradle.launcher.daemon.server.exec.WatchForDisconnection.execute(WatchForDisconnection.java:47)
	at org.gradle.launcher.daemon.server.exec.ResetDeprecationLogger.execute(ResetDeprecationLogger.java:26)
	at org.gradle.launcher.daemon.server.exec.RequestStopIfSingleUsedDaemon.execute(RequestStopIfSingleUsedDaemon.java:34)
	at org.gradle.launcher.daemon.server.exec.ForwardClientInput$2.call(ForwardClientInput.java:74)
	at org.gradle.launcher.daemon.server.exec.ForwardClientInput$2.call(ForwardClientInput.java:72)
	at org.gradle.util.Swapper.swap(Swapper.java:38)
	at org.gradle.launcher.daemon.server.exec.ForwardClientInput.execute(ForwardClientInput.java:72)
	at org.gradle.launcher.daemon.server.exec.LogAndCheckHealth.execute(LogAndCheckHealth.java:55)
	at org.gradle.launcher.daemon.server.exec.LogToClient.doBuild(LogToClient.java:60)
	at org.gradle.launcher.daemon.server.exec.EstablishBuildEnvironment.doBuild(EstablishBuildEnvironment.java:72)
	at org.gradle.launcher.daemon.server.exec.StartBuildOrRespondWithBusy$1.run(StartBuildOrRespondWithBusy.java:50)
	at org.gradle.launcher.daemon.server.DaemonStateCoordinator$1.run(DaemonStateCoordinator.java:297)
	at org.gradle.internal.concurrent.ExecutorPolicy$CatchAndRecordFailures.onExecute(ExecutorPolicy.java:63)
	at org.gradle.internal.concurrent.StoppableExecutorImpl$1.run(StoppableExecutorImpl.java:46)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at java.lang.Thread.run(Thread.java:745)
Caused by: org.gradle.api.GradleException: Xtext validation failed, see build log for details.
	at org.xtext.gradle.builder.XtextGradleBuilder.build(XtextGradleBuilder.java:210)
	at org.xtext.gradle.tasks.XtextGenerate.generate(XtextGenerate.java:149)
	at java.lang.reflect.Method.invoke(Method.java:483)
	at org.gradle.internal.reflect.JavaMethod.invoke(JavaMethod.java:73)
	at org.gradle.api.internal.project.taskfactory.DefaultTaskClassInfoStore$IncrementalTaskAction.doExecute(DefaultTaskClassInfoStore.java:163)
	at org.gradle.api.internal.project.taskfactory.DefaultTaskClassInfoStore$StandardTaskAction.execute(DefaultTaskClassInfoStore.java:134)
	at org.gradle.api.internal.project.taskfactory.DefaultTaskClassInfoStore$StandardTaskAction.execute(DefaultTaskClassInfoStore.java:123)
	at org.gradle.api.internal.tasks.execution.ExecuteActionsTaskExecuter.executeAction(ExecuteActionsTaskExecuter.java:95)
	at org.gradle.api.internal.tasks.execution.ExecuteActionsTaskExecuter.executeActions(ExecuteActionsTaskExecuter.java:76)
	... 73 more
Can someone explain what causes these errors and how I can fix this?
- Nicolas.
Re: Xtext validation fails on travis-ci [message #1755063 is a reply to message #1755062] Mon, 27 February 2017 17:38 Go to previous message
Member
I understand that I should have posted this on the TMF (Xtext) forum; however, it looks like I can't move this message to that forum.
Previous Topic:deleted
Next Topic:How to completely remove a Resource from a ResourceSet?
Current Time: Tue Sep 28 19:58:27 GMT 2021
Powered by FUDForum. Page generated in 0.02194 seconds
