Home » Archived » Eclipse Process Manager (Stardust) » org.apache.activemq.ActiveMQConnectionFactory cannot be cast to javax.jms.QueueConnectionFactory(Jms tutorial problem)
org.apache.activemq.ActiveMQConnectionFactory cannot be cast to javax.jms.QueueConnectionFactory [message #1755042] Mon, 27 February 2017 13:07 Go to next message
chris suen is currently offline chris suenFriend
Got this exception at when sending message. I am using activemq 5.14.3 with tomcat 7,0,73. Can anyone assist?
java.lang.ClassCastException: org.apache.activemq.ActiveMQConnectionFactory cannot be cast to javax.jms.QueueConnectionFactory
at org.eclipse.stardust.engine.extensions.jms.app.JMSApplicationInstance.connectJmsResources(JMSApplicationInstance.java:223)
at org.eclipse.stardust.engine.extensions.jms.app.JMSApplicationInstance.send(JMSApplicationInstance.java:116)
at org.eclipse.stardust.engine.core.spi.extensions.runtime.StatelessAsynchronousApplicationBinding.send(StatelessAsynchronousApplicationBinding.java:60)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.invokeAsynchronously(ActivityInstanceBean.java:1862)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.invokeApplication(ActivityInstanceBean.java:1587)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.invoke(ActivityInstanceBean.java:1289)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.doStartActivity(ActivityInstanceBean.java:1279)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityInstanceBean.start(ActivityInstanceBean.java:1240)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityThread.runCurrentActivity(ActivityThread.java:1229)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityThread.runInternal(ActivityThread.java:419)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityThread.run(ActivityThread.java:242)
at org.eclipse.stardust.engine.core.runtime.beans.ActivityThread.schedule(ActivityThread.java:127)
at org.eclipse.stardust.engine.core.runtime.audittrail.management.ActivityInstanceUtils.complete(ActivityInstanceUtils.java:409)
at org.eclipse.stardust.engine.core.runtime.beans.WorkflowServiceImpl.complete(WorkflowServiceImpl.java:1109)
at org.eclipse.stardust.engine.core.runtime.beans.WorkflowServiceImpl.complete(WorkflowServiceImpl.java:992)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.CallingInterceptor.invoke(CallingInterceptor.java:29)
at org.eclipse.stardust.engine.core.runtime.interceptor.MethodInvocationImpl.proceed(MethodInvocationImpl.java:130)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.POJOExceptionHandler.invoke(POJOExceptionHandler.java:30)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.RuntimeExtensionsInterceptor.invoke(RuntimeExtensionsInterceptor.java:34)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.GuardingInterceptor.invoke(GuardingInterceptor.java:78)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.AbstractLoginInterceptor.performCall(AbstractLoginInterceptor.java:201)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.AbstractLoginInterceptor.invoke(AbstractLoginInterceptor.java:121)
at org.eclipse.stardust.engine.api.spring.SpringBeanLoginInterceptor.invoke(SpringBeanLoginInterceptor.java:79)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.doWithDataSource(SpringSessionInterceptor.java:143)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.access$000(SpringSessionInterceptor.java:49)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor$1.doInConnection(SpringSessionInterceptor.java:88)
at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:342)
at org.eclipse.stardust.engine.api.spring.SpringSessionInterceptor.invoke(SpringSessionInterceptor.java:82)
at org.eclipse.stardust.engine.api.spring.SpringConfigurationInterceptor.invoke(SpringConfigurationInterceptor.java:101)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.PropertyLayerProviderInterceptor.invoke(PropertyLayerProviderInterceptor.java:129)
at org.eclipse.stardust.engine.core.runtime.beans.interceptors.DebugInterceptor.invoke(DebugInterceptor.java:56)
at org.eclipse.stardust.engine.api.spring.SpringTxInterceptor$1.doInTransaction(SpringTxInterceptor.java:93)
at org.springframework.transaction.support.TransactionTemplate.execute(TransactionTemplate.java:131)
at org.eclipse.stardust.engine.api.spring.SpringTxInterceptor.invoke(SpringTxInterceptor.java:71)
at org.eclipse.stardust.engine.core.runtime.interceptor.MethodInvocationImpl.execute(MethodInvocationImpl.java:68)
at org.eclipse.stardust.engine.core.runtime.beans.InvocationManager.invoke(InvocationManager.java:53)
at com.sun.proxy.$Proxy174.complete(Unknown Source)
at org.eclipse.stardust.engine.api.spring.WorkflowServiceBean.complete(WorkflowServiceBean.java:68)
at org.eclipse.stardust.engine.api.spring.SpringServiceFactory$SpringServiceInvocationHandler.invoke(SpringServiceFactory.java:201)
at org.eclipse.stardust.ui.web.processportal.common.PPUtils.complete(PPUtils.java:472)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.completeCurrentActivityContinue(ActivityDetailsBean.java:1963)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.access$900(ActivityDetailsBean.java:155)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean$7.handleEvent(ActivityDetailsBean.java:1941)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.retrieveOutDataMappingContinue(ActivityDetailsBean.java:2388)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.retrieveOutDataMapping(ActivityDetailsBean.java:2369)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.completeCurrentActivity(ActivityDetailsBean.java:1934)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.completeCurrentActivity(ActivityDetailsBean.java:1918)
