Home » Modeling » EMF » Very high loading times of models with ID feature
Very high loading times of models with ID feature [message #1754259] Wed, 15 February 2017 19:53 Go to next message
Bugra M. Yildiz is currently offline Bugra M. YildizFriend
I have Java code that uses EMF Reflective library to load the models (model instances, not metamodels). For the models whose metamodel includes a feature serves as an ID, the loading of the model takes ages: 45 minutes for a model of size 20 MB.
I have tried to set the options of loading the models as described in multiple places:
https://www.eclipse.org/forums/index.php/t/929918/
https://www.eclipse.org/modeling/emf/docs/performance/EMFPerformanceTips.html
http://www.jevon.org/wiki/Improving_EMF_Model_Loading_Performance
https://sdqweb.ipd.kit.edu/wiki/EMF_Model_Loading_Performance_Tweaks
There is no change in the performance as reported in some other post:
https://sdqweb.ipd.kit.edu/wiki/EMF_Model_Loading_Performance_Tweaks .
I need help with this issue.
Thank you.
Re: Very high loading times of models with ID feature [message #1754277 is a reply to message #1754259] Thu, 16 February 2017 06:55 Go to previous messageGo to next message
I see the last link mentions using an intrinsic map. I suspect you've not done this. Any time you have bad performance, it's worth your while to use a tool like YourKit to measure what specifically is so slow. It's likely this would point at org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObjectByID(String) as a bottleneck and then you'd look at the code and quickly see how the intrinsic map would improve things:
  protected EObject getEObjectByID(String id)
    Map<String, EObject> map = getIntrinsicIDToEObjectMap();
    if (map != null)
      EObject eObject = map.get(id);
      if (eObject != null)
        return eObject;
Ed Merks
Re: Very high loading times of models with ID feature [message #1754318 is a reply to message #1754277] Thu, 16 February 2017 11:08 Go to previous messageGo to next message
You are right, after putting the map, it started working much faster. Thanks for the help and response.
Re: Very high loading times of models with ID feature [message #1754334 is a reply to message #1754277] Thu, 16 February 2017 12:52 Go to previous messageGo to next message
Erdal Karaca is currently offline Erdal KaracaFriend
Hi Ed,
I have seen people often fall into this trap:
Can't EMF provide that setting by default? What is the reason for explicitly setting the map?
Ed Merks wrote on Thu, 16 February 2017 07:55
    if (map != null)
        return eObject;
Re: Very high loading times of models with ID feature [message #1754349 is a reply to message #1754334] Thu, 16 February 2017 15:42 Go to previous messageGo to next message
A default where though? Changing behavior for existing clients tends to invite new problems...
Ed Merks
Re: Very high loading times of models with ID feature [message #1754350 is a reply to message #1754349] Thu, 16 February 2017 15:55 Go to previous messageGo to next message
So, the reason to set the map manually and not by default is to not break compatibility?
Maybe, provide an addtional resource option as most people first look at what options are available.
Example:
loadOptions.put(XMLResource.OPTION_USE_INTRINSIC_ID_MAP, Boolean.TRUE);
Re: Very high loading times of models with ID feature [message #1754376 is a reply to message #1754350] Fri, 17 February 2017 05:57 Go to previous message
How about adding Javadoc to the org.eclipse.emf.ecore.xmi.XMLResource.OPTION_DEFER_IDREF_RESOLUTION option? E.g.,
   * For best performance resolving IDs,
   * it's most effective to use this option set to true in conjunction with an {@link ResourceImpl#setIntrinsicIDToEObjectMap(Map) intrinsic ID map},
   * which is best set in the {@link Resource.Factory#createResource(URI) resource factory}.
If people are actually looking at that, they can read it, and know what needs to be done, without yet another mechanism for doing it (which they'd have to look for and read as well). Please open a Bugzilla if you think that's an improvement.
Ed Merks
Previous Topic:Unable to set an attribute as primary key
Next Topic:get name/address of model
Current Time: Mon Sep 27 11:34:26 GMT 2021
Powered by FUDForum. Page generated in 0.01480 seconds
