Home » Eclipse Projects » Eclipse Platform » same package in two different bundles: a problem?
same package in two different bundles: a problem? [message #331517] Wed, 10 September 2008 23:26 Go to next message
WinXP & R3.3
We have two different bundles (plug-ins) that happen both to declare a
package, say "com.mun.ist.foo", but contain no conflicting classes
(i.e., if there is a class named Bar in that package it appears in only
one of the bundles). The code all compiles and runs fine.
I think this is not a problem, as (e.g.) Eclipse does the same:
a) package org.eclipse.ui.internal:
(BUNDLE) org.eclipse.ui => (PACKAGE) org.eclipse.ui.internal
(BUNDLE) org.eclipse.ui.workbench => (PACKAGE) org.eclipse.ui.internal
b) package org.eclipse.core.runtime:
(BUNDLE) org.eclipse.core.runtime => (PACKAGE) org.eclipse.core.runtime
(BUNDLE) org.eclipse.osgi => (PACKAGE) org.eclipse.core.runtime
(BUNDLE) org.eclipse.equinox.common => (PACKAGE) org.eclipse.core.runtime
(BUNDLE) org.eclipse.core.runtime.compatibility.registry => (PACKAGE)
(BUNDLE) org.eclipse.equinox.registry => (PACKAGE) org.eclipse.core.runtime
But someone is now trying to claim that the mere presence of the same
package in two bundles will cause the class-loader to fail. (He offers
no actual evidence.)
What's the story?
thanks,
Paul
Re: same package in two different bundles: a problem? [message #331528 is a reply to message #331517] Thu, 11 September 2008 08:56 Go to previous messageGo to next message
Originally posted by: eclipse-news.rizzoweb.com
Paul Th. Keyser wrote:
> WinXP & R3.3
First thing I'd say is, "show me the money!" In other words, produce a
demonstration or documentation that says it fails. Without that, there
is no discussion.
Secondly, you have already pointed out that Eclipse "core" plugins do
this all over he place without any problems. That is pretty strong
evidence to the contrary.
Finally, remind this someone that plugins use a special custom
classloader, so his understanding of the standard classloader may not
apply here. OSGi is specialized when it comes to class loading.
Hope this helps,
Eric
Re: same package in two different bundles: a problem? [message #331530 is a reply to message #331517] Thu, 11 September 2008 09:02 Go to previous messageGo to next message
> What's the story?
As long as things are done properly, you should have no problem. I wrote
about some of this a few weeks ago:
http://code9.com/2008/08/22/tip-split-packages-and-visibilit y/
~ Chris
Re: same package in two different bundles: a problem? [message #331544 is a reply to message #331528] Thu, 11 September 2008 12:37 Go to previous messageGo to next message
>> WinXP & R3.3
> Hope this helps,
> Eric
:) Beautiful, thanks. (I also, subsequently, happened to notice also
that the jar that used to contain this code had/has exactly the same
packaging, so the test had in effect already been done.)
-Paul
Re: same package in two different bundles: a problem? [message #331546 is a reply to message #331530] Thu, 11 September 2008 12:40 Go to previous messageGo to next message
> Cheers,
> ~ Chris
Thanks, very nice -- and that OSGi course (also mentioned on Code-9)
sounds interesting ...
-Paul
Re: same package in two different bundles: a problem? [message #331550 is a reply to message #331530] Thu, 11 September 2008 12:54 Go to previous messageGo to next message
>> offers no actual evidence.)
>> What's the story?
Well "properly" is the key here ;-)
Important is to not access package visible stuff (types, methods, etc.)
from the other plug-in's package as this would result in an
IllegalAccessError thrown by the class loader.
Dani
> I wrote about some of this a few weeks ago:
> Cheers,
> ~ Chris
Re: same package in two different bundles: a problem? [message #331559 is a reply to message #331546] Thu, 11 September 2008 14:10 Go to previous message
>> Cheers,
>> ~ Chris
Cool! I'll shoot you an email with more information.
~ Chris
Previous Topic:Creating a perspective on Runtime
Next Topic:Obtaining *all* referenced projects (including plugins and external folders)
Current Time: Tue Mar 25 15:13:49 EDT 2025
Powered by FUDForum. Page generated in 0.04451 seconds