at org.eclipse.stardust.ui.web.processportal.view.ActivityDetailsBean.completeCurrentActivity(ActivityDetailsBean.java:1913)
at org.eclipse.stardust.ui.web.processportal.view.ActivityPanelController.setRemoteControlActivityStateChangeCommandId(ActivityPanelController.java:197)
at org.apache.myfaces.el.PropertyResolverImpl.setProperty(PropertyResolverImpl.java:409)
at org.apache.myfaces.el.PropertyResolverImpl.setValue(PropertyResolverImpl.java:176)
at com.sun.facelets.el.LegacyELContext$LegacyELResolver.setValue(LegacyELContext.java:201)
at com.sun.el.parser.AstValue.setValue(AstValue.java:113)
at com.sun.el.ValueExpressionImpl.setValue(ValueExpressionImpl.java:246)
at com.sun.facelets.el.TagValueExpression.setValue(TagValueExpression.java:93)
at com.sun.facelets.el.LegacyValueBinding.setValue(LegacyValueBinding.java:68)
at javax.faces.component.UIInput.updateModel(UIInput.java:270)
at javax.faces.component.UIInput.processUpdates(UIInput.java:207)
at javax.faces.component.UIComponentBase.processUpdates(UIComponentBase.java:648)
at org.eclipse.stardust.ui.web.common.app.tags.TabScopedComponent.processUpdates(TabScopedComponent.java:128)
at javax.faces.component.UIForm.processUpdates(UIForm.java:90)
at javax.faces.component.UIViewRoot.processUpdates(UIViewRoot.java:160)
at org.apache.myfaces.lifecycle.UpdateModelValuesExecutor.execute(UpdateModelValuesExecutor.java:33)
at org.apache.myfaces.lifecycle.LifecycleImpl.executePhase(LifecycleImpl.java:95)
at org.apache.myfaces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:70)
at com.icesoft.faces.webapp.http.core.JsfLifecycleExecutor.apply(JsfLifecycleExecutor.java:50)
at com.icesoft.faces.webapp.http.core.ReceiveSendUpdates.renderCycle(ReceiveSendUpdates.java:169)
at com.icesoft.faces.webapp.http.core.ReceiveSendUpdates.service(ReceiveSendUpdates.java:110)
at com.icesoft.faces.webapp.http.core.RequestVerifier.service(RequestVerifier.java:65)
at com.icesoft.faces.webapp.http.servlet.BasicAdaptingServlet.service(BasicAdaptingServlet.java:51)
at com.icesoft.faces.webapp.http.servlet.SessionVerifier.service(SessionVerifier.java:62)
at com.icesoft.faces.webapp.http.servlet.PathDispatcher.service(PathDispatcher.java:55)
at com.icesoft.faces.webapp.http.servlet.SessionDispatcher.service(SessionDispatcher.java:107)
at com.icesoft.faces.webapp.http.servlet.BlockExpiredSessionRequests.service(BlockExpiredSessionRequests.java:53)
at com.icesoft.faces.webapp.http.servlet.MainServlet.service(MainServlet.java:204)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
at com.icesoft.faces.webapp.xmlhttp.BlockingServlet.service(BlockingServlet.java:71)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.eclipse.stardust.ui.web.html5.EnhancedJarResourceFilter.doFilter(EnhancedJarResourceFilter.java:148)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:218)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:958)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:452)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1087)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:637)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:318)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
20:52:04 WARN [80-exec-14] LogUtils
Re: org.apache.activemq.ActiveMQConnectionFactory cannot be cast to javax.jms.QueueConnectionFactory [message #1755044 is a reply to message #1755042] Mon, 27 February 2017 13:34 Go to previous messageGo to next message
Rajkumar Dangi is currently offline Rajkumar DangiFriend
Member
share your process model ?
Re: org.apache.activemq.ActiveMQConnectionFactory cannot be cast to javax.jms.QueueConnectionFactory [message #1755122 is a reply to message #1755044] Tue, 28 February 2017 09:33 Go to previous message
Hi Thanks for replying. I am using the model from example. I managed to google and remove the multiples of geronimo-jms_1.1_spec from classpath. now it is giving the following error. This is my first time using activmq and stardust, not sure what to setup. Activemq is started with default config outside of tomcat.
java.lang.NoClassDefFoundError: javax/jms/ConnectionFactory
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at org.apache.activemq.jndi.JNDIReferenceFactory.loadClass(JNDIReferenceFactory.java:126)
at org.apache.activemq.jndi.JNDIReferenceFactory.getObjectInstance(JNDIReferenceFactory.java:62)
at org.apache.naming.factory.ResourceFactory.getObjectInstance(ResourceFactory.java:141)
at javax.naming.spi.NamingManager.getObjectInstance(Unknown Source)
at org.apache.naming.NamingContext.lookup(NamingContext.java:848)
at org.apache.naming.NamingContext.lookup(NamingContext.java:159)
at org.apache.naming.NamingContext.lookup(NamingContext.java:836)
at org.apache.naming.NamingContext.lookup(NamingContext.java:173)
at org.apache.naming.SelectorContext.lookup(SelectorContext.java:156)
at javax.naming.InitialContext.lookup(Unknown Source)
at com.sun.proxy.$Proxy49.complete(Unknown Source)
Caused by: java.lang.ClassNotFoundException: javax.jms.ConnectionFactory
... 166 more
Previous Topic:cannot view pdf file
Next Topic:spi programming examples
Current Time: Sat May 30 09:48:29 GMT 2020
Powered by FUDForum. Page generated in 0.02289 seconds
