Re: Stereotype: Default value setting on a multi-valued enumeration [message #1755047 is a reply to message #1755030] |
Mon, 27 February 2017 13:53 |
Dear Bernd,
I guess when you say that the default value does not appear in the attributes of a class, you actually mean that it does not get assigned to the multivalued stereotype attribute typed with the enumeration.
I confirm that the assignment does not get done. This is not specific to enumerations, but would be the same for an integer value assigned to a multi-valued property. The problem is the combination of a collection with a single default value: semantically, it is not clear how many elements should be created for a multi-valued attribute. So, while I am not sure, I don't think that it is possible.
FUDForum. Page generated in 0.03395 seconds
