Home » Eclipse Projects » Plugin Development Environment (PDE) » JDT bootclasspath problem(Upgrading PDE (and Java) results in ERROR: The type java.lang.Object cannot be resolved.)
JDT bootclasspath problem [message #1754243] Wed, 15 February 2017 16:40 Go to next message
Steve Taylor is currently offline Steve TaylorFriend
I'm upgrading a collection of headless PDE builds from:
org.eclipse.pde.build_3.8.2.v20121114-140810
to
org.eclipse.pde.build_3.9.100.v20150521-1524
and
java 6 to java 7.
Nothing else has changed. I've started to get errors along the lines of:
"The type java.lang.Object cannot be resolved."
I'm guessing that somehow the bootclasspath is not getting set. I've read countless posts along similar lines but the solutions either don't apply or don't work.
Anyone seen this or know what the problem is?
Re: JDT bootclasspath problem [message #1754323 is a reply to message #1754243] Thu, 16 February 2017 11:45 Go to previous messageGo to next message
*UPDATE* - launching python bootstrapper in a different way has fixed this - not sure why but I'm presuming the cause was environmental. If I get time I'll go back and investigate why and add a further update.
[Updated on: Thu, 16 February 2017 11:46]
Report message to a moderator
Re: JDT bootclasspath problem [message #1754345 is a reply to message #1754323] Thu, 16 February 2017 15:00 Go to previous messageGo to next message
*FURTHER UPDATE* - I spoke to soon - problem is back.
Re: JDT bootclasspath problem [message #1754997 is a reply to message #1754345] Sat, 25 February 2017 17:21 Go to previous message
Stephan Herrmann is currently offline Stephan HerrmannFriend
Do you have a "global" build.properties for your build?
Does it contain an entry for "JavaSE-1.7"?
Here's the entry from a build that I maintain:
JavaSE-1.7=/shared/common/oracle-jre1.7.0/lib/rt.jar:/shared/common/oracle-jre1.7.0/lib/charsets.jar:/shared/common/oracle-jre1.7.0/lib/deploy.jar:/shared/common/oracle-jre1.7.0/lib/management-agent.jar:/shared/common/oracle-jre1.7.0/lib/alt-rt.jar:/shared/common/oracle-jre1.7.0/lib/plugin.jar:/shared/common/oracle-jre1.7.0/lib/security/US_export_policy.jar:/shared/common/oracle-jre1.7.0/lib/security/local_policy.jar:/shared/common/oracle-jre1.7.0/lib/resources.jar:/shared/common/oracle-jre1.7.0/lib/jsse.jar:/shared/common/oracle-jre1.7.0/lib/jce.jar:/shared/common/oracle-jre1.7.0/lib/javaws.jar
OTOH, when you say you changed from Java 6 to 7, it is not clear if this concerns the JVM that runs the build or the target of the software being built?
Previous Topic:API to access OSGi information at compile time
Next Topic:Register a ToolBar in an e4 view
Current Time: Wed Oct 21 17:16:50 GMT 2020
Powered by FUDForum. Page generated in 0.01937 seconds
