Home » Modeling » TMF (Xtext) » JDT - Check Instance of RuntimeException(To check if a Exception class is subclass of RuntimeException using the QualifiedName string)
JDT - Check Instance of RuntimeException [message #1754845] Thu, 23 February 2017 07:24 Go to next message
Suresh P is currently offline Suresh PFriend
hi
By using JDT (AST), I need to check using the Exception class's QualifiedName (string format) is an subclass of RuntimeException class?
Im using the below code:
IMethodBinding methodbinding = ((MethodDeclaration)node).resolveBinding().getMethodDeclaration();
ITypeBinding[] exceptiontypes = methodbinding.getExceptionTypes();
Re: JDT - Check Instance of RuntimeException [message #1754846 is a reply to message #1754845] Thu, 23 February 2017 07:25 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
Hi, this is the Xtext forum, not the JDT forum. Please ask this in the JDT forum
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Previous Topic:how to call or run Java class(pure java code) in the Xtend Code when generate my Xtext Project ?
Next Topic:Producing multiple objects from one rule
Current Time: Wed Oct 20 14:33:49 GMT 2021
Powered by FUDForum. Page generated in 0.01815 seconds
