Problems when referencing Ecore elements using an imported Ecore model [message #1754821] |
Wed, 22 February 2017 18:47 |
in a new DSL I started to work on, I refer to Ecore elements in the DSL, something like
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
import "http://www.eclipse.org/xtext/xbase/Xbase" as xbase
generate myDsl "...my uri..."
Program:
('metamodel' metamodels+=[ecore::EPackage|STRING])*
So far so good, everything works. Now I'd like to switch to a manually maintained ecore model. I performed the steps to switch to an imported ecore model (starting from the one that Xtext had previously generated).
As soon as I switch in the grammar:
import "...my uri..."
The grammar editor starts complaining with a warning for the import:
"The imported package refers to elements in the package registry
instead of using the instances from the workspace"
and for the assignment metamodels+=[ecore::EPackage|STRING]) I get an error:
"Cannot find compatible feature metamodels in sealed EClass
Program from imported package myuri:
The type 'EPackage' [org.eclipse.emf.ecore.EPackage] used in
the reference 'metamodels' is inconsistent. Probably this is
due to an unsupported kind of metamodel hierarchy."
However, the workflow mwe2 still runs (of course, I updated it so that it references my genmodel).
The warning (not the error) proposes a quickfix to "update the imported package". The quickfix transforms in my ecore the reference:
<eStructuralFeatures xsi:type="ecore:EReference" name="metamodels" unique="false"
upperBound="-1" eType="ecore:EClass http://www.eclipse.org/emf/2002/Ecore#//EPackage"/>
into
upperBound="-1" eType="ecore:EClass ../../../org.eclipse.emf.ecore/model/Ecore.ecore#//EPackage"/>
Now the editor is happy (no more errors nor warnings). However, now it is the mwe2 workflow that complains with the same error I used to have in the editor:
"Cannot find compatible feature metamodels in sealed EClass EdeltaProgram from imported package ...myuri...: The type 'EPackage' used in the reference 'metamodels' is inconsistent. Probably this is due to an unsupported kind of metamodel hierarchy. (ErrorCode: CannotCreateTypeInSealedMetamodel)"
is there anything I could do to make "everyone" happy?
Could this be related https://github.com/eclipse/xtext-core/issues/41?
thanks in advance
Lorenzo
HOME: http://www.lorenzobettini.it
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754823 is a reply to message #1754822] |
Wed, 22 February 2017 19:04 |
interestingly this xcore setup seems to work (i did not test if what comes out acutally runs
@GenModel(nsUri="http://www.example.com//zzz")
package zzz
import org.eclipse.emf.ecore.EPackage
class Model {
refers EPackage[] metamodels
grammar org.xtext.example.mydsl8.MyDsl with org.eclipse.xtext.common.Terminals
import "zzz"
Model returns Model:
{Model}
'Model'
('metamodels' '(' metamodels+=[ecore::EPackage|STRING] ( "," metamodels+=[ecore::EPackage|STRING])* ')' )?
language = StandardLanguage {
name = "org.xtext.example.mydsl8.MyDsl"
fileExtensions = "mydsl8"
referencedResource = "platform:/resource/org.eclipse.emf.ecore/model/Ecore.genmodel"
referencedResource = "platform:/resource/zzz.xcore/model/zzz.xcore"
Twitter : @chrdietrich
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754867 is a reply to message #1754862] |
Thu, 23 February 2017 10:53 |
OK, I added that in the grammar:
import "platform:/resource/org.eclipse.emf.ecore/model/Ecore.ecore" as ecore
import "platform:/resource/org.eclipse.xtext.xbase/model/Xbase.ecore" as xbase
import "platform:/resource/org.eclipse.xtext.xbase/model/Xtype.ecore" as xtype
import "platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.ecore" as types
The Xtext editor still complains with errors and now also mwe2 fails with the same problems, so both now fail consistently.
If I now modify the ecore manually using platform uris for ecore references, the editor is happy but now the mwe2 fails with a different error:
java.lang.IllegalStateException: Validation Error in edelta.Edelta: The rule 'STRING' is not valid for a cross reference since it does not return an EString. You'll have to wrap it in a data type rule.
at org.eclipse.xtext.xtext.generator.XtextGeneratorLanguage$1.add(XtextGeneratorLanguage.java:300)
If I redefine the terminal rule STRING in my grammar
terminal STRING:
'"' ( '\\' . /* ('b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\') */ | !('\\'|'"') )* '"'? |
"'" ( '\\' . /* ('b'|'t'|'n'|'f'|'r'|'u'|'"'|"'"|'\\') */ | !('\\'|"'") )* "'"?;
Then mwe2 throws another exception:
java.lang.RuntimeException: Problems running workflow edelta.GenerateEdelta: Problem parsing 'file:/home/bettini/work/xtext/edelta/edelta.parent/edelta/../edelta/src/edelta/Edelta.xtext':
TransformationDiagnostic: null:92 Cannot inherit from terminal rule and return another type. (ErrorCode: InvalidSupertype)
I guess there's no easy way to deceive the EMF registry...
Re: Problems when referencing Ecore elements using an imported Ecore model [message #1754880 is a reply to message #1754878] |
Thu, 23 February 2017 12:58 |
OK, I can answer myself:
class CustomGeneratorModule extends DefaultGeneratorModule {
def Class<? extends XtextGeneratorResourceSetInitializer> bindXtextGeneratorResourceSetInitializer() {
CustomXtextGeneratorResourceSetInitializer
Workflow {
component = XtextGenerator {
configuration = CustomGeneratorModule {
project = StandardProjectConfig {...
and (note the commented line):
@Log
class CustomXtextGeneratorResourceSetInitializer extends XtextGeneratorResourceSetInitializer {
override initialize(ResourceSet resourceSet, List<String> referencedResources) {
val delegate = new StandaloneSetup
delegate.resourceSet = resourceSet
// resourceSet.packageRegistry.put(EcorePackage.eNS_URI, EcorePackage.eINSTANCE)
referencedResources.forEach[
loadResource(resourceSet)
registerGenModels(resourceSet)
registerEPackages(resourceSet)
... everything else copied and pasted from the superclass since it's all private
This makes mwe2 finally work... (and tests are still green)
I don't know how this could be generalized for the bug...
I'll also try to revert the imports in the grammar with platform uris and see what happens
FUDForum. Page generated in 0.04067 seconds
