Home » Newcomers » Newcomers » Plugins are probably installed but unavailable(Problem with installing plugins in Neon 2)
Plugins are probably installed but unavailable [message #1753496] Tue, 07 February 2017 08:55 Go to next message
Tal Tene is currently offline Tal TeneFriend
I recently installed several eclipse plugins (see image). The common for all of them is that I cannot find the way of using them.
I can see them in the Marketplace dialog "installed" tab.
But I cannot use them. I cannot find them anywhere around the IDE!!
Can you assist please?
Windows 7.
Neon 2.
Thanks.
Re: Plugins are probably installed but unavailable [message #1753724 is a reply to message #1753496] Thu, 09 February 2017 10:59 Go to previous messageGo to next message
Wow! 1700 views and nobody ever had this phenomena?... Sad
Re: Plugins are probably installed but unavailable [message #1753746 is a reply to message #1753724] Thu, 09 February 2017 15:03 Go to previous message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
You should check their individual documentation to see how they're supposed to work, and their support forums to troubleshoot them. They're not provided by eclipse.org, so you might be addressing an audience that doesn't use any of those plug-ins. Otherwise, it would help to have more (any?) details about the version of Eclipse you're using, where in the UI specifically where new things should appear but don't, and if there's anything at all in the Error Log view.
Nitin Dahyabhai
Eclipse Web Tools Platform
Previous Topic:Easy way to install missing packages?
Next Topic:RSS links do not work
Current Time: Fri Aug 07 22:41:48 GMT 2020
Powered by FUDForum. Page generated in 0.04449 seconds
